Can two t-servers connect to same switch?
Hey folks, wondering whether this is possible or not
two t-servers which are located in different tenants say tserver1 in xtenant and tserver2 in ytenant, can they connect to same switch using the tcp ip link?
Yes as long as they don’t monitor same objects on the Switch (PBX)
It depends on the switch: some don’t support switch partitioning.
Fra
