Composer 8.1.410.14 issues
Hi guys
Wondering if you are having same issues as me before opening a ticket at G
  1. If we use ComposerRoot variables () it will replicate as many subcallflows as we have on a single call flow.
    Meaning, we create a root variable var1, now we have Main.callflow and Sub1.callflow then Sub1.callflow will have on its code 2 var1 declared. See pic linked 1.
http://s32.postimg.org/dup9f14ch/composer2.jpg
http://s32.postimg.org/ffvsyqgqp/composer3.jpg
  1. If we copy this project and rename it, the Subcallflow calls are not updated and keep linking to original Project. Meaning: I have project Test1, copy and rename Test2. Now we go to Test2 and check Subdialog properties…amazingly it doesn’t point to subproject located on Test2 but to Test1, so if we have like 100 subcallflows means we have to update by hand each one…O.o this didn’t happen on previous versions. All was done automatically. If we don’t do this when we compile it will point to the Test1 project even on VXML code, which creates a really mess as calls wrong code.
http://s32.postimg.org/u52wljrcx/composer1.jpg
http://s32.postimg.org/71tl7krwh/composer4.jpg
Have tested last Composer version and same stuff, corrected a but where on VXML code it declared all root variables as well even duplicated, creating a mess on code.
Anyone can validate this and let me know I am not crazy?
Thanks!
I can take a look, later today. I’m pretty sure I came across this before and that there is a difference between copy/paste and export/import but I will need to check…
Probably but tested on older versions and they work as expected, they update the subdialog references automatically.
They did - they used to - now they don’t. I guess it’s Ticket time, cav…
I have similar an issue with Composer 8.1.410.14 also but a little different.
I have imported the webengagement_chat project and I cannot change a project variable. I open the “Access Diagram variables” and give a default value ti a project variable. validate - no error, then I press OK. I open again the variables window and my variable is empty again. This is not a system variable.. is a project one so I should be able to change it. The same thing if I want to add a new variable.. it’s like the project is read only.
Did you upgraded the project?
I did and did not :slight_smile:
I did upgrade and it says upgrade successful but when I press Generate all it still says not up-to-date so I manually altered the .composer file. It al works now except modifying or adding new variables. For modifying them I added an assign block right after start and is OK
vma
Weird…I downloaded last version (not in my head which one) and upgraded and was better than previous one. Not perfect tho.
Then just created a new project and copied the callflows from old only to this new one and magic! Issues fixed on variables. Not perfect yet but better…
