Compatiblity issue of Composer
I developed ivr callflow using composer 8.0.401.84, exported project, imported into composer 8.1.101.88, but when I tried to open callflow,
I got the following error message:
Cannot open input element:
Reason:
Value:
‘com.genesyslab.studio.model.gvp.datatypes.impl.PromptItemImpl@10d16b(name:noinput1)(value: Language/1000.vox)(interpretAs: Text,type:Value,alternateText: , format:, note:, instruction:, …’
Is there anyone who experienced similar problem?
Thanks in advance.
Kevin
Hi Kevin,
Have you upgraded your project created with Composer 8.0.401.84 before opening it with version 8.1.101.88?
Thansk, Rene, good point. I didn’t upgrade. but I just tried, there is still a error msg.
“The upgrade process has ran into an error. Please see Details and check the logs”.
When I opened details: there is java NullPointer error.
java.lang.NullPointerException.
Thanks, It works now.
can you please tell us , how you solve this issue
Read the posts above… The solution is therr
