Composer-Callflow development-Dynamic Maximum input Digits
Hi All,
Is it possible to make the assign variable for Maximum Input Digits in Input Block.
I am trying to build a generic call flow, where i require Maximum and Minimum Input variables Dynamic.
Kindly suggest.
I don’t think you can do that, but perhaps you could create a loop on the Input block that collects only one digit and validate it after the loop is finished.
Thank you for the reply.
i just came to know that, there is a possibility of using external grammar for DTMF, and handle max input digits inside grammar.
It works.
or …
Assign min 0 and max 99 in block INPUT and handle block BRANCHING with two min and max variables with javascript.
´s
