CCP script library
I was browsing through this forum and noticed a lot of posts in regards to CCP scripting.
I was thinking that maybe we should put together a collection of
commonly used CCP scripts so all of us can use it.
What do you think?
Fantastic Idea
I need as much info on this as possible which I am quite happy to share with all :slight_smile:
I’m in.
Yeah Im in… Im trying to figure out if you can create global variables inside the action/threshold scripts. From the testing I have done it doesn’t seem like you can. : ( has anyone else had a look at this.
The reason why I want to do this is I want a threshold that looks at both the state of an object and the number/time of “whatevers” under that object. So the Threshold will only active when both conditions are met.
ie;
Campaign “MyCampaign” = SCMPAStatusActivated" and Threshold.StatValue = 100
Has anyone had a look at this or have any ideas?
Bob.
Track it all in DLL and then use two statistics that you can pass to and from DLL to retrieve the variables you want. One statistic would be used as variable name and other as variable value.
I know it is not really smart, but it works.
