Catching and Managing Genesys Cloud Flow Execution Exceptions via Python SDK
- A Python module that queries Genesys Cloud flow execution analytics, catches runtime exceptions, validates error payloads against strict schemas, and safely formats stack traces to prevent data leakage.
- Uses the Genesys Cloud Python SDK (
genesyscloud-python) and the Platform Webhooks API (/api/v2/platform/webhooks) for external synchronization and audit tracking. - Covers Python 3.10+ with
httpx,pydantic, and structured logging for production deployment.
- OAuth Client Credentials flow (confidential client with
client_idandclient_id_secret) - Required scopes:
flow:read,analytics:flows:view,webhook:read,webhook:write - SDK version:
genesyscloud-python>=15.0.0 - Runtime: Python 3.10+
- External dependencies:
httpx>=0.27.0,pydantic>=2.5.0,structlog>=24.1.0,python-dotenv>=1.0.0
The Genesys Cloud Python SDK handles token acquisition and automatic refresh when configured with client credentials. The following configuration initializes the platform client with retry parameters and a custom HTTP adapter for latency tracking.
import os
import httpx
from genesyscloud.platform_client_v2.configuration import Configuration
from genesyscloud.platform_client_v2.api_client import ApiClient
from genesyscloud.flow_analytics_api import FlowAnalyticsApi
from genesyscloud.platform_webhooks_api import PlatformWebhooksApi
def initialize_genesys_client() -> tuple[FlowAnalyticsApi, PlatformWebhooksApi]:
configuration = Configuration()
configuration.client_id = os.environ["GENESYS_CLIENT_ID"]
configuration.client_secret = os.environ["GENESYS_CLIENT_SECRET"]
configuration.environment = os.environ.get("GENESYS_ENVIRONMENT", "mypurecloud.com")
configuration.host = f"https://api.{configuration.environment}"
# Configure retry logic for 429 rate limits
configuration.retries = 3
configuration.backoff_factor = 0.5
configuration.status_forcelist = [429, 500, 502, 503, 504]
api_client = ApiClient(configuration)
flow_analytics = FlowAnalyticsApi(api_client)
webhooks = PlatformWebhooksApi(api_client)
return flow_analytics, webhooks
Step 1: Configure Error Validation Schemas and Stack Trace Sanitization
Genesys Cloud returns structured error payloads during flow execution failures. You must validate these payloads against a strict schema to prevent malformed data from propagating to downstream systems. The following Pydantic model enforces data constraints and applies a maximum stack trace size limit to prevent memory exhaustion.
import re
from pydantic import BaseModel, field_validator, ConfigDict
from typing import Optional
class FlowErrorPayload(BaseModel):
model_config = ConfigDict(strict=True)
error_code: str
message: str
stack_trace: Optional[str] = None
flow_run_id: str
exception_type: str
@field_validator("stack_trace", mode="before")
@classmethod
def sanitize_stack_trace(cls, v: Optional[str]) -> Optional[str]:
if not v:
return None
# Enforce maximum-exception-stack-size limit of 4096 characters
MAX_STACK_SIZE = 4096
if len(v) > MAX_STACK_SIZE:
v = v[:MAX_STACK_SIZE] + "... [TRUNCATED]"
# Sensitive-data-leak verification pipeline
sensitive_patterns = [
r"(?i)password\s*[:=]\s*\S+",
r"(?i)secret\s*[:=]\s*\S+",
r"Bearer\s+[A-Za-z0-9\-_\.]+",
r"\b\d{3}-\d{2}-\d{4}\b" # SSN pattern
for pattern in sensitive_patterns:
v = re.sub(pattern, "[REDACTED]", v)
return v
@field_validator("error_code", mode="before")
@classmethod
def validate_error_code(cls, v: str) -> str:
# Error-code-mapping evaluation logic
VALID_CODES = ["FLOW_EXECUTION_ERROR", "DATA_ACTION_TIMEOUT", "CONNECTIVITY_FAILURE", "VALIDATION_ERROR"]
if v not in VALID_CODES:
raise ValueError(f"Invalid error code: {v}")
return v
Step 2: Query Flow Analytics for Runtime Exceptions with Pagination and Retry Logic
The /api/v2/analytics/flows/details/query endpoint returns flow execution details. You must construct a valid query payload, handle pagination via the next_page_sequence, and implement atomic GET verification. The following function demonstrates the complete request cycle with explicit error handling.
import httpx
from genesyscloud.flow_analytics_api.models import FlowDetailsQueryRequest, FlowDetailsQueryRequestInterval
def fetch_flow_exceptions(flow_analytics: FlowAnalyticsApi, org_id: str) -> list[FlowErrorPayload]:
start_time = datetime.utcnow() - timedelta(hours=1)
end_time = datetime.utcnow()
query_payload = FlowDetailsQueryRequest(
interval=f"{start_time.isoformat()}Z/{end_time.isoformat()}Z",
group_by=["flowRunId"],
view="flowRunDetails",
select=["flowRunId", "status", "errorCode", "errorMessage", "flowId"],
where=[{"path": "status", "operator": "equals", "value": "failed"}]
validated_errors = []
page_sequence = None
max_pages = 5 # Prevent runaway pagination
for _ in range(max_pages):
response = flow_analytics.post_analytics_flows_details_query(
body=query_payload,
page_sequence=page_sequence
if hasattr(e, 'status') and e.status == 429:
print("Rate limit exceeded. Applying backoff retry.")
time.sleep(2)
raise e
if not response.entity:
break
for detail in response.entity:
error_obj = FlowErrorPayload(
error_code=detail.error_code or "UNKNOWN_ERROR",
message=detail.error_message or "No message provided",
stack_trace=getattr(detail, "stack_trace", None),
flow_run_id=detail.flow_run_id,
exception_type="FlowExecutionException"
validated_errors.append(error_obj)
except Exception as parse_err:
print(f"Schema validation failed for run {detail.flow_run_id}: {parse_err}")
page_sequence = response.next_page_sequence
if not page_sequence:
break
return validated_errors
Step 3: Register Error Synchronization Webhooks and Track Latency
You must synchronize caught exceptions with an external operations center. The /api/v2/platform/webhooks endpoint registers HTTP callbacks. The following code registers a webhook that triggers on flow errors, tracks request latency, and enforces silent-failure checking to ensure the registration pipeline does not block the main execution thread.
from genesyscloud.platform_webhooks_api.models import CreateWebhookRequest, CreateWebhookRequestResource, WebhookType
import structlog
def register_error_webhook(webhooks_api: PlatformWebhooksApi, target_url: str, flow_id: str) -> dict:
resource = CreateWebhookRequestResource(
webhook_type=WebhookType("custom"),
name="Flow Exception Catcher Sync",
description="Synchronizes flow runtime exceptions to external ops center",
enabled=True,
api_version="2.0"
create_req = CreateWebhookRequest(
name="flow-exception-sync",
resources=[resource],
target_uri=target_url,
headers={"Content-Type": "application/json", "X-Source": "genesys-exception-catcher"},
event_types=["flow:errors"]
start_ns = time.time_ns()
response = webhooks_api.post_platform_webhooks(body=create_req)
latency_ms = (time.time_ns() - start_ns) / 1_000_000
logger.info(
"webhook_registered",
webhook_id=response.id,
target_url=target_url,
latency_ms=round(latency_ms, 2),
status=response.status
return {"id": response.id, "status": response.status, "latency_ms": latency_ms}
# Silent-failure checking: log but do not raise to prevent pipeline halt
logger.warning(
"webhook_registration_failed",
error=str(e),
fallback="local_audit_only"
return {"id": None, "status": "failed", "latency_ms": 0}
Step 4: Execute the Exception Catcher Loop with Audit Logging
The final component ties validation, analytics querying, webhook synchronization, and audit logging into a single execution loop. It tracks catch efficiency metrics and generates structured audit logs for data governance compliance.
import json
import httpx
class ExceptionCatcher:
def __init__(self, flow_analytics, webhooks_api, org_id: str, webhook_url: str):
self.flow_analytics = flow_analytics
self.webhooks_api = webhooks_api
self.org_id = org_id
self.success_count = 0
self.failure_count = 0
self.total_latency = 0.0
def run(self) -> dict:
loop_start = time.time()
errors = fetch_flow_exceptions(self.flow_analytics, self.org_id)
query_latency = time.time() - loop_start
audit_entries = []
for err in errors:
entry_start = time.time()
# Generate catching audit log for data governance
audit_entry = {
"timestamp": datetime.utcnow().isoformat() + "Z",
"flow_run_id": err.flow_run_id,
"error_code": err.error_code,
"sanitized_message": err.message[:200],
"stack_trace_present": err.stack_trace is not None,
"data_leak_check": "passed",
"schema_validation": "passed"
audit_entries.append(audit_entry)
# Synchronize with external ops center via httpx POST
with httpx.Client(timeout=5.0) as client:
resp = client.post(
self.webhook_url,
json=audit_entry,
headers={"X-Audit-Source": "genesys-catcher"}
if resp.status_code in (200, 201, 202):
self.success_count += 1
else:
self.failure_count += 1
except httpx.HTTPError:
entry_latency = time.time() - entry_start
self.total_latency += entry_latency
efficiency_rate = self.success_count / max(self.success_count + self.failure_count, 1)
avg_latency = self.total_latency / max(len(audit_entries), 1)
"total_exceptions_caught": len(errors),
"sync_success_rate": round(efficiency_rate, 3),
"average_latency_ms": round(avg_latency * 1000, 2),
"audit_log_count": len(audit_entries),
"query_latency_seconds": round(query_latency, 3)
The following script combines all components into a single executable module. Replace the environment variables with your Genesys Cloud credentials before execution.
import os
import httpx
import structlog
# Configure structured logging
structlog.configure(
processors=[
structlog.processors.add_log_level,
structlog.processors.TimeStamper(fmt="iso"),
structlog.processors.JSONRenderer()
wrapper_class=structlog.make_filtering_bound_logger("INFO")
error_code: str
message: str
flow_run_id: str
exception_type: str
@classmethod
if not v:
return None
sensitive_patterns = [r"(?i)password\s*[:=]\s*\S+", r"Bearer\s+[A-Za-z0-9\-_\.]+", r"\b\d{3}-\d{2}-\d{4}\b"]
return v
@classmethod
return v
return FlowAnalyticsApi(api_client), PlatformWebhooksApi(api_client)
for _ in range(5):
response = flow_analytics.post_analytics_flows_details_query(body=query_payload, page_sequence=page_sequence)
time.sleep(2)
raise e
break
validated_errors.append(FlowErrorPayload(
logger.warning("schema_validation_failed", run_id=detail.flow_run_id, error=str(parse_err))
break
def register_error_webhook(webhooks_api: PlatformWebhooksApi, target_url: str) -> dict:
resource = CreateWebhookRequestResource(webhook_type=WebhookType("custom"), name="Flow Exception Sync", enabled=True, api_version="2.0")
create_req = CreateWebhookRequest(name="flow-exception-sync", resources=[resource], target_uri=target_url, headers={"Content-Type": "application/json"})
return {"id": response.id, "status": response.status, "latency_ms": (time.time_ns() - start_ns) / 1_000_000}
logger.warning("webhook_registration_failed", error=str(e))
audit_entries = []
for err in errors:
audit_entry = {
resp = client.post(self.webhook_url, json=audit_entry)
else:
self.total_latency += time.time() - entry_start
"average_latency_ms": round((self.total_latency / max(len(audit_entries), 1)) * 1000, 2),
flow_api, webhook_api = initialize_genesys_client()
catcher = ExceptionCatcher(flow_api, webhook_api, os.environ["GENESYS_ORG_ID"], os.environ["OPS_CENTER_URL"])
metrics = catcher.run()
logger.info("catcher_execution_complete", metrics=metrics)
- What causes it: The OAuth client credentials are invalid, expired, or the scope
analytics:flows:viewis missing from the client configuration in the Genesys Cloud admin console. - How to fix it: Verify the
client_idandclient_secretmatch an active confidential client. Ensure the client has the required scopes. The SDK will automatically retry once, but persistent 401 errors require credential rotation. - Code showing the fix:
# Verify scope assignment in configuration before initialization
configuration.scopes = ["flow:read", "analytics:flows:view", "webhook:read", "webhook:write"]
- What causes it: The analytics query endpoint enforces strict rate limits per organization. Rapid pagination or concurrent polling triggers throttling.
- How to fix it: The configuration already includes
status_forcelist = [429]and exponential backoff. If throttling persists, reduce the query interval window or implement a jitter delay between pagination cycles. - Code showing the fix:
import random
jitter = random.uniform(0.5, 1.5)
time.sleep(2 + jitter)
Error: Pydantic ValidationError: Invalid error code
- What causes it: The flow execution returned an error code outside the predefined
VALID_CODESmatrix. Genesys Cloud occasionally returns platform-specific codes during beta feature rollouts. - How to fix it: Expand the validation matrix or implement a fallback mapping strategy that routes unknown codes to a generic
PLATFORM_ERRORcategory instead of failing the entire pipeline. - Code showing the fix:
@classmethod
return v if v in VALID_CODES else "PLATFORM_ERROR"
