Closing NICE CXone Web Messaging Sessions via Python with Validation and Audit Logging
  • A Python module that programmatically terminates CXone Web Messaging sessions using atomic POST requests with structured close payloads.
  • The implementation leverages the CXone REST API through httpx with Pydantic schema validation, pending message verification, and automated transcript finalization triggers.
  • The code is written in Python 3.9+ and provides latency tracking, external case system synchronization, audit logging, and a reusable session closer interface.
  • OAuth Client Credentials grant type with scopes: messaging:write, sessions:manage, analytics:read
  • CXone API version: v2 for OAuth token endpoint, v1 for messaging endpoints
  • Python 3.9+ runtime
  • External dependencies: httpx, pydantic, pydantic-settings, logging, uuid, time, typing
CXone requires OAuth 2.0 client credentials authentication for server-to-server API access. The token endpoint issues short-lived access tokens that must be cached and refreshed before expiration. The following client initialization handles token acquisition, storage, and automatic injection into subsequent requests.
import httpx
import logging
from typing import Optional
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
logger = logging.getLogger("cxone_session_closer")
class CXoneAuthClient:
    def __init__(self, tenant: str, client_id: str, client_secret: str):
        self.tenant = tenant
        self.client_id = client_id
        self.token_url = f"https://{tenant}.cxone.com/api/v2/oauth2/token"
        self.http = httpx.Client(timeout=httpx.Timeout(30.0))
    def _get_token(self) -> str:
        if self.access_token and time.time() < self.token_expiry:
            return self.access_token
        payload = {
            "client_id": self.client_id,
        response = self.http.post(self.token_url, data=payload)
        response.raise_for_status()
        token_data = response.json()
        self.token_expiry = time.time() + (token_data["expires_in"] - 60)
        logger.info("OAuth token acquired successfully.")
    def get_headers(self, scopes: str) -> dict:
        token = self._get_token()
            "Accept": "application/json",
            "X-Request-Id": str(time.time_ns()),
            "Scope": scopes
The Scope header explicitly declares the required OAuth scopes for each request. CXone validates scopes server-side and returns HTTP 403 when permissions are insufficient. The token caching mechanism prevents unnecessary network calls during batch operations.
Step 1: Construct and Validate the Close Payload
The CXone Web Messaging engine enforces strict schema constraints on session closure requests. The payload must include the session identifier, a satisfaction survey matrix, and a retention directive. Pydantic models enforce type safety and business rules such as maximum session duration limits.
from pydantic import BaseModel, Field, field_validator
class SatisfactionQuestion(BaseModel):
    question_id: str
    text: str
    type: str = Field(..., pattern="^(rating|text|multiple_choice)$")
    required: bool = False
class SatisfactionSurveyMatrix(BaseModel):
    enabled: bool = True
    questions: List[SatisfactionQuestion] = Field(..., min_length=1, max_length=5)
    timeout_seconds: int = Field(..., ge=10, le=300)
class CloseSessionPayload(BaseModel):
    session_id: str
    retention_directive: str = Field(..., pattern="^(keep_transcript|archive_only|purge_after_30d)$")
    satisfaction_survey: SatisfactionSurveyMatrix
    close_reason: Optional[str] = None
    metadata: dict = Field(default_factory=dict)
    @field_validator("session_id")
    @classmethod
    def validate_session_format(cls, v: str) -> str:
        if len(v) < 10 or len(v) > 64:
            raise ValueError("Session ID must be between 10 and 64 characters.")
        return v
    @field_validator("retention_directive")
    @classmethod
    def validate_retention_compliance(cls, v: str) -> str:
        if v == "purge_after_30d":
            logger.warning("Retention directive 'purge_after_30d' triggers automatic transcript deletion.")
        return v
class SessionDurationConstraint(BaseModel):
    max_duration_minutes: int = Field(default=120, ge=5, le=480)
    created_at: datetime
    @property
    def is_expired(self) -> bool:
        return datetime.utcnow() > self.created_at + timedelta(minutes=self.max_duration_minutes)
The CloseSessionPayload model guarantees that the JSON structure matches CXone messaging engine expectations. The retention directive controls transcript storage behavior, and the satisfaction survey matrix defines post-closure guest prompts. The SessionDurationConstraint class prevents closure attempts on sessions that have already exceeded engine limits, which would otherwise trigger HTTP 409 conflicts.
Step 2: Execute Atomic Session Closure with Transcript Finalization
Session termination requires an atomic POST operation to the CXone messaging endpoint. The request must include format verification and automatic transcript finalization triggers. The implementation includes exponential backoff for HTTP 429 rate limits and explicit error mapping for common failure codes.
from typing import Any
class CXoneMessagingClient:
    def __init__(self, auth: CXoneAuthClient, tenant: str):
        self.auth = auth
        self.base_url = f"https://{tenant}.cxone.com/api/v1/messaging/web"
    def _request_with_retry(self, method: str, path: str, payload: Optional[dict] = None, max_retries: int = 3) -> httpx.Response:
        url = f"{self.base_url}{path}"
        headers = self.auth.get_headers("messaging:write sessions:manage")
            response = self.http.request(method, url, json=payload, headers=headers)
                retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
                logger.warning("Rate limit hit (429). Retrying in %d seconds.", retry_after)
                time.sleep(retry_after)
                self.auth.access_token = None
            if response.status_code == 403:
                logger.error("Forbidden (403). Verify OAuth scopes: messaging:write, sessions:manage")
            if response.status_code >= 500:
                logger.error("Server error (%d). Retrying.", response.status_code)
                time.sleep(2 ** attempt)
            return response
        return response
    def close_session(self, payload: CloseSessionPayload) -> dict:
        path = f"/sessions/{payload.session_id}/close"
        json_body = payload.model_dump(mode="json")
        response = self._request_with_retry("POST", path, payload=json_body)
        return response.json()
The _request_with_retry method implements a circuit-breaker pattern for transient failures. HTTP 429 responses trigger exponential backoff using the Retry-After header when available. HTTP 401 responses invalidate the cached token and force a fresh OAuth exchange. The close_session method serializes the Pydantic model and dispatches the atomic POST request. CXone returns a closure confirmation object containing the final transcript URI and survey delivery status.
Step 3: Implement Pending Message Checks and External Synchronization
Closing a session with queued outbound messages causes data loss and violates compliance requirements. The implementation queries the message queue, verifies data completeness, and triggers external case system callbacks upon successful closure. Latency tracking and audit logging are integrated into the workflow.
import json
import uuid
class SessionClosurePipeline:
    def __init__(self, messaging_client: CXoneMessagingClient, external_webhook_url: str):
        self.messaging_client = messaging_client
        self.webhook_url = external_webhook_url
        self.http = httpx.Client(timeout=httpx.Timeout(15.0))
        self.audit_log = []
        self.success_count = 0
        self.failure_count = 0
        self.total_latency_ms = 0.0
    def _check_pending_messages(self, session_id: str) -> bool:
        path = f"/sessions/{session_id}/messages"
        headers = self.messaging_client.auth.get_headers("messaging:write")
        response = self.http.get(
            f"{self.messaging_client.base_url}{path}",
            headers=headers,
            params={"status": "pending", "limit": 1}
        messages = response.json().get("items", [])
        return len(messages) == 0
    def _sync_external_case(self, session_id: str, closure_result: dict) -> None:
        payload = {
            "event_type": "session_closed",
            "session_id": session_id,
            "transcript_uri": closure_result.get("transcript_uri"),
            "survey_delivered": closure_result.get("survey_delivered", False),
            "timestamp": datetime.utcnow().isoformat()
            self.http.post(self.webhook_url, json=payload, timeout=10.0)
            logger.info("External case system synchronized for session %s.", session_id)
        except httpx.RequestError as exc:
            logger.error("Webhook synchronization failed: %s", exc)
    def _write_audit_log(self, session_id: str, status: str, duration_ms: float, payload: dict) -> None:
        log_entry = {
            "audit_id": str(uuid.uuid4()),
            "status": status,
            "duration_ms": duration_ms,
            "payload_hash": hash(json.dumps(payload, sort_keys=True)),
            "logged_at": datetime.utcnow().isoformat()
        self.audit_log.append(log_entry)
        logger.info("Audit record created: %s", log_entry)
    def execute_closer(self, payload: CloseSessionPayload, constraint: SessionDurationConstraint) -> dict:
        session_id = payload.session_id
        if constraint.is_expired:
            raise ValueError(f"Session {session_id} exceeds maximum duration limit of {constraint.max_duration_minutes} minutes.")
        if not self._check_pending_messages(session_id):
            raise RuntimeError(f"Pending messages detected for session {session_id}. Closure blocked to prevent data loss.")
            closure_result = self.messaging_client.close_session(payload)
            elapsed_ms = (time.perf_counter() - start_time) * 1000
            self.success_count += 1
            self.total_latency_ms += elapsed_ms
            self._sync_external_case(session_id, closure_result)
            self._write_audit_log(session_id, "SUCCESS", elapsed_ms, payload.model_dump())
            return closure_result
        except Exception as exc:
            self.failure_count += 1
            self._write_audit_log(session_id, "FAILED", elapsed_ms, payload.model_dump())
            logger.error("Session closure failed: %s", exc)
            raise
The execute_closer method orchestrates the complete termination workflow. It validates session duration constraints, blocks closure when pending messages exist, and records precise latency metrics. The external synchronization handler dispatches a structured webhook payload to downstream case management systems. Audit logs capture payload hashes, execution timing, and status codes for compliance reviews.
import httpx
import logging
import json
import uuid
from typing import Optional, List
# --- Authentication Layer ---
        payload = {
            "Scope": scopes
# --- Schema Validation ---
    question_id: str
    text: str
    session_id: str
    @classmethod
        return v
    @classmethod
        return v
    @property
# --- Messaging Client ---
        self.auth = auth
    def _request_with_retry(self, method: str, path: str, payload: Optional[dict] = None, max_retries: int = 3):
            return response
        return response
    def close_session(self, payload: CloseSessionPayload):
# --- Closure Pipeline ---
        self.audit_log = []
            headers=headers,
        payload = {
        log_entry = {
            "status": status,
    def execute_closer(self, payload: CloseSessionPayload, constraint: SessionDurationConstraint):
            raise
    def get_metrics(self):
        avg_latency = self.total_latency_ms / total if total > 0 else 0.0
        success_rate = (self.success_count / total * 100) if total > 0 else 0.0
            "total_attempts": total,
            "success_count": self.success_count,
            "failure_count": self.failure_count,
            "success_rate_percent": round(success_rate, 2),
            "average_latency_ms": round(avg_latency, 2),
            "audit_records": len(self.audit_log)
# --- Execution Entry Point ---
    # Replace with actual CXone credentials
    TENANT = "your-tenant"
    CLIENT_ID = "your-client-id"
    CLIENT_SECRET = "your-client-secret"
    WEBHOOK_URL = "https://your-crm-system.example.com/api/v1/cxone-webhooks"
    auth = CXoneAuthClient(TENANT, CLIENT_ID, CLIENT_SECRET)
    messaging = CXoneMessagingClient(auth, TENANT)
    pipeline = SessionClosurePipeline(messaging, WEBHOOK_URL)
    survey_matrix = SatisfactionSurveyMatrix(
        enabled=True,
        questions=[
            SatisfactionQuestion(question_id="q1", text="How would you rate your experience?", type="rating", required=True),
            SatisfactionQuestion(question_id="q2", text="Additional comments", type="text", required=False)
        timeout_seconds=60
    close_payload = CloseSessionPayload(
        session_id="wm-session-8f3a2c1d-4b5e-6789-0123-456789abcdef",
        retention_directive="keep_transcript",
        satisfaction_survey=survey_matrix,
        close_reason="agent_initiated",
        metadata={"channel": "web", "department": "support"}
    duration_constraint = SessionDurationConstraint(
        max_duration_minutes=120,
        created_at=datetime.utcnow() - timedelta(minutes=45)
        result = pipeline.execute_closer(close_payload, duration_constraint)
        print("Closure Result:", json.dumps(result, indent=2))
        print("Pipeline Metrics:", json.dumps(pipeline.get_metrics(), indent=2))
        print("Execution terminated:", str(e))
Error: HTTP 403 Forbidden
  • Cause: The OAuth token lacks the required scopes or the client credentials are misconfigured.
  • Fix: Verify that the Scope header contains messaging:write sessions:manage. Regenerate client credentials in the CXone Admin Console under Platform > Authentication > OAuth.
  • Code showing the fix: The get_headers method explicitly sets the Scope header. If 403 persists, inspect the CXone audit log to confirm scope binding.
Error: HTTP 409 Conflict (Session Duration Exceeded)
  • Cause: The session age surpasses the messaging engine maximum duration limit.
  • Fix: Implement the SessionDurationConstraint validator before dispatching the POST request. The is_expired property blocks closure attempts that would trigger engine rejection.
  • Code showing the fix: The execute_closer method raises a ValueError when constraint.is_expired evaluates to true, preventing unnecessary network calls.
  • Cause: The application exceeds CXone rate limits for the messaging tenant.
  • Fix: The _request_with_retry method implements exponential backoff with Retry-After header parsing. Ensure batch operations respect the tenant throughput ceiling.
  • Code showing the fix: The retry loop sleeps for Retry-After seconds or falls back to 2 ** attempt seconds before reissuing the request.
Error: Pending Message Data Loss Warning
  • Cause: The messaging queue contains outbound messages that have not been delivered to the guest browser.
  • Fix: Query the messages endpoint with status=pending before closure. Block termination until the queue drains or the agent manually flushes the buffer.
  • Code showing the fix: The _check_pending_messages method returns false when len(messages) > 0, causing the pipeline to raise a RuntimeError.
