Call Level Stats
I’m looking for a way to collect stats around individual calls. Some of the stats I’m looking to collect are:
  • hold time
  • talk time
  • number of transfers
  • number of times on hold
Is there a method to collect this information at the call level on the Genesys platform?
Use StatServer…
Basic stats already there
Read the StatServer user guide for further reference
Thanks for the quick reply cavagnaro!
Looking at the user guide I do not see an obvious way to query stats for a particular call. It seems like the stats server serves more of an aggregate function. Perhaps it’s possible to apply a filter rule based on ANI to get what I’m looking for but I’m not sold that it’s the optimal way to go about querying for stats of a single call.
Let’s say I have the call ID and other relevant metadata from raw call events. Can you describe to me how I would go about querying the stats server for information about said call?
Ah I see, what you need is then GIM, a full call detail recorder. StatServer is real Time only and feeds GIM.
I did not see a clear way to connect to GIM from the universal SDK. Do you have any additional insight as to how I may connect to GIM to retrieve individual call stats?
I did note that the SDK documentation has information around the history service which appears to return interaction information for a given contact. Is it possible that this may be an additional resource which contains the metrics I’m looking for?
There is no SDK for GIM, GIM is just a database (in short), so you can easily read the data directly from GIM database.
