Hi all,
In routing strategy
Could you help me how to check for if agents extension, ACD positions are logged in or not
like SData[‘[email removed]’,‘StatAgentsTotal’] > 0 checks for if agents are logged in or not.
Thanks in advance
Hi all,
In routing strategy
Thanks in advance
It should be possible to check if agent is logged/available on particular place using SData[‘……@….AP’,‘……’].
Rene,
SData['......@....AP','......'].
above place id represents single place Id right? what if i want to check all agents extensions in the call center?
If I create a place in CME with allagents extensions and use it as a group to check will that work?
Thanks for the update
You can create group of places and use this object in SData function (SData[‘……@….GP’,‘……’]).
Just curious - why do you need to check all places?
