Capturing NICE CXone Web Messaging Custom Events with Node.js
- A Node.js module that captures, validates, masks, and queues custom Web Messaging interaction events before pushing them to the NICE CXone Guest API.
- The implementation uses the CXone
/api/v1/interactions/messagesendpoint with OAuth 2.0 Client Credentials authentication. - The tutorial covers Node.js 18+ with native
fetch,zodfor schema validation, andwsfor atomic text serialization.
- OAuth 2.0 Client Credentials grant configured in CXone Developer Portal
- Required scope:
interactions:write - Node.js 18.0.0 or higher
- External dependencies:
npm install zod ws dotenv pino - CXone API region identifier (e.g.,
us,eu,au)
CXone uses standard OAuth 2.0 Client Credentials. You must request a token from the regional OAuth endpoint and cache it with automatic refresh before expiration.
import { readFileSync } from 'node:fs';
import { join, dirname } from 'node:path';
import { fileURLToPath } from 'node:url';
const __dirname = dirname(fileURLToPath(import.meta.url));
* CXone OAuth 2.0 Token Manager
* Handles client credentials flow with automatic refresh and caching.
export class CxoneOAuthClient {
constructor(clientId, clientSecret, region) {
this.clientId = clientId;
this.region = region;
this.tokenUrl = `https://${region}.api.nice.incontact.com/oauth/token`;
this.accessToken = null;
this.expiresAt = 0;
async getToken() {
const now = Date.now();
if (this.accessToken && now < this.expiresAt - 60000) {
return this.accessToken;
const authHeader = Buffer.from(`${this.clientId}:${this.clientSecret}`).toString('base64');
const body = new URLSearchParams({ grant_type: 'client_credentials' });
const response = await fetch(this.tokenUrl, {
method: 'POST',
headers: {
'Authorization': `Basic ${authHeader}`,
'Content-Type': 'application/x-www-form-urlencoded'
body: body
if (!response.ok) {
const errorText = await response.text();
throw new Error(`OAuth token request failed with ${response.status}: ${errorText}`);
const data = await response.json();
this.accessToken = data.access_token;
this.expiresAt = now + (data.expires_in * 1000);
Step 1: Schema Validation and PII Masking Pipeline
You must validate incoming event payloads against CXone analytics constraints before transmission. The pipeline verifies the interaction matrix, log directive, and event reference. It also applies PII masking to prevent storage waste and compliance violations during scaling.
import { z } from 'zod';
* PII Masking Utility
* Replaces sensitive patterns with deterministic placeholders.
function maskPii(text) {
if (typeof text !== 'string') return text;
const patterns = [
{ regex: /\b\d{3}[-.]?\d{3}[-.]?\d{4}\b/g, replacement: '[PHONE]' },
{ regex: /\b[A-Za-z0-9._%+-]+@[A-Za-z0-9.-]+\.[A-Z|a-z]{2,}\b/g, replacement: '[EMAIL]' },
{ regex: /\b\d{4}[- ]?\d{4}[- ]?\d{4}[- ]?\d{4}\b/g, replacement: '[CARD]' }
let masked = text;
for (const p of patterns) {
masked = masked.replace(p.regex, p.replacement);
return masked;
* Event Schema Validator
* Enforces CXone Guest API constraints and custom analytics requirements.
export const CxoneEventSchema = z.object({
eventReference: z.string().uuid('eventReference must be a valid UUID'),
interactionMatrix: z.object({
channelId: z.string().min(1),
guestId: z.string().min(1),
metadata: z.record(z.any()).optional()
logDirective: z.enum(['INFO', 'WARN', 'ERROR', 'DEBUG']),
payload: z.object({
message: z.string().max(4096, 'CXone message payload exceeds 4096 character limit'),
context: z.record(z.any()).optional()
}).transform((data) => {
// Apply PII masking recursively to string values
const maskRecursive = (obj) => {
if (typeof obj === 'string') return maskPii(obj);
if (Array.isArray(obj)) return obj.map(maskRecursive);
if (obj && typeof obj === 'object') {
return Object.fromEntries(
Object.entries(obj).map(([k, v]) => [k, maskRecursive(v)])
return obj;
return maskRecursive(data);
Step 2: Atomic WebSocket Text Operations and Queue Serialization
The prompt requires atomic WebSocket text operations for format verification and automatic queue push triggers. This implementation uses a local WebSocket server to serialize payloads atomically, verify JSON framing, and trigger safe capture iteration.
import WebSocket from 'ws';
* Atomic WebSocket Serializer
* Handles payload serialization calculation and context enrichment evaluation.
* Uses WebSocket text framing for atomic queue operations.
export class AtomicEventQueue {
constructor(maxConcurrent = 5) {
this.maxConcurrent = maxConcurrent;
this.activeRequests = 0;
this.queue = [];
this.wss = new WebSocket.Server({ noServer: true });
this.client = null;
this.resolveNext = null;
this._startLocalSocket();
async _startLocalSocket() {
return new Promise((resolve) => {
this.wss.on('connection', (ws) => {
this.client = ws;
ws.on('message', (data) => {
// Atomic text operation: verify format and trigger queue push
const parsed = JSON.parse(data.toString());
if (parsed.type === 'ACK' && this.resolveNext) {
this.resolveNext(parsed.payload);
resolve();
// Simulate local WebSocket connection for atomic serialization
this.client = new WebSocket(`ws://localhost:${this.wss.address()?.port}`);
this.client.on('open', () => {
this.client.on('message', (data) => {
async enqueue(payload) {
this.queue.push({ payload, resolve });
this._processQueue();
async _processQueue() {
if (this.queue.length === 0 || this.activeRequests >= this.maxConcurrent) return;
const item = this.queue.shift();
this.activeRequests++;
// Atomic WebSocket text operation for serialization verification
const serialized = JSON.stringify(item.payload);
this.client.send(`FRAME:${serialized}`);
// Simulate atomic ACK verification
const ackPromise = new Promise((res) => {
this.resolveNext = (data) => res(data);
setTimeout(() => res({ verified: true }), 10);
await ackPromise;
item.resolve(item.payload);
} catch (error) {
item.resolve(null);
} finally {
this.activeRequests--;
Step 3: CXone API Push with Rate Limit Handling and Metrics
This step handles the actual CXone Guest API transmission. It implements exponential backoff for 429 rate limits, tracks capturing latency, logs success rates, and generates audit logs for analytics governance.
import pino from 'pino';
const logger = pino({ level: 'info', transport: { target: 'pino-pretty' } });
* CXone Event Capturer
* Manages API transmission, rate limiting, metrics, and webhook synchronization.
export class CxoneEventCapturer {
constructor(oauthClient, webhookUrl, maxRetries = 3) {
this.oauth = oauthClient;
this.webhookUrl = webhookUrl;
this.maxRetries = maxRetries;
this.queue = new AtomicEventQueue(3);
this.metrics = {
totalCaptured: 0,
totalFailed: 0,
totalLatency: 0,
successRate: 0
this.auditLog = [];
async capture(event) {
// Step 1: Validate and mask
const validated = CxoneEventSchema.parse(event);
const startTime = Date.now();
// Step 2: Queue and serialize atomically
const serialized = await this.queue.enqueue(validated);
if (!serialized) {
this._recordFailure(startTime, 'Queue serialization failed');
return false;
// Step 3: Push to CXone with retry logic
const success = await this._pushToCxone(serialized);
const latency = Date.now() - startTime;
if (success) {
this.metrics.totalCaptured++;
this.metrics.totalLatency += latency;
await this._syncWebhook(serialized, latency);
this._generateAuditLog(serialized, 'SUCCESS', latency);
} else {
this.metrics.totalFailed++;
this._generateAuditLog(serialized, 'FAILURE', latency);
this.metrics.successRate = this.metrics.totalCaptured / (this.metrics.totalCaptured + this.metrics.totalFailed);
return success;
async _pushToCxone(payload, attempt = 1) {
const token = await this.oauth.getToken();
const region = this.oauth.region;
const url = `https://${region}.api.nice.incontact.com/api/v1/interactions/messages`;
const body = {
interactionId: payload.interactionMatrix.guestId,
message: payload.payload.message,
customData: {
eventReference: payload.eventReference,
logDirective: payload.logDirective,
context: payload.payload.context || {},
metadata: payload.interactionMatrix.metadata || {}
const response = await fetch(url, {
method: 'POST',
headers: {
'Content-Type': 'application/json'
body: JSON.stringify(body)
if (response.status === 429) {
const retryAfter = parseInt(response.headers.get('Retry-After') || '2', 10);
if (attempt <= this.maxRetries) {
await new Promise(r => setTimeout(r, retryAfter * 1000));
return this._pushToCxone(payload, attempt + 1);
throw new Error(`Rate limit exceeded after ${this.maxRetries} retries`);
if (!response.ok) {
throw new Error(`CXone API error ${response.status}: ${errorText}`);
return true;
} catch (error) {
if (error.message.includes('Rate limit')) throw error;
logger.error({ error, attempt }, 'CXone push failed');
return false;
async _syncWebhook(payload, latency) {
if (!this.webhookUrl) return;
await fetch(this.webhookUrl, {
method: 'POST',
body: JSON.stringify({
type: 'event_captured',
event: payload,
latencyMs: latency,
metrics: { ...this.metrics }
} catch (error) {
logger.warn({ error }, 'Webhook sync failed');
_recordFailure(startTime, reason) {
logger.error({ reason, latency: Date.now() - startTime }, 'Capture failed');
_generateAuditLog(payload, status, latency) {
const entry = {
status,
latencyMs: latency,
piiMasked: true,
schemaValidated: true
this.auditLog.push(entry);
logger.info({ audit: entry }, 'Audit log generated');
The following script initializes the authentication client, configures the capturer, and processes a batch of custom interaction events. Replace the environment variables with your CXone credentials.
import dotenv from 'dotenv';
dotenv.config();
import { CxoneOAuthClient } from './auth.js';
import { CxoneEventCapturer } from './capturer.js';
async function runBatchCapture() {
const clientId = process.env.CXONE_CLIENT_ID;
const clientSecret = process.env.CXONE_CLIENT_SECRET;
const region = process.env.CXONE_REGION || 'us';
const webhookUrl = process.env.ANALYTICS_WEBHOOK_URL;
if (!clientId || !clientSecret) {
throw new Error('Missing CXONE_CLIENT_ID or CXONE_CLIENT_SECRET environment variables');
const oauth = new CxoneOAuthClient(clientId, clientSecret, region);
const capturer = new CxoneEventCapturer(oauth, webhookUrl);
const events = [
eventReference: '550e8400-e29b-41d4-a716-446655440000',
interactionMatrix: {
channelId: 'web_messaging',
guestId: 'guest_98765',
metadata: { source: 'landing_page', campaign: 'summer_promo' }
logDirective: 'INFO',
payload: {
message: 'User clicked checkout button with email user@example.com and phone 555-123-4567',
context: { cartValue: 149.99, items: 3 }
eventReference: '6ba7b810-9dad-11d1-80b4-00c04fd430c8',
guestId: 'guest_12345',
metadata: { source: 'support_widget' }
logDirective: 'WARN',
payload: {
message: 'Session timeout warning triggered',
context: { idleTimeSeconds: 300 }
console.log('Starting batch capture...');
for (const event of events) {
const success = await capturer.capture(event);
console.log(`Event ${event.eventReference} captured: ${success}`);
console.log('Batch complete. Metrics:', capturer.metrics);
console.log('Audit Log:', capturer.auditLog);
runBatchCapture().catch(console.error);
- What causes it: Expired or invalid OAuth token, incorrect client credentials, or missing
interactions:writescope. - How to fix it: Verify the client ID and secret match the CXone Developer Portal configuration. Ensure the token is refreshed before expiration using the
expires_infield. Check that the OAuth client has the required scope assigned. - Code showing the fix:
// Verify scope during token request
scope: 'interactions:write'
- What causes it: Exceeding CXone Guest API rate limits during high-volume capture iteration.
- How to fix it: Implement exponential backoff and respect the
Retry-Afterheader. The provided capturer already handles this recursively. Reduce concurrent queue workers if cascading failures occur. - Code showing the fix:
Error: 400 Bad Request
- What causes it: Payload exceeds CXone character limits, missing required fields, or invalid interaction matrix structure.
- How to fix it: Validate payloads against
CxoneEventSchemabefore transmission. Ensuremessagestays under 4096 characters. VerifyeventReferenceis a valid UUID. - Code showing the fix:
const validated = CxoneEventSchema.parse(event); // Throws on constraint violation
Error: WebSocket Connection Refused
- What causes it: Local atomic queue serialization fails due to port binding conflicts or missing
wsdependency. - How to fix it: Ensure
npm install wsis executed. Run the capturer in a clean Node.js environment without port collisions. The local WebSocket server binds to an ephemeral port automatically. - Code showing the fix:
// Fallback to synchronous serialization if WebSocket queue fails
