Hi, I have a question I need an answer to:
what I want to do s to get a total number of calls handled on both RP A and RP B without doing any math. By queueing calls on VQ_A in both RP_A and RP B, I thought I could accomplish that, but it does not work.
Here is the layout:
I have TServer A on Switch A and TServer B on Switch B. I have URS connected to both TServers.
I have VQ_A defined under TServer A and VQ_B defined under TServer B.
I also have Routing Point A on Switch A where strategy A is running and Routing Point B on Switch B where strategy B is running.
StatServer is connected to both A and B.
My Strategy B, when receives a call on RP B, tries to queue a call into VQ_A (yes, A not B) while call is waiting for a target.
I noticed that if I try that, URS does NOT queue a call into VQ_A.
If I change VQ_A to VQ_B in my Select target, it works just fine.
I thought that VQs were global, thus allowing you to queue the calls into them even if they were defined under a different Switch!!!
What am I doing wrong? We are using 6.5.108 URS.
Thanks!
