Call lands on incoming VDN and strategy moves it to busy treatment VDN . While the music is being played out ,CTI link disconnects . Now URS keeps sending "requestroutecall " and T-server keeps responding with AttributeErrorCode 54(switch not connected). This continues till few minutes CTI link gets connected and call gets claered from VQ and deleted from URS .
The switch is avaya and vector of typical busy treatment VDN is :
1 sec silence
Adjunt route
announcement
music of 600 sec
default route
Is there a way to handle such scenarios where the call gets default routed immediately without continuing sending requestroutecalls.
Using the call_tracking option within URS will allow URS to delete the call if no confirmation is received from the treament routerequest within 60 seconds.
We have call_tracking option value as true and call_kpl_time as 60. Would be there be any other setting i should be checking . All stuck call clerance options are also set. We have 7.6 Genesys set up
IMHO there is no solution on Genesys side as Genesys can’t control the call if CTI link is down. Check with your Avaya experts if Avaya can take control over the call in case third party (CTI) application disconnects.
