Writing a cron job to pull conversation analytics data. Docs say: “Use client credentials for server-to-server communication.”
Trying auth code flow:
POST /oauth/token
grant_type=authorization_code
Getting 401. Should I just switch to client credentials since there’s no user session?
Switch to client credentials. It’s the only sane way for headless scripts. You don’t need a user context for analytics. Just grab the token with your app’s ID and secret. Watch out for scope creep though. If you request admin:analytics:read but forget read:reports, the call will fail silently or throw a 403.
curl -X POST "https://api.mypurecloud.com/oauth/token" \
-H "Authorization: Basic base64(client_id:client_secret)" \
-H "Content-Type: application/x-www-form-urlencoded" \
-d "grant_type=client_credentials&scope=analytics:report:read"
