Hi Guys, strange question. We are testing CCA at the moment for rolling out to the callcentre. However, we have some projects which do not use any softphone app, ie they login manually through a ‘hardphone’ turret.
Although I can see the login event, the logout event and calls that they get, I can’t see any agentready events or agentnotready events coming through tserver. This obviously throws all the reporting out for those agents.
Can anyone suggest how I can fix this, apart from making the agents use a softphone of some kind?
What version of StatServer are you using? I know that in 6.5 the StatServer pretty much ignores any actions that have been delivered via softphone. Ver6.0 or 6.1 was a lot looser in this regard.
Is your switch Definity? Definity doesn’t report agent state changes over an ASAI link… Your best bet would be to knock together a simple app out of the ActiveX controls and get agents to change state using this rather than their teleset.
