Hi guys,
How can I capture the ANI/DNIS using Studio 7.5?
Hi Cav,
If my memory serves well
GVP fills the variables ANI and DNIS automatically at the start. You can get the value using “lookUp” function. If it won’t work try to use shadow variable “$ani$”.
PS. What about OBN? Any progress?
Thanks!
About OBN nop. It still doesn’t make a single call and keeps crashing
Now Alcatel says that OBN doesn’t work with OXE…I don’t trust that one, only that they don’t know even of what I’m talking about
a “mechanical way” is too modify the url provisioned on EMPS interfase…so u can capture the value.
How is that? The URL that you provision by default already contains the ANI…what do you mean?
I think he means the DNIS. I had to add it in the IVR URL, for eg: DNIS=$did$ so I can do a lookUp() for “DNIS”.
Hope this helps.
yes…
very sorry for th delay…
hope that recommendation helps u
Solution for my memory:
call setpageItem(“vANI”,lookup(“ANI”))
