Hi, everybody,
I am having a somewhat of a rookie problem and I cannot figure out what it is.
I am using 6.5.2 Historical and Realtime Reporting to keep track of all the calls, and numbers do not match. The numbers shown in CCP and the numbers shown in CCA are different by about 10 to 20 percent by the end of the day.
At first I thought it had something to do with time profile, but… we are using the same statistics in both CCA and CCP templates with identical time profiles, so that should not be the case.
Next, I thought it might be … "# of cleared calls " but then it still does not make sense. Because, if you have CCP open from morning till night then by the end of the day you should have the same number of calls entered, followed by calls answered+calls abandoned+calls distributed to somewhere else…
But it is not… Total Answered+Total Abandoned+total cleared does not match Total Entered. What makes matters wose, Total_Answered is different for CCP and CCA…
Anyone has any idea what is going on?
PBX is Avaya
