Cloning Cognigy.AI Bot Flow Definitions via REST APIs with Python
- A Python module that clones bot flow definitions using the Cognigy.AI REST API, remaps node references, validates graph constraints, detects circular dependencies, verifies variable scopes, and executes atomic creation requests.
- Uses Cognigy.AI v1 REST API endpoints for flow retrieval, validation, and provisioning.
- Covers Python 3.9+ with
requests,httpx, and standard library modules for metrics tracking, audit logging, and webhook synchronization.
- OAuth client credentials configured in Cognigy.AI with
flow:readandflow:writescopes - Cognigy.AI v1 API access enabled for your tenant
- Python 3.9 or higher
- External dependencies:
pip install requests httpx pydantic
Cognigy.AI uses OAuth 2.0 client credentials grant for programmatic access. The following implementation caches the access token and handles expiration gracefully.
import requests
import threading
from typing import Optional
class CognigyAuth:
def __init__(self, tenant: str, client_id: str, client_secret: str):
self.base_url = f"https://{tenant}.cognigy.ai/api/v1"
self.client_id = client_id
self.expires_at: float = 0.0
self.lock = threading.Lock()
def _fetch_token(self) -> str:
payload = {
"client_id": self.client_id,
response = requests.post(f"{self.base_url}/oauth/token", json=payload)
response.raise_for_status()
data = response.json()
return data["access_token"], data.get("expires_in", 3600)
def get_token(self) -> str:
with self.lock:
if self.token and time.time() < self.expires_at:
return self.token
token, expires_in = self._fetch_token()
self.token = token
self.expires_at = time.time() + expires_in - 60
return self.token
"Authorization": f"Bearer {self.get_token()}",
Step 1: Fetch Source Flow and Construct Clone Payload
The cloning process begins by retrieving the source flow definition. You must remap all internal identifiers to prevent UUID collisions in the target environment. The payload requires a complete node matrix, remapped edge references, and a duplicateDirective marker for audit tracking.
import uuid
import copy
import requests
from typing import Dict, Any
class FlowCloner:
def __init__(self, auth: CognigyAuth):
self.auth = auth
self.base_url = auth.base_url
def fetch_flow(self, flow_id: str) -> Dict[str, Any]:
response = requests.get(
f"{self.base_url}/flows/{flow_id}",
headers=self.auth.get_headers()
return response.json()
def construct_clone_payload(self, source_flow: Dict[str, Any], new_name: str) -> Dict[str, Any]:
# Deep copy to avoid mutating the source reference
payload = copy.deepcopy(source_flow)
payload["id"] = str(uuid.uuid4())
payload["name"] = new_name
payload["version"] = 0
payload["duplicateDirective"] = "cloned_via_api"
# Remap node and edge identifiers
id_mapping = {}
for node in payload.get("nodes", []):
old_id = node["id"]
new_id = str(uuid.uuid4())
id_mapping[old_id] = new_id
node["id"] = new_id
for edge in payload.get("edges", []):
if edge.get("from") in id_mapping:
edge["from"] = id_mapping[edge["from"]]
if edge.get("to") in id_mapping:
edge["to"] = id_mapping[edge["to"]]
return payload
Step 2: Validate Schema and Graph Constraints
Before submission, you must validate the payload against Cognigy.AI graph engine constraints. This includes enforcing maximum node counts, detecting circular dependencies via depth-first search, and verifying variable scope definitions against node configurations.
from collections import defaultdict
from typing import List, Tuple
class FlowValidator:
MAX_NODE_COUNT = 500
@staticmethod
def validate_node_count(payload: Dict[str, Any]) -> bool:
node_count = len(payload.get("nodes", []))
if node_count > FlowValidator.MAX_NODE_COUNT:
raise ValueError(f"Node count {node_count} exceeds maximum limit of {FlowValidator.MAX_NODE_COUNT}")
return True
@staticmethod
def detect_circular_dependencies(payload: Dict[str, Any]) -> bool:
graph = defaultdict(list)
nodes = {n["id"] for n in payload.get("nodes", [])}
if edge.get("from") in nodes and edge.get("to") in nodes:
graph[edge["from"]].append(edge["to"])
visited = set()
rec_stack = set()
def dfs(node: str) -> bool:
visited.add(node)
rec_stack.add(node)
for neighbor in graph[node]:
if neighbor not in visited:
if dfs(neighbor):
return True
elif neighbor in rec_stack:
return True
rec_stack.discard(node)
return False
for node in nodes:
if node not in visited:
if dfs(node):
raise ValueError("Circular dependency detected in flow graph")
return True
@staticmethod
def verify_variable_scope(payload: Dict[str, Any]) -> bool:
defined_vars = {v["name"] for v in payload.get("variables", [])}
config = node.get("config", {})
# Cognigy nodes reference variables via ${variableName} or direct config keys
if "variable" in config and config["variable"] not in defined_vars:
raise ValueError(f"Undefined variable reference: {config['variable']} in node {node['id']}")
return True
Step 3: Execute Atomic Clone POST and Handle Reference Resolution
Cognigy.AI requires the complete flow definition in a single atomic POST operation. The following implementation includes exponential backoff for 429 rate limits, format verification, and automatic retry logic.
import httpx
class FlowDeployer:
self.auth = auth
self.client = httpx.Client(timeout=30.0)
def deploy_clone(self, payload: Dict[str, Any], max_retries: int = 3) -> Dict[str, Any]:
url = f"{self.base_url}/flows"
headers = self.auth.get_headers()
response = self.client.post(url, json=payload, headers=headers)
if response.status_code == 200 or response.status_code == 201:
elif response.status_code == 429:
retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
time.sleep(retry_after)
elif response.status_code == 400:
raise ValueError(f"Payload validation failed: {response.text}")
elif response.status_code == 409:
raise ConflictError(f"Flow conflict: {response.text}")
else:
raise RuntimeError("Maximum retry attempts exceeded for 429 rate limiting")
class ConflictError(Exception):
pass
Step 4: Verify Clone and Synchronize with External Version Control
After successful deployment, you must trigger external version control webhooks, calculate cloning latency, update success metrics, and generate structured audit logs for governance compliance.
import json
import logging
class CloneOrchestrator:
def __init__(self, auth: CognigyAuth, webhook_url: str):
self.auth = auth
self.cloner = FlowCloner(auth)
self.validator = FlowValidator()
self.deployer = FlowDeployer(auth)
self.success_count = 0
self.total_attempts = 0
self.latency_log: List[float] = []
self.audit_log = logging.getLogger("clone_audit")
self.audit_log.setLevel(logging.INFO)
handler = logging.StreamHandler()
handler.setFormatter(logging.JSONFormatter())
self.audit_log.addHandler(handler)
def clone_flow(self, source_id: str, new_name: str) -> Dict[str, Any]:
self.total_attempts += 1
# Step 1: Fetch and construct
source_flow = self.cloner.fetch_flow(source_id)
payload = self.cloner.construct_clone_payload(source_flow, new_name)
# Step 2: Validate
self.validator.validate_node_count(payload)
self.validator.detect_circular_dependencies(payload)
self.validator.verify_variable_scope(payload)
# Step 3: Deploy
result = self.deployer.deploy_clone(payload)
# Step 4: Metrics and Webhook
latency = time.perf_counter() - start_time
self.latency_log.append(latency)
self.success_count += 1
self._trigger_webhook(result, latency)
self._write_audit_log(source_id, result["id"], latency, "SUCCESS")
return result
self._write_audit_log(source_id, None, latency, "FAILURE", str(e))
raise
def _trigger_webhook(self, flow_data: Dict[str, Any], latency: float) -> None:
payload = {
"event": "flow_cloned",
"flow_id": flow_data["id"],
"flow_name": flow_data["name"],
"latency_ms": round(latency * 1000, 2),
"timestamp": datetime.now(timezone.utc).isoformat()
httpx.post(self.webhook_url, json=payload, timeout=10.0)
def _write_audit_log(self, source_id: str, target_id: Optional[str], latency: float, status: str, error: str = None) -> None:
self.audit_log.info({
"event": "flow_clone_attempt",
"source_id": source_id,
"target_id": target_id,
"status": status,
"success_rate": f"{self.success_count}/{self.total_attempts}",
"error": error
def get_metrics(self) -> Dict[str, float]:
avg_latency = sum(self.latency_log) / len(self.latency_log) if self.latency_log else 0.0
"total_clones": self.total_attempts,
"successful_clones": self.success_count,
"success_rate": self.success_count / self.total_attempts if self.total_attempts > 0 else 0.0,
"average_latency_ms": round(avg_latency * 1000, 2)
The following script combines all components into a single executable module. Replace the placeholder credentials and webhook URL before execution.
import sys
import json
def main():
# Configuration
TENANT = "your-tenant"
CLIENT_ID = "your-client-id"
CLIENT_SECRET = "your-client-secret"
SOURCE_FLOW_ID = "5f9a8b7c6d5e4f3a2b1c0d9e"
NEW_FLOW_NAME = "Production-Clone-Flow-v2"
WEBHOOK_URL = "https://your-vcs-webhook.example.com/api/flows/sync"
# Initialize components
auth = CognigyAuth(TENANT, CLIENT_ID, CLIENT_SECRET)
orchestrator = CloneOrchestrator(auth, WEBHOOK_URL)
print("Initiating flow cloning process...")
result = orchestrator.clone_flow(SOURCE_FLOW_ID, NEW_FLOW_NAME)
print(f"Clone successful. New Flow ID: {result['id']}")
print(f"Metrics: {json.dumps(orchestrator.get_metrics(), indent=2)}")
except ValueError as ve:
print(f"Validation Error: {ve}")
sys.exit(1)
except ConflictError as ce:
print(f"Conflict Error: {ce}")
sys.exit(2)
print(f"Unexpected Error: {e}")
sys.exit(3)
main()
Common Errors and Debugging
Error: 400 Bad Request
- What causes it: The payload violates Cognigy.AI schema validation. Common triggers include missing
startNode, invalid node types, or undefined variable references. - How to fix it: Verify the
verify_variable_scopeoutput matches your flow configuration. Ensure all nodes contain requiredtypeandconfigfields. - Code showing the fix:
# Add explicit schema check before deployment
if "startNode" not in payload or not payload["startNode"]:
raise ValueError("Payload missing startNode identifier")
Error: 409 Conflict
- What causes it: A flow with the same name or identifier already exists in the target environment, or the graph engine detects overlapping resource locks.
- How to fix it: Append a timestamp or unique suffix to the
new_nameparameter. EnsureduplicateDirectivedoes not trigger webhook deduplication rules. - Code showing the fix:
import datetime
new_name = f"{base_name}_{datetime.datetime.now().strftime('%Y%m%d_%H%M%S')}"
- What causes it: Cognigy.AI enforces strict rate limits on flow creation endpoints. Rapid cloning attempts trigger backpressure.
- How to fix it: The
FlowDeployerclass implements exponential backoff. Increasemax_retriesor add a fixed delay between bulk operations. - Code showing the fix:
# In deploy_clone loop
- What causes it: Graph engine constraints are violated during serialization, typically due to malformed edge references or unsupported node configurations.
- How to fix it: Validate edge
fromandtoreferences exist in the node matrix before POST. Ensure all node IDs are valid UUIDs. - Code showing the fix:
# Pre-flight reference verification
node_ids = {n["id"] for n in payload["nodes"]}
for edge in payload["edges"]:
if edge["from"] not in node_ids or edge["to"] not in node_ids:
raise ValueError(f"Orphaned edge reference: {edge}")
