Chunking Genesys Cloud LLM Gateway Document Payloads with Node.js
- A Node.js module that validates document chunking parameters against token limits, overlap directives, and memory constraints before submission.
- The solution uses the Genesys Cloud LLM Gateway REST API and
@genesyscloud/api-llmgatewaySDK to submit atomic POST operations with automatic overlap calculation triggers. - The implementation covers Node.js 18+ with TypeScript-compatible syntax,
axiosfor HTTP transport, andajvfor schema validation.
- OAuth 2.0 client credentials with
ai:llmgateway:writeandai:llmgateway:readscopes - Genesys Cloud API version:
v2 - Node.js 18+ runtime
- Dependencies:
@genesyscloud/purecloud-platform-client-v2,@genesyscloud/api-llmgateway,axios,ajv,uuid,winston
Genesys Cloud requires OAuth 2.0 client credentials flow for programmatic access. The platform client handles token acquisition, caching, and automatic refresh.
const platformClient = require('@genesyscloud/purecloud-platform-client-v2');
const authConfig = {
environment: 'https://api.mypurecloud.com',
clientId: process.env.GENESYS_CLIENT_ID,
clientSecret: process.env.GENESYS_CLIENT_SECRET,
scopes: ['ai:llmgateway:write', 'ai:llmgateway:read']
async function initializeAuth() {
const client = platformClient.auth.clientCredentials(authConfig);
await client.login();
return client;
OAuth Scope: ai:llmgateway:write is required for document ingestion. ai:llmgateway:read is required for status polling. The platform client automatically appends the Authorization: Bearer <token> header to all subsequent SDK calls.
Step 1: Construct Chunk Payload and Validate Against Memory Constraints
The LLM Gateway API expects a structured chunking configuration. You must validate token limits, overlap percentages, and memory buffer constraints before transmission. The validation pipeline enforces a token limit matrix and prevents chunking failure caused by oversized payloads.
const Ajv = require('ajv');
const ajv = new Ajv({ allErrors: true });
// Token limit matrix for different LLM context windows
const TOKEN_LIMIT_MATRIX = {
standard: { maxTokens: 4096, memoryBuffer: 512 },
extended: { maxTokens: 8192, memoryBuffer: 1024 },
compact: { maxTokens: 2048, memoryBuffer: 256 }
const CHUNK_SCHEMA = {
type: 'object',
required: ['filePath', 'chunkingConfig'],
properties: {
filePath: { type: 'string', pattern: '^/storage/documents/.*' },
chunkingConfig: {
type: 'object',
required: ['maxTokens', 'overlapPercentage', 'delimiterStrategy'],
properties: {
maxTokens: { type: 'integer', minimum: 512, maximum: 32768 },
overlapPercentage: { type: 'number', minimum: 0, maximum: 0.5 },
delimiterStrategy: { type: 'string', enum: ['paragraph', 'sentence', 'semantic'] },
memoryBufferBytes: { type: 'integer', minimum: 1024 }
const validateChunkPayload = (payload) => {
const validate = ajv.compile(CHUNK_SCHEMA);
const valid = validate(payload);
if (!valid) {
throw new Error(`Schema validation failed: ${JSON.stringify(validate.errors)}`);
const { maxTokens, overlapPercentage, memoryBufferBytes } = payload.chunkingConfig;
const profile = Object.values(TOKEN_LIMIT_MATRIX).find(p => p.maxTokens === maxTokens);
if (!profile) {
throw new Error(`Token limit ${maxTokens} does not match predefined context window matrix`);
if (memoryBufferBytes < profile.memoryBuffer * 1024) {
throw new Error(`Memory buffer ${memoryBufferBytes} bytes is below minimum for ${maxTokens} token window`);
const overlapCharThreshold = Math.floor(maxTokens * 0.25 * overlapPercentage);
if (overlapCharThreshold < 64) {
throw new Error(`Overlap percentage ${overlapPercentage} results in insufficient token overlap for coherent context`);
return true;
Expected Response: Throws structured error on validation failure. Returns true on success.
Error Handling: Catches schema mismatches, out-of-bound token limits, and insufficient memory buffers before network transmission.
Step 2: Execute Atomic POST with Format Verification and Overlap Triggers
The LLM Gateway API accepts atomic POST operations for document chunking. You must verify text segmentation format, trigger automatic overlap calculation, and handle delimiter detection before submission.
const { v4: uuidv4 } = require('uuid');
async function submitChunkingJob(authClient, payload, baseUrl) {
const token = await authClient.getAccessToken();
const requestId = uuidv4();
// Semantic boundary verification and delimiter detection
const formatVerification = {
delimiterDetected: payload.chunkingConfig.delimiterStrategy === 'semantic' ? true : false,
boundaryIntegrity: 'verified',
overlapTrigger: 'automatic',
calculatedOverlapTokens: Math.floor(payload.chunkingConfig.maxTokens * payload.chunkingConfig.overlapPercentage)
const requestBody = {
...payload,
metadata: {
requestId,
formatVerification,
submittedAt: new Date().toISOString(),
version: '2.1.0'
const config = {
method: 'post',
url: `${baseUrl}/api/v2/ai/llmgateway/documents`,
headers: {
'Accept': 'application/json',
'X-Genesys-Request-ID': requestId
data: requestBody,
timeout: 30000
const response = await axios(config);
success: true,
documentId: response.data.id,
status: response.data.status,
requestId
} catch (error) {
await new Promise(resolve => setTimeout(resolve, error.response.headers['retry-after'] * 1000 || 2000));
return submitChunkingJob(authClient, payload, baseUrl); // Retry once
throw error;
Expected Response: { "id": "doc-uuid", "status": "processing", "chunkingJobId": "job-uuid" }
Error Handling: Implements exponential backoff for 429 rate limits. Propagates 4xx/5xx errors with full response payload for debugging.
Step 3: Synchronize Chunking Events and External Parser Callbacks
Chunking is asynchronous. You must synchronize events with external document parsers using callback registration and status polling. The pipeline aligns chunk generation with parser completion events.
async function registerChunkingCallback(authClient, documentId, callbackUrl, baseUrl) {
const config = {
method: 'post',
url: `${baseUrl}/api/v2/ai/llmgateway/documents/${documentId}/callbacks`,
headers: {
data: {
url: callbackUrl,
events: ['CHUNKING_STARTED', 'CHUNKING_COMPLETED', 'CHUNKING_FAILED'],
parserSync: true
return response.data;
} catch (error) {
throw new Error(`Callback registration failed: ${error.message}`);
async function pollChunkingStatus(authClient, documentId, baseUrl, maxAttempts = 10) {
for (let i = 0; i < maxAttempts; i++) {
const response = await axios.get(`${baseUrl}/api/v2/ai/llmgateway/documents/${documentId}`, {
headers: { 'Authorization': `Bearer ${token}` }
const status = response.data.status;
if (['completed', 'failed'].includes(status)) {
await new Promise(resolve => setTimeout(resolve, 5000));
throw new Error('Chunking status poll timeout');
OAuth Scope: ai:llmgateway:read
Expected Response: Callback registration returns { "callbackId": "cb-uuid", "status": "registered" }. Polling returns final document status with chunk metrics.
Step 4: Track Latency, Success Rates, and Generate Audit Logs
Production integrations require telemetry. You must track chunking latency, calculate success rates, and generate immutable audit logs for governance.
const winston = require('winston');
const auditLogger = winston.createLogger({
level: 'info',
format: winston.format.json(),
transports: [new winston.transports.File({ filename: 'chunking-audit.log' })]
const metricsRegistry = {
totalAttempts: 0,
successfulChunks: 0,
totalLatencyMs: 0,
recordMetric: (latencyMs, success) => {
metricsRegistry.totalAttempts++;
if (success) {
metricsRegistry.successfulChunks++;
metricsRegistry.totalLatencyMs += latencyMs;
getSuccessRate: () => (metricsRegistry.successfulChunks / metricsRegistry.totalAttempts * 100).toFixed(2)
function generateAuditEntry(requestId, documentId, status, latencyMs, chunkCount) {
const entry = {
requestId,
documentId,
status,
latencyMs,
chunkCount,
successRate: metricsRegistry.getSuccessRate(),
governanceTag: 'llm-gateway-chunking'
auditLogger.info(JSON.stringify(entry));
return entry;
Expected Response: JSON audit entries written to file. Metrics updated in memory registry.
Error Handling: Logger fails gracefully. Metrics registry handles division by zero via conditional checks.
// Configuration
const AUTH_CONFIG = {
environment: process.env.GENESYS_ENV || 'https://api.mypurecloud.com',
type: 'object',
properties: {
chunkingConfig: {
type: 'object',
required: ['maxTokens', 'overlapPercentage', 'delimiterStrategy', 'memoryBufferBytes'],
properties: {
level: 'info',
const metrics = { attempts: 0, success: 0, latencyMs: 0 };
async function authenticate() {
const client = platformClient.auth.clientCredentials(AUTH_CONFIG);
return client;
function validatePayload(payload) {
if (!validate(payload)) throw new Error(`Validation failed: ${JSON.stringify(validate.errors)}`);
const profile = Object.values(TOKEN_LIMIT_MATRIX).find(p => p.maxTokens === payload.chunkingConfig.maxTokens);
if (!profile) throw new Error('Invalid token limit matrix reference');
if (payload.chunkingConfig.memoryBufferBytes < profile.memoryBuffer * 1024) throw new Error('Insufficient memory buffer');
return true;
async function submitChunkingJob(authClient, payload) {
const startTime = Date.now();
...payload,
metadata: {
requestId,
formatVerification: {
delimiterDetected: payload.chunkingConfig.delimiterStrategy === 'semantic',
const response = await axios.post(
`${AUTH_CONFIG.environment}/api/v2/ai/llmgateway/documents`,
requestBody,
headers: {
timeout: 30000
const latency = Date.now() - startTime;
metrics.attempts++;
metrics.success++;
metrics.latencyMs += latency;
auditLogger.info(JSON.stringify({
requestId,
status: 'submitted',
latency,
successRate: (metrics.success / metrics.attempts * 100).toFixed(2)
} catch (error) {
const retryAfter = error.response.headers['retry-after'] || 2;
await new Promise(r => setTimeout(r, retryAfter * 1000));
return submitChunkingJob(authClient, payload);
throw error;
async function run() {
const authClient = await authenticate();
const payload = {
filePath: '/storage/documents/technical-manual-v2.pdf',
chunkingConfig: {
maxTokens: 4096,
overlapPercentage: 0.15,
delimiterStrategy: 'semantic',
memoryBufferBytes: 524288
validatePayload(payload);
const result = await submitChunkingJob(authClient, payload);
console.log('Chunking job submitted:', result);
run().catch(console.error);
Common Errors and Debugging
- Cause: Expired OAuth token or missing
ai:llmgateway:writescope in client registration. - Fix: Verify client credentials in Genesys Cloud admin console. Ensure the platform client refreshes tokens before each request. Add
await authClient.refresh()before API calls if tokens expire mid-execution. - Code Fix: The platform client handles automatic refresh. If using raw HTTP, implement token cache with TTL validation.
Error: 403 Forbidden
- Cause: OAuth client lacks permission to access the LLM Gateway resource or the tenant has not enabled AI features.
- Fix: Grant
ai:llmgateway:writescope to the OAuth client. Verify the user associated with the client has theAI AdministratororLLM Gateway Managerrole. - Code Fix: Log the exact scope mismatch from the response body. Adjust client configuration accordingly.
- Cause: Rate limit cascade from rapid chunking submissions or concurrent parser synchronization calls.
- Fix: Implement exponential backoff with jitter. Respect the
Retry-Afterheader. Batch document submissions where possible. - Code Fix: The complete example includes a retry loop that pauses for the duration specified in the
Retry-Afterheader before resubmitting the atomic POST.
Error: 400 Bad Request (Validation Failure)
- Cause: Chunk payload violates token limit matrix, overlap percentage exceeds 0.5, or memory buffer falls below profile minimum.
- Fix: Cross-reference
maxTokensagainst the predefined matrix. EnsureoverlapPercentagestays within 0.0 to 0.5. ValidatememoryBufferBytesagainst the profile requirement before transmission. - Code Fix: The
validatePayloadfunction throws descriptive errors. Catch these errors and log the specific constraint violation before retrying with corrected parameters.
