Channel SIPServer connection failed, Interaction workspace 8.1
Hi all,
I am attempting to deploy Interaction Workspace 8.1 in our test lab however have come across message when attempting to login :
The IWS application has a connection to sipserver, stat server and message server.
The security.disable-rbac configuration option in the interaction-workspace section is set to true.
The User have a Full control permission on all object (in Environment and Resources Tenant).
the IWS log file shows this error :
13-03-04 12:28:55.056 [ 1] DEBUG ocolInstance.Channel - State transition from Closed to Opening for SIPServer - tcp://w2k8r2gen8adm:7005
13-03-04 12:28:55.056 [ 1] DEBUG ocolInstance.Channel - Channel state transition: Closed->Opening for SIPServer - tcp://w2k8r2gen8adm:7005
13-03-04 12:28:55.058 [ 1] DEBUG ocolInstance.Channel - Opening channel SIPServer - tcp://w2k8r2gen8adm:7005 …
13-03-04 12:28:55.062 [ 1] DEBUG Channel.HAConnection - Transition from ‘.StateAbsent proxy: proxy1’ to '.StateOpening proxy: proxy1
13-03-04 12:28:55.066 [ 1] DEBUG .HAConnection.proxy1 - Setting connection: tcp://w2k8r2gen8adm:7005
13-03-04 12:28:55.067 [ 1] DEBUG xy1.CommonConnection - method ConnectionBase.Configure() called
13-03-04 12:28:55.067 [ 1] DEBUG xy1.CommonConnection - IConnectionConfiguration parsing…
13-03-04 12:28:55.067 [ 1] DEBUG xy1.CommonConnection - LocalHost=10.162.119.5, LocalPort=7005
13-03-04 12:28:55.067 [ 1] DEBUG xy1.CommonConnection - Blocking mode is set to ‘False’
13-03-04 12:28:55.067 [ 1] DEBUG ion.TlsClientSupport - TLS disabled
13-03-04 12:28:55.067 [ 1] DEBUG xy1.CommonConnection - IConnectionConfiguration was parsed successfully.
13-03-04 12:28:55.068 [ 1] DEBUG xy1.CommonConnection - Connecting to tcp://w2k8r2gen8adm:7005 …
13-03-04 12:28:55.069 [ 1] DEBUG xy1.CommonConnection - Socket#1940: Try to bind to 10.162.119.5:7005
13-03-04 12:28:55.070 [ 1] WARN xy1.CommonConnection - Exception ‘An attempt was made to access a socket in a way forbidden by its access permissions’ occured while trying to connect to tcp://w2k8r2gen8adm:7005
13-03-04 12:28:55.075 [ 1] DEBUG xy1.CommonConnection - tcp://w2k8r2gen8adm:7005 connection is firing ‘Closed’ event with exception System.Net.Sockets.SocketException: An attempt was made to access a socket in a way forbidden by its access permissions
at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.Sockets.Socket.Bind(EndPoint localEP)
at Genesyslab.Platform.Commons.Connection.CommonConnection.ConnectSocket(String server, Int32 port)
at Genesyslab.Platform.Commons.Connection.CommonConnection.DoOpen(Object param)
13-03-04 12:28:55.077 [ 1] DEBUG Channel.HAConnection - tcp://w2k8r2gen8adm:7005 connection is firing ‘Closed’ event with exception System.Net.Sockets.SocketException: An attempt was made to access a socket in a way forbidden by its access permissions
13-03-04 12:28:55.080 [ 1] DEBUG ocolInstance.Channel - Handling SIPServer - tcp://w2k8r2gen8adm:7005 connection closed…
13-03-04 12:28:55.080 [ 1] DEBUG ocolInstance.Channel - Completed handling SIPServer - tcp://w2k8r2gen8adm:7005 connection closed
13-03-04 12:28:55.080 [ 1] DEBUG Channel.HAConnection - tcp://w2k8r2gen8adm:7005 connection is done firing ‘Closed’ event.
13-03-04 12:28:55.080 [ 1] DEBUG Channel.HAConnection - Transition from ‘.StateOpening proxy: proxy1’ to '.StateAbsent proxy: proxy1
13-03-04 12:28:55.081 [ 1] DEBUG xy1.CommonConnection - tcp://w2k8r2gen8adm:7005 connection is done firing ‘Closed’ event.
13-03-04 12:28:55.081 [ 1] DEBUG ocolInstance.Channel - State transition from Opening to Closed for SIPServer - tcp://w2k8r2gen8adm:7005
13-03-04 12:28:55.081 [ 1] DEBUG ocolInstance.Channel - Channel state transition: Opening->Closed for SIPServer - tcp://w2k8r2gen8adm:7005
13-03-04 12:28:55.082 [ 1] DEBUG ocolInstance.Channel - SIPServer - tcp://w2k8r2gen8adm:7005 channel is firing ‘Closed’ event…
13-03-04 12:28:55.085 [ 8] DEBUG r.WarmStandbyService - OnChannelClosed(…) SIPServer - tcp://w2k8r2gen8adm:7005 invoked…
13-03-04 12:28:55.088 [ 1] ERROR Workspace.Core.Agent - Expception in InitializeMedia(voice)
Genesyslab.Enterprise.Exceptions.Channel.ChannelException: Channel ‘SIPServer’ connection has failed —> Genesyslab.Platform.Commons.Protocols.ProtocolException: Can’t open channel —> System.Net.Sockets.SocketException: An attempt was made to access a socket in a way forbidden by its access permissions
at Genesyslab.Platform.Commons.Connection.CommonConnection.Open()
at Genesyslab.Platform.Voice.Protocols.HA.StateOpening.OpenConnection(String host, Int32 port, ConnectionContext connectionContext)
at Genesyslab.Platform.Voice.Protocols.HA.StateOpening.Init()
at Genesyslab.Platform.Voice.Protocols.HA.TransitionManager.MakeTransition(IHAConnState from, IHAConnState to, IHAConnState siblingFrom, IHAConnState siblingTo)
at Genesyslab.Platform.Voice.Protocols.HA.StateAbsent.Open()
at Genesyslab.Platform.Voice.Protocols.HA.HAConnection.Open()
at Genesyslab.Platform.Commons.Protocols.DuplexChannel.InitiateOpen()
— End of inner exception stack trace —
at Genesyslab.Platform.Commons.Protocols.DuplexChannel.BeginOpen()
at Genesyslab.Enterprise.Core.Channel.OpenStraightWay()
at Genesyslab.Desktop.Modules.Voice.Model.Agents.MediaVoiceExtension.InitializeMedia(IMedia media, IEnterpriseServiceProvider enterpriseServiceProvider)
at Genesyslab.Desktop.Modules.Core.Model.Agents.Agent.InitializeMedia(IMedia media)
at Genesyslab.Desktop.Modules.Core.Model.Agents.Agent.Initialize()
13-03-04 12:28:55.089 [ 8] DEBUG r.WarmStandbyService - Channel SIPServer - tcp://w2k8r2gen8adm:7005 failed to open, cause: System.Net.Sockets.SocketException: An attempt was made to access a socket in a way forbidden by its access permissions
13-03-04 12:28:55.117 [ 8] DEBUG r.WarmStandbyService - Processing channel SIPServer - tcp://w2k8r2gen8adm:7005 closed (failure Genesyslab.Platform.Commons.Protocols.ClosedEventArgs:
PreviousChannelState = Opening
Cause = System.Net.Sockets.SocketException: An attempt was made to access a socket in a way forbidden by its access permissions
)… State: Idle
Our set up is:
sip 8.1.000.91
interaction workspacev 8.1.302.00
configuration server 8.1
message server 8.1.000.06
Thanks for your help ;D
SSB
As you can see,the issue is related to network problem. So,at first check if the firewall is turn on,if yes,try to turn off
Hi Kubig,
Thanks for your replay. The firewall is is already turned off, there is no antivirus installed ans the .NET Framework 3.5.1 is also installed
I performed a telnet on this port “7005”, everything is ok.
at Windows Sockets Error Codes (Windows) http://msdn2.microsoft.com/en-us/library/ms740668.aspx tt says:
WSAEACCES
10013
Permission denied.
An attempt was made to access a socket in a way forbidden by its access permissions. An example is using a broadcast address for sendto without broadcast permission being set using setsockopt(SO_BROADCAST).
Another possible reason for the WSAEACCES error is that when the bind function is called (on Windows NT 4 SP4 or later), another application, service, or kernel mode driver is bound to the same address with exclusive access. Such exclusive access is a new feature of Windows NT 4 SP4 and later, and is implemented by using the SO_EXCLUSIVEADDRUSE option.
someone would have an idea ?
Thanks in advance.
SSB
Do SIP Server logs report the same error or any additional info?
I don’t think it matters, but is SIP Server running on the same host where IWS is?
Fra
Hi Fra,
yes this is the case, the SIPServer is installed on the same machine, and there is nothing in the SIPServer logs.
SSB
IWS has been granted on their user role to everything? Which SIP Server and IWS versions do you have?
Yes the User have a Full control permission on all objects including hosts (in Environment and Resources Tenant).
Our set up is:
sip 8.1.000.91
Interaction Workspace SIP Endpoint Version 8.0.203.04
Widows Server 2008 R2 SP1.
No, I mean the IWS role…what is he allowed to use?
http://genesyslab.info/wiki/index.php?title=Role_Privileges
sorry for the confusion, yes all Privileges are granted
When you have option “disable-rbac” with value “true”,login of each agent is not based on role privileges. I have installed similiar configuration in my laboratory env and I did not register any same issue. Could you try to connect to the T-Server via ICOM console (for sure that the connection to the T-Server is globaly allowed/possible)?
Is Your computer part of domain and if yes do You have any policy set for .net application. For me it looks more like problem with .Net security settings. As far as I remember You can define policy in .Net which tells which functions are available for apps started from network. Maybe in Your case there is a policy which blocks starting TCP/IP sockets - this is just wild guess
