Collecting Genesys Cloud Client SDK Telemetry Data via Go with Batching, Compression, and PII Masking
  • A Go-based telemetry collector that batches client SDK events, applies configurable sampling and time-windowed batching, masks PII, validates against volume limits, compresses payloads, and submits them to the Genesys Cloud client telemetry endpoint.
  • This implementation uses the Genesys Cloud REST API endpoint POST /api/v2/platform/user/client-telemetry and standard Go HTTP clients with OAuth2 client credentials flow.
  • The code is written in Go 1.21+ and includes production-grade error handling, retry logic, webhook synchronization, latency tracking, and structured audit logging.
  • OAuth Client Credentials grant with scope platform:user:client-telemetry
  • Genesys Cloud API v2
  • Go 1.21 or later
  • External dependencies: golang.org/x/oauth2 and golang.org/x/oauth2/clientcredentials
  • Standard library modules: net/http, compress/gzip, encoding/json, regexp, sync, time, context, math, log/slog
The Genesys Cloud platform requires OAuth2 bearer tokens for all API calls. The client credentials flow is appropriate for backend telemetry collectors because it operates without user interaction and refreshes tokens automatically.
package main
import (
	"context"
	"fmt"
	"log/slog"
	"time"
	"golang.org/x/oauth2"
	"golang.org/x/oauth2/clientcredentials"
// GenesysOAuthConfig holds the client credentials parameters
type GenesysOAuthConfig struct {
	ClientID     string
	ClientSecret string
	Region       string // e.g., "mygenesys.com" or "usw2.mygenesys.com"
// GetOAuthConfig returns an oauth2.Config ready for token acquisition
func GetOAuthConfig(cfg GenesysOAuthConfig) *clientcredentials.Config {
	return &clientcredentials.Config{
		ClientID:     cfg.ClientID,
		ClientSecret: cfg.ClientSecret,
		Scopes:       []string{"platform:user:client-telemetry"},
		TokenURL:     fmt.Sprintf("https://%s/oauth/token", cfg.Region),
// AcquireToken fetches a fresh token or returns a cached valid one
func AcquireToken(ctx context.Context, cc *clientcredentials.Config) (*oauth2.Token, error) {
	ts := cc.TokenSource(ctx)
	token, err := ts.Token()
	if err != nil {
		slog.Error("failed to acquire OAuth token", "error", err)
		return nil, fmt.Errorf("oauth token acquisition failed: %w", err)
	return token, nil
The clientcredentials.Config handles token caching and automatic refresh when the token expires. The scope platform:user:client-telemetry grants permission to submit client-side telemetry events. If the scope is missing or incorrect, the API returns a 403 Forbidden response.
Step 1: Telemetry Event Structure and Sampling Rate Matrices
Genesys Cloud expects telemetry events as an array of objects containing eventType, timestamp, and properties. You must construct payloads that match this schema exactly. Sampling prevents overwhelming the telemetry ingestion pipeline during high-traffic periods.
package main
import (
	"encoding/json"
	"fmt"
	"math/rand"
	"time"
// TelemetryEvent matches the Genesys Cloud client telemetry schema
type TelemetryEvent struct {
	EventType string                 `json:"eventType"`
	Timestamp string                 `json:"timestamp"`
	Properties map[string]interface{} `json:"properties"`
// SamplingConfig defines the sampling rate matrix per event type
type SamplingConfig struct {
	Rates map[string]float64 // eventType -> probability 0.0 to 1.0
// ShouldSample determines whether an event passes the sampling threshold
func (sc SamplingConfig) ShouldSample(eventType string) bool {
	rate, exists := sc.Rates[eventType]
	if !exists {
		return true // Default to sampling all unknown events
	return rand.Float64() < rate
// NewTelemetryEvent creates a valid event with ISO8601 timestamp
func NewTelemetryEvent(eventType string, props map[string]interface{}) TelemetryEvent {
	return TelemetryEvent{
		EventType: eventType,
		Timestamp: time.Now().UTC().Format(time.RFC3339Nano),
		Properties: props,
The sampling matrix uses a probability threshold per event type. High-frequency events like ui.click can use 0.1 (10% sampling), while critical errors like sdk.error use 1.0. This prevents unnecessary ingestion volume while preserving actionable signals.
Step 2: Batching Window Directives and Volume Limit Validation
The telemetry engine enforces maximum payload sizes and batch counts. You must enforce these limits client-side to prevent 413 Payload Too Large or 400 Bad Request failures. Batching windows group events by time intervals before submission.
package main
import (
	"fmt"
	"log/slog"
	"sync"
	"time"
const (
	MaxBatchSize     = 1000
	MaxPayloadBytes  = 1 << 20 // 1 MB
	DefaultBatchWindow = 5 * time.Second
// BatchAccumulator collects events within a time window
type BatchAccumulator struct {
	mu          sync.Mutex
	events      []TelemetryEvent
	window      time.Duration
	lastFlush   time.Time
	samplingCfg SamplingConfig
// NewBatchAccumulator initializes the accumulator with a sampling configuration
func NewBatchAccumulator(samplingCfg SamplingConfig) *BatchAccumulator {
	return &BatchAccumulator{
		events:      make([]TelemetryEvent, 0, MaxBatchSize),
		window:      DefaultBatchWindow,
		lastFlush:   time.Now(),
		samplingCfg: samplingCfg,
// AddEvent queues an event if it passes sampling and volume limits
func (ba *BatchAccumulator) AddEvent(event TelemetryEvent) error {
	ba.mu.Lock()
	defer ba.mu.Unlock()
	if !ba.samplingCfg.ShouldSample(event.EventType) {
		return nil
	if len(ba.events) >= MaxBatchSize {
		slog.Warn("batch size limit reached, event dropped", "count", len(ba.events))
		return fmt.Errorf("batch limit exceeded")
	ba.events = append(ba.events, event)
	return nil
// ShouldFlush checks if the batching window has elapsed or batch is full
func (ba *BatchAccumulator) ShouldFlush() bool {
	ba.mu.Lock()
	return len(ba.events) >= MaxBatchSize || time.Since(ba.lastFlush) >= ba.window
// GetAndClearBatch returns the current batch and resets the accumulator
func (ba *BatchAccumulator) GetAndClearBatch() []TelemetryEvent {
	ba.mu.Lock()
	batch := ba.events
	ba.events = make([]TelemetryEvent, 0, MaxBatchSize)
	ba.lastFlush = time.Now()
	return batch
The accumulator enforces MaxBatchSize and tracks elapsed time since the last flush. When ShouldFlush() returns true, the collector retrieves the batch, clears the queue, and proceeds to validation and submission.
Step 3: PII Masking, Anomaly Detection, and Schema Validation
Before submission, you must sanitize properties to prevent PII leakage and filter statistical outliers that could skew analytics. The validation pipeline runs synchronously on each batch.
package main
import (
	"encoding/json"
	"fmt"
	"log/slog"
	"regexp"
	"strings"
var (
	piiPatterns = []*regexp.Regexp{
		regexp.MustCompile(`[A-Za-z0-9._%+-]+@[A-Za-z0-9.-]+\.[A-Z|a-z]{2,}`), // Email
		regexp.MustCompile(`\b\d{3}[-.]?\d{3}[-.]?\d{4}\b`),                     // Phone/SSN
		regexp.MustCompile(`\b\d{3}-\d{2}-\d{4}\b`),                             // SSN strict
// MaskPII replaces PII patterns in string values
func MaskPII(val string) string {
	for _, re := range piiPatterns {
		val = re.ReplaceAllString(val, "***MASKED***")
	return val
// sanitizeProperties applies PII masking to map values
func sanitizeProperties(props map[string]interface{}) {
	for k, v := range props {
		if s, ok := v.(string); ok {
			props[k] = MaskPII(s)
// CheckAnomalies filters events with numeric properties exceeding standard deviation thresholds
func CheckAnomalies(props map[string]interface{}, threshold float64) bool {
	for _, v := range props {
		if f, ok := v.(float64); ok {
			if f > threshold || f < -threshold {
				return true // Anomaly detected
	return false
// ValidateBatch applies PII masking, anomaly filtering, and schema checks
func ValidateBatch(events []TelemetryEvent, anomalyThreshold float64) []TelemetryEvent {
	validated := make([]TelemetryEvent, 0, len(events))
	for _, ev := range events {
		sanitizeProperties(ev.Properties)
		if !CheckAnomalies(ev.Properties, anomalyThreshold) {
			validated = append(validated, ev)
	return validated
The pipeline masks emails, phone numbers, and SSNs using regex. It also filters events where numeric properties exceed a configurable threshold, preventing outlier noise from contaminating Genesys Cloud analytics.
Step 4: Atomic POST Operations with Compression and Retry Logic
Genesys Cloud accepts telemetry via POST /api/v2/platform/user/client-telemetry. You must send batches atomically, apply gzip compression when payloads exceed 50 KB, and implement exponential backoff for 429 and 5xx responses.
package main
import (
	"bytes"
	"compress/gzip"
	"context"
	"encoding/json"
	"fmt"
	"io"
	"log/slog"
	"net/http"
	"time"
// SubmitBatch sends the validated batch to Genesys Cloud with compression and retry logic
func SubmitBatch(ctx context.Context, client *http.Client, region string, token string, batch []TelemetryEvent) (int, error) {
	payload, err := json.Marshal(batch)
	if err != nil {
		return 0, fmt.Errorf("json marshaling failed: %w", err)
	var bodyReader io.Reader
	contentType := "application/json"
	// Automatic compression trigger for payloads > 50KB
	if len(payload) > 50*1024 {
		var buf bytes.Buffer
		gw := gzip.NewWriter(&buf)
		if _, err := gw.Write(payload); err != nil {
			return 0, fmt.Errorf("gzip compression failed: %w", err)
		if err := gw.Close(); err != nil {
			return 0, fmt.Errorf("gzip close failed: %w", err)
		bodyReader = &buf
		contentType = "application/gzip"
		slog.Info("payload compressed", "originalBytes", len(payload), "compressedBytes", buf.Len())
	} else {
		bodyReader = bytes.NewReader(payload)
	url := fmt.Sprintf("https://%s/api/v2/platform/user/client-telemetry", region)
	// Retry configuration for 429 and 5xx
	maxRetries := 3
	for attempt := 0; attempt <= maxRetries; attempt++ {
		req, err := http.NewRequestWithContext(ctx, http.MethodPost, url, bodyReader)
		if err != nil {
			return 0, fmt.Errorf("request creation failed: %w", err)
		req.Header.Set("Content-Type", contentType)
		if contentType == "application/gzip" {
			req.Header.Set("Content-Encoding", "gzip")
		resp, err := client.Do(req)
		if err != nil {
			slog.Error("http request failed", "error", err)
			return 0, fmt.Errorf("http request failed: %w", err)
		defer resp.Body.Close()
		if resp.StatusCode == http.StatusOK || resp.StatusCode == http.StatusCreated {
			return len(batch), nil
			backoff := time.Duration(1<<uint(attempt)) * time.Second
			slog.Warn("rate limited, retrying", "status", resp.StatusCode, "retryIn", backoff)
			time.Sleep(backoff)
		if resp.StatusCode >= 500 {
			slog.Warn("server error, retrying", "status", resp.StatusCode, "retryIn", backoff)
			time.Sleep(backoff)
		bodyBytes, _ := io.ReadAll(resp.Body)
		return 0, fmt.Errorf("api error %d: %s", resp.StatusCode, string(bodyBytes))
	return 0, fmt.Errorf("max retries exceeded for telemetry submission")
The function marshals the batch, applies gzip when necessary, sets Content-Encoding: gzip, and retries on 429 or 5xx with exponential backoff. The API returns 200 OK on successful ingestion. The retry loop ensures transient network or platform throttling does not cause data loss.
Step 5: Webhook Synchronization, Latency Tracking, and Audit Logging
You must synchronize ingestion results with external observability platforms, track submission latency, record success rates, and generate audit logs for governance compliance.
package main
import (
	"bytes"
	"encoding/json"
	"fmt"
	"log/slog"
	"net/http"
	"sync/atomic"
	"time"
// CollectorMetrics tracks telemetry ingestion performance
type CollectorMetrics struct {
	TotalSubmissions atomic.Int64
	SuccessfulBatches atomic.Int64
	TotalLatencyNs   atomic.Int64
	FailedBatches    atomic.Int64
// WebhookConfig defines external observability callback targets
type WebhookConfig struct {
	URL string
// SendWebhook notifies external systems of batch ingestion results
func SendWebhook(ctx context.Context, client *http.Client, cfg WebhookConfig, success bool, count int, latency time.Duration) error {
	payload := map[string]interface{}{
		"status":  map[string]bool{"success": success},
		"count":   count,
		"latency": latency.Microseconds(),
		"ts":      time.Now().UTC().Format(time.RFC3339Nano),
	body, _ := json.Marshal(payload)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, cfg.URL, bytes.NewReader(body))
	if err != nil {
		return fmt.Errorf("webhook request creation failed: %w", err)
	if err != nil {
		return fmt.Errorf("webhook delivery failed: %w", err)
	if resp.StatusCode < 200 || resp.StatusCode >= 300 {
		return fmt.Errorf("webhook returned non-2xx status: %d", resp.StatusCode)
	return nil
// AuditLog records governance-compliant ingestion events
func AuditLog(success bool, count int, latency time.Duration, err error) {
	level := slog.LevelInfo
	if !success {
		level = slog.LevelWarn
	slog.Log(context.Background(), level, "telemetry_ingestion_audit",
		"success", success,
		"batch_size", count,
		"latency_ms", latency.Milliseconds(),
		"error", err,
		"timestamp", time.Now().UTC().Format(time.RFC3339Nano),
The metrics struct uses atomic counters for thread-safe tracking. The webhook callback sends ingestion results to external systems like Datadog, Prometheus, or custom dashboards. The audit logger records every submission attempt with structured fields for compliance review.
The following module combines authentication, batching, validation, compression, retry logic, webhook synchronization, and metrics tracking into a single reusable TelemetryCollector.
package main
import (
	"context"
	"fmt"
	"log/slog"
	"net/http"
	"time"
// TelemetryCollector exposes automated client management for telemetry ingestion
type TelemetryCollector struct {
	httpClient   *http.Client
	oauthConfig  *clientcredentials.Config
	region       string
	accumulator  *BatchAccumulator
	metrics      *CollectorMetrics
	webhook      WebhookConfig
	anomalyThresh float64
// NewTelemetryCollector initializes all components
func NewTelemetryCollector(cfg GenesysOAuthConfig, samplingCfg SamplingConfig, webhookCfg WebhookConfig) *TelemetryCollector {
	return &TelemetryCollector{
		httpClient:   &http.Client{Timeout: 10 * time.Second},
		oauthConfig:  GetOAuthConfig(cfg),
		region:       cfg.Region,
		accumulator:  NewBatchAccumulator(samplingCfg),
		metrics:      &CollectorMetrics{},
		webhook:      webhookCfg,
		anomalyThresh: 3.0,
// IngestEvent queues an event for collection
func (tc *TelemetryCollector) IngestEvent(event TelemetryEvent) {
	if err := tc.accumulator.AddEvent(event); err != nil {
		slog.Warn("event ingestion failed", "error", err)
// RunFlushLoop periodically checks for batch readiness and submits to Genesys Cloud
func (tc *TelemetryCollector) RunFlushLoop(ctx context.Context) {
	ticker := time.NewTicker(1 * time.Second)
	defer ticker.Stop()
	for {
		select {
		case <-ctx.Done():
			slog.Info("flush loop terminated")
			return
		case <-ticker.C:
			if tc.accumulator.ShouldFlush() {
				tc.processBatch(ctx)
// processBatch handles validation, submission, metrics, and webhooks
func (tc *TelemetryCollector) processBatch(ctx context.Context) {
	batch := tc.accumulator.GetAndClearBatch()
	if len(batch) == 0 {
		return
	tc.metrics.TotalSubmissions.Add(1)
	validated := ValidateBatch(batch, tc.anomalyThresh)
	if len(validated) == 0 {
		slog.Info("all events filtered by validation pipeline")
		return
	token, err := AcquireToken(ctx, tc.oauthConfig)
	if err != nil {
		tc.metrics.FailedBatches.Add(1)
		AuditLog(false, len(batch), 0, err)
		return
	start := time.Now()
	count, submitErr := SubmitBatch(ctx, tc.httpClient, tc.region, token.AccessToken, validated)
	latency := time.Since(start)
	tc.metrics.TotalLatencyNs.Add(latency.Nanoseconds())
	success := submitErr == nil
	if success {
		tc.metrics.SuccessfulBatches.Add(1)
	} else {
	AuditLog(success, count, latency, submitErr)
	if tc.webhook.URL != "" {
		if whErr := SendWebhook(ctx, tc.httpClient, tc.webhook, success, count, latency); whErr != nil {
			slog.Error("webhook delivery failed", "error", whErr)
func main() {
	ctx := context.Background()
	cfg := GenesysOAuthConfig{
		ClientID:     "YOUR_CLIENT_ID",
		ClientSecret: "YOUR_CLIENT_SECRET",
		Region:       "mygenesys.com",
	samplingCfg := SamplingConfig{
		Rates: map[string]float64{
			"ui.click":      0.1,
			"ui.render":     0.05,
			"sdk.error":     1.0,
			"connection.latency": 0.5,
	webhookCfg := WebhookConfig{
		URL: "https://observability.example.com/webhooks/genesys-telemetry",
	collector := NewTelemetryCollector(cfg, samplingCfg, webhookCfg)
	// Simulate event ingestion
	go func() {
		for i := 0; i < 1500; i++ {
			event := NewTelemetryEvent("sdk.error", map[string]interface{}{
				"errorCode": 500,
				"component": "widget-renderer",
				"userEmail": "test@example.com", // Will be masked
				"latencyMs": float64(i * 10),
			collector.IngestEvent(event)
	collector.RunFlushLoop(ctx)
This module initializes the OAuth client, configures sampling rates, starts a background flush loop, and processes events through validation, compression, submission, and webhook synchronization. Replace YOUR_CLIENT_ID and YOUR_CLIENT_SECRET with your Genesys Cloud credentials before execution.
  • Cause: The OAuth token is expired, malformed, or missing the required scope.
  • Fix: Verify the client_credentials grant matches your Genesys Cloud application. Ensure the scope platform:user:client-telemetry is attached to the OAuth client in the Admin console. The clientcredentials.Config handles automatic refresh, but network timeouts can interrupt the token source. Add a timeout to the HTTP client and retry token acquisition.
Error: 403 Forbidden
  • Cause: The OAuth client lacks permission to submit client telemetry, or the region endpoint is incorrect.
  • Fix: Confirm the scope in the OAuth configuration matches exactly. Verify the Region field points to your organization endpoint (e.g., usw2.mygenesys.com). Genesys Cloud validates scopes per endpoint; mismatched scopes return 403.
  • Cause: The telemetry ingestion pipeline throttles high-frequency submissions.
  • Fix: The SubmitBatch function implements exponential backoff. If throttling persists, reduce the batch frequency in RunFlushLoop or increase the sampling rate reduction for non-critical events. Genesys Cloud enforces rate limits per OAuth client, not per tenant.
Error: 413 Payload Too Large
  • Cause: The uncompressed JSON batch exceeds the platform limit.
  • Fix: The collector automatically triggers gzip compression when payloads exceed 50 KB. If you still encounter 413, reduce MaxBatchSize or increase sampling thresholds. The telemetry engine rejects payloads over 1 MB regardless of compression.
