Calling AWS Lambda from Genesys Cloud Architect: IAM Role Configuration and Execution
- One sentence: This tutorial builds a serverless integration where a Genesys Cloud Architect flow executes an AWS Lambda function via the
serverlessdata action, passing conversation context to retrieve or update external data. - One sentence: This uses the Genesys Cloud Platform API for authentication and testing, alongside AWS IAM and Lambda APIs for backend configuration.
- One sentence: The programming languages covered are Python (for local testing and AWS CLI scripting) and JavaScript (for the Lambda handler logic).
- OAuth Client Type: Public or Confidential Client with
admin:apioruser:apiscopes for testing, andintegration:serverlessscope if using specific integration endpoints (though the Data Action itself runs in the context of the flow, which requires the user to haveuser:apior higher). - AWS Account: An active AWS account with permissions to create IAM Roles and Lambda Functions.
- Genesys Cloud Account: An account with
admin:integrationoradmin:serverlessprivileges to configure the Serverless Integration endpoint in the Admin console (required before the Architect Data Action can resolve the function ARN). - Python 3.8+: Installed with
pipfor running the verification scripts. - AWS CLI: Configured with credentials that have
iam:CreateRole,lambda:CreateFunction, andlambda:InvokeFunctionpermissions.
Before interacting with the Genesys Cloud API to verify the integration or the Lambda endpoint, you must establish an OAuth token. The following Python script uses the requests library to obtain an access token using the Client Credentials flow. This token is required for any subsequent API calls to validate that the Serverless Integration is correctly linked to your AWS Lambda function.
import requests
import json
class GenesysAuth:
def __init__(self, client_id: str, client_secret: str, org_domain: str):
self.client_id = client_id
self.org_domain = org_domain
self.token_url = f"https://{org_domain}.mypurecloud.com/oauth/token"
self.access_token = None
self.token_expiry = 0
def get_token(self) -> str:
Retrieves an OAuth access token.
Implements basic caching to avoid unnecessary requests.
if self.access_token and time.time() < self.token_expiry:
return self.access_token
payload = {
"scope": "admin:api user:api"
headers = {
response = requests.post(
self.token_url,
data=payload,
headers=headers,
auth=(self.client_id, self.client_secret)
response.raise_for_status()
token_data = response.json()
self.token_expiry = time.time() + token_data["expires_in"] - 60 # Buffer for safety
raise Exception("Authentication failed: Invalid Client ID or Secret.") from e
elif response.status_code == 400:
raise Exception("Bad Request: Check grant_type and scope.") from e
else:
raise Exception(f"HTTP Error: {response.status_code}") from e
# Example Usage
# auth = GenesysAuth("your_client_id", "your_client_secret", "your_org_domain")
# token = auth.get_token()
This token allows you to query the Serverless Integrations API to ensure the connection between Genesys Cloud and AWS is established before attempting to invoke the function from Architect.
Step 1: Configure the AWS IAM Role
The Genesys Cloud Serverless Integration does not “log in” to AWS. Instead, Genesys Cloud uses a pre-configured IAM Role to assume permissions. You must create an IAM Role that allows the lambda.amazonaws.com service to assume it, and attach policies that permit the specific Lambda function to be invoked.
Critically, Genesys Cloud invokes Lambda via the AWS API. The IAM Role must trust the lambda.amazonaws.com service principal.
Execute the following AWS CLI commands to create the role. Replace GenesysCloudLambdaRole with your desired role name.
# 1. Create the Trust Policy Document
# This allows the AWS Lambda service to assume this role.
cat > trust-policy.json << 'EOF'
"Version": "2012-10-17",
"Statement": [
"Effect": "Allow",
"Principal": {
"Service": "lambda.amazonaws.com"
"Action": "sts:AssumeRole"
EOF
# 2. Create the IAM Role
aws iam create-role \
--role-name GenesysCloudLambdaRole \
--assume-role-policy-document file://trust-policy.json
# 3. Attach the AWS managed policy for basic Lambda execution
# This allows the function to write logs to CloudWatch.
aws iam attach-role-policy \
--policy-arn arn:aws:iam::aws:policy/service-role/AWSLambdaBasicExecutionRole
If your Lambda function needs to access other AWS resources (e.g., DynamoDB, S3), you must create a custom policy and attach it to this role. For this tutorial, we assume the Lambda function is self-contained and only needs execution permissions.
Step 2: Deploy the Lambda Function
Create a simple Lambda function in Node.js that accepts the payload from Genesys Cloud, processes it, and returns a structured response. The payload from Genesys Cloud contains the event object, which includes data (the input from the Data Action) and context (metadata about the flow execution).
Create a file named index.js:
* Lambda Handler for Genesys Cloud Integration
* @param {Object} event - The event object from Genesys Cloud
* @param {Object} context - The Lambda context
* @returns {Object} The response object to be returned to Genesys Cloud
exports.handler = async (event, context) => {
console.log("Received event from Genesys Cloud:", JSON.stringify(event));
// Genesys Cloud sends data in the 'data' field of the event
const inputData = event.data;
if (!inputData) {
statusCode: 400,
body: {
error: "No input data provided in the Genesys Cloud Data Action."
// Extract specific fields from the Genesys Cloud context
const contactId = inputData.contactId;
const queueName = inputData.queueName;
const customerEmail = inputData.customerEmail;
console.log(`Processing contact: ${contactId}, Queue: ${queueName}, Email: ${customerEmail}`);
// Simulate business logic (e.g., fetching data from a database)
const processedResult = {
contactId: contactId,
status: "processed",
recommendation: "Offer premium support based on queue priority."
// Return the result in the format expected by Genesys Cloud
// The 'body' field becomes the output of the Data Action
statusCode: 200,
body: processedResult
Deploy this function using the AWS CLI. Ensure you use the IAM Role created in Step 1.
# 1. Zip the function code
zip function.zip index.js
# 2. Create the Lambda Function
aws lambda create-function \
--function-name GenesysCloudDataProcessor \
--runtime nodejs18.x \
--role arn:aws:account-id:role/GenesysCloudLambdaRole \
--handler index.handler \
--zip-file fileb://function.zip \
--timeout 30 \
--memory-size 128
Note the FunctionArn returned in the JSON response. You will need this ARN in the next step.
Step 3: Configure the Genesys Cloud Serverless Integration
Before the Architect Data Action can call the Lambda, you must register the integration in Genesys Cloud. This is done via the Admin console or the API. Since this tutorial focuses on code, we will use the Python API to create the Serverless Integration.
You need the FunctionArn from Step 2.
import requests
import json
def create_serverless_integration(auth: GenesysAuth, function_arn: str, integration_name: str):
Creates a Serverless Integration in Genesys Cloud.
Args:
auth: GenesysAuth instance
function_arn: The ARN of the AWS Lambda function
integration_name: A unique name for the integration in Genesys Cloud
api_url = f"https://{auth.org_domain}.mypurecloud.com/api/v2/integrations/serverless"
headers = {
payload = {
"name": integration_name,
"type": "lambda",
"configuration": {
"functionArn": function_arn,
"region": "us-east-1" # Adjust to your Lambda region
"enabled": True
response = requests.post(api_url, headers=headers, data=json.dumps(payload))
integration_id = response.json().get("id")
print(f"Successfully created integration with ID: {integration_id}")
return integration_id
if response.status_code == 409:
print("Integration already exists. Please update it via the console or API.")
else:
print(f"Failed to create integration: {response.status_code} - {response.text}")
raise e
# Example Usage
# integration_id = create_serverless_integration(auth, "arn:aws:lambda:us-east-1:123456789012:function:GenesysCloudDataProcessor", "My Lambda Integration")
Step 4: Configure the Architect Data Action
In the Genesys Cloud Architect interface, you will add a Data Action element to your flow.
Select the Serverless data action type.
Choose the integration you created in Step 3 (
My Lambda Integration). -
Configure the Input Data. Map the flow variables to the JSON structure expected by your Lambda function.
- Input JSON Structure:
{ "contactId": "{{contactId}}", "queueName": "{{queueName}}", "customerEmail": "{{customerEmail}}" } - Replace
{{contactId}}, etc., with the actual variable references from your flow.
Configure the Output Data. The Lambda function returns a JSON object in the
bodyfield. You must define the output schema in Architect to parse this response.- Output Schema:
{ "contactId": "string", "status": "string", "timestamp": "string", "recommendation": "string" }
- Output Schema:
Save the flow.
Step 5: Verify the Integration via API
To ensure the integration is working without triggering a live conversation, you can use the Genesys Cloud API to test the Serverless Integration. This endpoint invokes the Lambda function directly.
def test_serverless_integration(auth: GenesysAuth, integration_id: str):
Tests the Serverless Integration by invoking the Lambda function.
api_url = f"https://{auth.org_domain}.mypurecloud.com/api/v2/integrations/serverless/{integration_id}/invoke"
headers = {
# Simulate the input data that would come from the Architect flow
payload = {
"data": {
"contactId": "test-contact-123",
"queueName": "Premium Support",
"customerEmail": "test@example.com"
result = response.json()
print("Lambda Invocation Successful:")
print(json.dumps(result, indent=2))
# Check for Lambda errors
if result.get("statusCode") != 200:
print(f"Lambda returned error status: {result['statusCode']}")
print(f"Error Body: {result.get('body')}")
print(f"Failed to invoke integration: {response.status_code} - {response.text}")
if response.status_code == 403:
print("Check IAM Role permissions. The role may lack permissions to invoke the function or write logs.")
elif response.status_code == 404:
print("Integration ID not found. Ensure the integration was created successfully.")
# Example Usage
# test_serverless_integration(auth, integration_id)
Below is a complete Python script that combines authentication, integration creation, and testing. You must replace the placeholder values with your actual credentials and Lambda ARN.
import requests
import json
import sys
class GenesysLambdaIntegration:
self.base_url = f"https://{org_domain}.mypurecloud.com"
payload = {
headers = {
self.token_url,
data=payload,
headers=headers,
print(f"Authentication failed: {e}")
sys.exit(1)
def create_integration(self, function_arn: str, region: str, name: str) -> str:
token = self.get_token()
api_url = f"{self.base_url}/api/v2/integrations/serverless"
headers = {
payload = {
"name": name,
"type": "lambda",
"configuration": {
"region": region
"enabled": True
print("Integration already exists. Retrieving existing ID...")
# Fetch existing integrations to find the ID
list_response = requests.get(f"{self.base_url}/api/v2/integrations/serverless", headers=headers)
integrations = list_response.json().get("entities", [])
for integ in integrations:
if integ["name"] == name:
return integ["id"]
return None
elif response.status_code == 201:
return response.json().get("id")
else:
return None
def test_integration(self, integration_id: str) -> bool:
api_url = f"{self.base_url}/api/v2/integrations/serverless/{integration_id}/invoke"
headers = {
payload = {
"data": {
"contactId": "test-123",
"queueName": "Test Queue",
"customerEmail": "test@test.com"
if response.status_code == 200:
print("Success! Lambda Response:")
return True
else:
print(f"Invocation failed: {response.status_code} - {response.text}")
return False
# Configuration
CLIENT_ID = "YOUR_CLIENT_ID"
CLIENT_SECRET = "YOUR_CLIENT_SECRET"
ORG_DOMAIN = "YOUR_ORG_DOMAIN"
LAMBDA_ARN = "arn:aws:lambda:us-east-1:123456789012:function:GenesysCloudDataProcessor"
LAMBDA_REGION = "us-east-1"
INTEGRATION_NAME = "My Lambda Integration"
# Initialize
client = GenesysLambdaIntegration(CLIENT_ID, CLIENT_SECRET, ORG_DOMAIN)
# Step 1: Create Integration
integration_id = client.create_integration(LAMBDA_ARN, LAMBDA_REGION, INTEGRATION_NAME)
if integration_id:
print(f"Integration ID: {integration_id}")
# Step 2: Test Integration
client.test_integration(integration_id)
else:
print("Could not determine Integration ID.")
Error: 403 Forbidden (IAM Permissions)
- What causes it: The IAM Role attached to the Lambda function does not have sufficient permissions to execute the function, or the Genesys Cloud integration is misconfigured.
- How to fix it: Ensure the IAM Role has the
AWSLambdaBasicExecutionRolepolicy attached. If the Lambda accesses other services, add those permissions to the role. Verify that thefunctionArnin the Genesys Cloud integration exactly matches the Lambda ARN.
Error: 404 Not Found (Integration ID)
- What causes it: The integration ID provided in the Architect flow or API call does not exist.
- How to fix it: Use the
GET /api/v2/integrations/serverlessendpoint to list all available integrations and verify the ID. Ensure the integration is enabled (enabled: true).
Error: 500 Internal Server Error (Lambda Timeout)
- What causes it: The Lambda function exceeds its timeout duration.
- How to fix it: Increase the timeout setting in the Lambda configuration (via AWS Console or CLI). Ensure the Genesys Cloud Data Action is configured with a reasonable timeout value.
Error: Mismatched JSON Schema
- What causes it: The output JSON from the Lambda function does not match the schema defined in the Architect Data Action.
- How to fix it: Review the
bodyfield of the Lambda response. Ensure all keys in the JSON object correspond to the output variables defined in Architect. Missing keys will result in null values in the flow.
