Cloning NICE Cognigy.AI Flow Templates via Flow API with Go
- A Go service that clones workflow templates by constructing replicate payloads with
template-ref,node-matrix, andreplicatedirectives. - An implementation that validates cloning schemas against
structure-constraintsandmaximum-node-copylimits, handlesid-generationandreference-mapping, and executes atomic HTTP POST operations. - A complete workflow cloner written in Go that includes circular-dependency checking, missing-resource verification, webhook synchronization, latency tracking, and audit logging.
- OAuth 2.0 Client Credentials flow configured in the Cognigy.AI/NICE CXone tenant
- Required OAuth scopes:
flow:templates:read,flow:templates:replicate,webhooks:manage - Go 1.21 or higher
- Standard library dependencies:
net/http,context,encoding/json,sync,sync/atomic,time,fmt,log,errors - Base API URL:
https://{tenant}.cognigy.ai/api/v1
The Cognigy.AI Flow API requires a bearer token obtained via the OAuth 2.0 client credentials grant. You must cache the token and refresh it before expiration to avoid 401 interruptions during batch cloning operations.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"net/http"
"time"
type OAuthConfig struct {
TenantID string
ClientID string
ClientSecret string
TokenEndpoint string
type TokenResponse struct {
ExpiresIn int64 `json:"expires_in"`
func FetchOAuthToken(ctx context.Context, cfg OAuthConfig) (TokenResponse, error) {
payload := map[string]string{
"client_id": cfg.ClientID,
"client_secret": cfg.ClientSecret,
jsonPayload, err := json.Marshal(payload)
if err != nil {
return TokenResponse{}, fmt.Errorf("failed to marshal oauth payload: %w", err)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, cfg.TokenEndpoint, bytes.NewBuffer(jsonPayload))
if err != nil {
return TokenResponse{}, fmt.Errorf("failed to create oauth request: %w", err)
resp, err := client.Do(req)
if err != nil {
return TokenResponse{}, fmt.Errorf("oauth request failed: %w", err)
defer resp.Body.Close()
return TokenResponse{}, fmt.Errorf("oauth returned status %d", resp.StatusCode)
var tokenResp TokenResponse
return TokenResponse{}, fmt.Errorf("failed to decode oauth response: %w", err)
return tokenResp, nil
The Flow API expects a structured JSON body containing the template-ref, node-matrix, and replicate directive. You must validate the payload against structure-constraints and enforce maximum-node-copy limits before submission. The id-generation and reference-mapping fields control how the API assigns new identifiers and updates internal node links.
package main
import (
"encoding/json"
"fmt"
type ReplicatePayload struct {
TemplateRef string `json:"template-ref"`
NodeMatrix map[string]interface{} `json:"node-matrix"`
Replicate ReplicateDirective `json:"replicate"`
StructureConstraints map[string]int `json:"structure-constraints"`
MaximumNodeCopy int `json:"maximum-node-copy"`
IDGeneration string `json:"id-generation"`
ReferenceMapping map[string]string `json:"reference-mapping"`
type ReplicateDirective struct {
Mode string `json:"mode"`
Scope string `json:"scope"`
Validate bool `json:"validate"`
func BuildReplicatePayload(templateID string, nodeMatrix map[string]interface{}, maxCopy int) (ReplicatePayload, error) {
if len(nodeMatrix) > maxCopy {
return ReplicatePayload{}, fmt.Errorf("node matrix size %d exceeds maximum-node-copy limit %d", len(nodeMatrix), maxCopy)
payload := ReplicatePayload{
TemplateRef: templateID,
NodeMatrix: nodeMatrix,
Replicate: ReplicateDirective{
Mode: "full",
Scope: "template",
Validate: true,
StructureConstraints: map[string]int{
"max_depth": 15,
"max_branching": 8,
"max_loops": 3,
MaximumNodeCopy: maxCopy,
IDGeneration: "sequential",
ReferenceMapping: map[string]string{
"parent_ref": "auto",
"child_ref": "auto",
// Verify JSON serialization matches API contract
_, err := json.Marshal(payload)
if err != nil {
return ReplicatePayload{}, fmt.Errorf("payload format verification failed: %w", err)
return payload, nil
Step 2: Circular Dependency and Missing Resource Verification
Workflow cloning fails silently or corrupts execution graphs if the source template contains circular references or references resources that do not exist in the target environment. You must run a validation pipeline before the HTTP POST. This step implements depth-first search for cycle detection and a registry lookup for missing resources.
package main
import (
"fmt"
type NodeEdge struct {
From string
To string
func DetectCircularDependencies(edges []NodeEdge) error {
adjacency := make(map[string][]string)
for _, e := range edges {
adjacency[e.From] = append(adjacency[e.From], e.To)
visited := make(map[string]bool)
inStack := make(map[string]bool)
var dfs func(node string) bool
dfs = func(node string) bool {
if inStack[node] {
return true
if visited[node] {
return false
visited[node] = true
inStack[node] = true
defer func() { inStack[node] = false }()
for _, neighbor := range adjacency[node] {
if dfs(neighbor) {
return true
return false
for node := range adjacency {
if dfs(node) {
return fmt.Errorf("circular dependency detected starting at node %s", node)
return nil
func VerifyMissingResources(nodeMatrix map[string]interface{}, resourceRegistry map[string]bool) error {
for nodeID, nodeData := range nodeMatrix {
if mapped, ok := nodeData.(map[string]interface{}); ok {
if resRef, exists := mapped["resource_ref"]; exists {
refStr, ok := resRef.(string)
if ok && !resourceRegistry[refStr] {
return fmt.Errorf("missing resource verification failed: node %s references unknown resource %s", nodeID, refStr)
return nil
Step 3: Atomic POST Execution with Retry and ID Generation
The Flow API enforces strict rate limits during template replication. You must implement exponential backoff with jitter for 429 responses. The endpoint returns a job ID that you can poll, or it returns the cloned template directly depending on the replicate.mode. This implementation handles the synchronous path with automatic retry logic.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"math/rand"
"net/http"
"time"
type FlowAPIClient struct {
BaseURL string
HTTPClient *http.Client
Token string
func (c *FlowAPIClient) ReplicateTemplate(ctx context.Context, payload ReplicatePayload) (map[string]interface{}, error) {
jsonBody, err := json.Marshal(payload)
if err != nil {
return nil, fmt.Errorf("failed to marshal replicate payload: %w", err)
endpoint := fmt.Sprintf("%s/flow/templates/replicate", c.BaseURL)
maxRetries := 3
baseDelay := 1 * time.Second
for attempt := 0; attempt <= maxRetries; attempt++ {
req, err := http.NewRequestWithContext(ctx, http.MethodPost, endpoint, bytes.NewBuffer(jsonBody))
if err != nil {
return nil, fmt.Errorf("failed to create request: %w", err)
req.Header.Set("Authorization", fmt.Sprintf("Bearer %s", c.Token))
resp, err := c.HTTPClient.Do(req)
if err != nil {
return nil, fmt.Errorf("request failed: %w", err)
switch resp.StatusCode {
case http.StatusOK:
var result map[string]interface{}
if err := json.NewDecoder(resp.Body).Decode(&result); err != nil {
return nil, fmt.Errorf("failed to decode success response: %w", err)
return result, nil
case http.StatusTooManyRequests:
if attempt == maxRetries {
return nil, fmt.Errorf("max retries exceeded for 429 response")
backoff := baseDelay * time.Duration(1<<uint(attempt))
jitter := time.Duration(rand.Intn(int(backoff) / 2))
time.Sleep(backoff + jitter)
case http.StatusBadRequest, http.StatusUnauthorized, http.StatusForbidden:
return nil, fmt.Errorf("api returned terminal error: %d", resp.StatusCode)
default:
return nil, fmt.Errorf("unexpected status code: %d", resp.StatusCode)
return nil, fmt.Errorf("replicate operation failed after retries")
Step 4: Webhook Synchronization and Metrics Collection
You must synchronize cloning events with external version control by emitting template created webhooks. You also need to track cloning latency and replicate success rates for operational governance. This step ties the validation, execution, and telemetry together into a single WorkflowCloner struct.
package main
import (
"context"
"encoding/json"
"fmt"
"net/http"
"sync"
"sync/atomic"
"time"
type WorkflowCloner struct {
APIClient *FlowAPIClient
WebhookURL string
AuditLog []map[string]interface{}
SuccessCount int64
FailureCount int64
TotalLatencyMs int64
mu sync.Mutex
func NewWorkflowCloner(client *FlowAPIClient, webhookURL string) *WorkflowCloner {
return &WorkflowCloner{
APIClient: client,
WebhookURL: webhookURL,
AuditLog: make([]map[string]interface{}, 0),
func (w *WorkflowCloner) CloneAndSync(ctx context.Context, payload ReplicatePayload) error {
startTime := time.Now()
// Execute atomic POST
result, err := w.APIClient.ReplicateTemplate(ctx, payload)
latency := time.Since(startTime).Milliseconds()
w.mu.Lock()
w.TotalLatencyMs += latency
w.AuditLog = append(w.AuditLog, map[string]interface{}{
"timestamp": time.Now().UTC().Format(time.RFC3339),
"template_ref": payload.TemplateRef,
"latency_ms": latency,
"max_node_copy": payload.MaximumNodeCopy,
"status": "pending",
w.mu.Unlock()
if err != nil {
atomic.AddInt64(&w.FailureCount, 1)
w.updateAuditStatus("failed", err.Error())
return fmt.Errorf("clone operation failed: %w", err)
atomic.AddInt64(&w.SuccessCount, 1)
w.updateAuditStatus("success", "replicated successfully")
// Synchronize with external version control via webhook
if err := w.emitTemplateCreatedWebhook(result); err != nil {
return fmt.Errorf("webhook synchronization failed: %w", err)
return nil
func (w *WorkflowCloner) updateAuditStatus(status, detail string) {
w.mu.Lock()
defer w.mu.Unlock()
if len(w.AuditLog) > 0 {
w.AuditLog[len(w.AuditLog)-1]["status"] = status
w.AuditLog[len(w.AuditLog)-1]["detail"] = detail
func (w *WorkflowCloner) emitTemplateCreatedWebhook(result map[string]interface{}) error {
payload, err := json.Marshal(map[string]interface{}{
"event": "template.created",
"payload": result,
"source": "flow-cloner-go",
"time": time.Now().UTC().Format(time.RFC3339),
if err != nil {
return err
req, err := http.NewRequest(http.MethodPost, w.WebhookURL, bytes.NewBuffer(payload))
if err != nil {
return err
if err != nil {
return err
if resp.StatusCode < 200 || resp.StatusCode >= 300 {
return fmt.Errorf("webhook returned status %d", resp.StatusCode)
return nil
func (w *WorkflowCloner) GetMetrics() map[string]interface{} {
total := atomic.LoadInt64(&w.SuccessCount) + atomic.LoadInt64(&w.FailureCount)
successRate := 0.0
if total > 0 {
successRate = float64(atomic.LoadInt64(&w.SuccessCount)) / float64(total)
avgLatency := 0.0
if total > 0 {
avgLatency = float64(w.TotalLatencyMs) / float64(total)
return map[string]interface{}{
"success_count": atomic.LoadInt64(&w.SuccessCount),
"failure_count": atomic.LoadInt64(&w.FailureCount),
"success_rate": successRate,
"avg_latency_ms": avgLatency,
The following script demonstrates the full cloning pipeline. Replace the placeholder credentials and tenant identifiers with your production values. The script validates constraints, checks for cycles and missing resources, executes the replicate call with retry logic, emits a webhook, and prints metrics and audit logs.
package main
import (
"context"
"fmt"
"log"
"net/http"
"time"
func main() {
ctx := context.Background()
// 1. Authentication
oauthCfg := OAuthConfig{
TenantID: "your-tenant-id",
ClientID: "your-client-id",
ClientSecret: "your-client-secret",
TokenEndpoint: "https://your-tenant.cognigy.ai/oauth/token",
token, err := FetchOAuthToken(ctx, oauthCfg)
if err != nil {
log.Fatalf("oauth failed: %v", err)
// 2. Client Initialization
apiClient := &FlowAPIClient{
BaseURL: "https://your-tenant.cognigy.ai/api/v1",
HTTPClient: &http.Client{Timeout: 30 * time.Second},
Token: token.AccessToken,
cloner := NewWorkflowCloner(apiClient, "https://your-vcs-webhook-endpoint.com/events")
// 3. Payload Construction
nodeMatrix := map[string]interface{}{
"node_start": map[string]interface{}{
"type": "entry",
"resource_ref": "sys:entry",
"transitions": []string{"node_greeting"},
"node_greeting": map[string]interface{}{
"type": "dialog",
"resource_ref": "res:dialog_01",
"transitions": []string{"node_end"},
"node_end": map[string]interface{}{
"type": "exit",
"transitions": []string{},
// Extract edges for cycle validation
var edges []NodeEdge
for id, data := range nodeMatrix {
if m, ok := data.(map[string]interface{}); ok {
if trans, exists := m["transitions"]; exists {
for _, t := range trans.([]string) {
edges = append(edges, NodeEdge{From: id, To: t})
// 4. Validation Pipeline
if err := DetectCircularDependencies(edges); err != nil {
log.Fatalf("validation failed: %v", err)
resourceRegistry := map[string]bool{
"sys:entry": true,
"res:dialog_01": true,
if err := VerifyMissingResources(nodeMatrix, resourceRegistry); err != nil {
payload, err := BuildReplicatePayload("tpl_prod_v2", nodeMatrix, 50)
if err != nil {
log.Fatalf("payload build failed: %v", err)
// 5. Execution & Synchronization
if err := cloner.CloneAndSync(ctx, payload); err != nil {
log.Fatalf("clone operation failed: %v", err)
// 6. Output Metrics and Audit
fmt.Println("=== Cloning Metrics ===")
for k, v := range cloner.GetMetrics() {
fmt.Printf("%s: %v\n", k, v)
fmt.Println("\n=== Audit Log ===")
for _, entry := range cloner.AuditLog {
fmt.Println(entry)
Error: 400 Bad Request - Structure Constraints Violated
- Cause: The
node-matrixexceedsmaximum-node-copy, or the graph violatesstructure-constraintssuch asmax_depthormax_branching. - Fix: Adjust the
maximum-node-copyinteger in the payload to match your template size. Verify that your node graph does not exceed the declared structural limits. - Code showing the fix:
// Increase limit if validation passes but API rejects
payload.MaximumNodeCopy = 100
payload.StructureConstraints["max_depth"] = 20
Error: 401 Unauthorized - Token Expired
- Cause: The OAuth token expired during a long-running cloning batch.
- Fix: Implement a token refresh wrapper that checks
token.ExpiresInand re-authenticates before the next batch. - Code showing the fix:
if time.Now().Add(2 * time.Minute).After(tokenExpirationTime) {
newToken, _ := FetchOAuthToken(ctx, oauthCfg)
apiClient.Token = newToken.AccessToken
Error: 429 Too Many Requests - Rate Limit Cascade
- Cause: The Flow API enforces per-tenant rate limits during bulk replication.
- Fix: The
ReplicateTemplatemethod already implements exponential backoff with jitter. EnsuremaxRetriesis sufficient for your batch size. - Code showing the fix:
// Already implemented in ReplicateTemplate switch case
// Adjust baseDelay or maxRetries in FlowAPIClient if needed
Error: Circular Dependency Detected
- Cause: The
node-matrixcontains a transition loop (A → B → A). - Fix: Remove or break the cycle in the source template before serialization. The
DetectCircularDependenciesfunction will halt execution before the HTTP call. - Code showing the fix:
// Edit nodeMatrix to remove the back-edge
delete(nodeMatrix["node_b"].([]interface{}), "transitions_back_to_a")
