our customer calls a number which routes internally to another group- it rings for about a minute and then they get a busy signal. Below is a snippet from the sipserver log that shows the busy - any idea why?:
07:44:10.330: Sending [0,UDP] 405 bytes to 10.30.243.242:5060 >>>>>
ACK sip:88599774892@10.92.243.242:5060 SIP/2.0
Via: SIP/2.0/UDP 10.94.159.45:5060;branch=z9hG4bK96F215F5-4695-4921-97CE-24079C79D085-179694
From: sip:2105079557@10.94.159.45:5060 ;tag=386ADA4B-D516-4399-B159-7ED3DA8AA348-72752
To: sip:88599774892@10.94.159.45:5060 ;tag=gK088487c3
Call-ID: 1CA5EF58-FD43-4816-A2C8-11BF7AD35DB4-43347@10.94.159.45
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
07:44:10.330: SipDialog: event CALLING_RESREJECT, t=1266336, s=9, r=5, m=0000000012e5fc28
07:44:10.330 SIPCONN(282608599774892): HandleSipDialogEvent(CALLING_RESREJECT)
07:44:10.330 SIPCONN(282608599774892): 1pcc event CALLING_RESREJECT
07:44:10.330 SIPCONN(282608599774892): ConvertResponse: 403
07:44:10.330 SIPCONN(282608599774892): ConvertResponse: no conversion configured for 403
07:44:10.330 SIPCONN(282608599774892): Failed to obtain Media Server ID
07:44:10.330: ExtSvc: Script parse failed, cannot find priority 102 to execute
07:44:10.330: ERROR: 10000004, GetInstruction(priority, instruction), SipExtendedServicesResult.cpp,901
07:44:10.330: ERROR: 10000004, SetNextInstruction(priority), SipExtendedServicesResult.cpp,990
07:44:10.330 SIPCONN(282608599774892): state e:4,p:2,s:6,c:8,rc:403,m:1
07:44:10.330 SIPCONN(6530): CheckUpdateTransferStatus: no original dialog
07:44:10.330 SIPPARTY(282608599774892): 16789829 verify update of party-connection state A-F
07:44:10.330 +++ CIFace::Event +++
+++ Pre-event +++
Type EventDestinationBusy
Devices: <6530/6530> <-/282608599774892> <-/->
Calls: 16782278/019102a0d93e5fd2/16782278.1125d420/c:2/r:0 0/none
Parties: D6530/6530.11608700-1125d420:1/l:1/r:0/Dialing,Active,Origination
X282608599774892/282608599774892.11606e40-1125d420:1/l:2/r:0/Alerting,Destination
none
Cause: Blocked/35, Info: 0
Flags: divert=0 hook=0 postCall=0 active=1 moveAll=1 callType=1 hideOtherPi=0 InternalOther=0
â Pre-event â
+++ DestBusy +++
â target state not compatible at line 1170
SetFailed: party 6530.11608700-1125d420:1, cause Blocked
@07 :44:10.3300 [0] 8.1.102.09 distribute_event: message EventDestinationBusy
AttributeEventSequenceNumber 0000000000069989
AttributeTimeinuSecs 330000
AttributeTimeinSecs 1494513850 (07:44:10)
AttributeExtensions [23] 00 01 01 00..
âBusinessCallâ 0
AttributeOtherDNRole 2
AttributeOtherDN â282608599774892â
AttributeThisDNRole 1
AttributeAgentID â38560â
AttributeThisDN â6530â
AttributeDNIS â88599774892â
AttributeUserData [160] 00 04 00 00..
âIW_CaseUidâ â47cb2bc6-d164-451b-976c-7b307e193c53â
âIW_BundleUidâ â4d52c48e-e136-4b55-b453-3562d178b835â
âCustomerSegmentâ âSHSVâ
âContactIdâ â0008GaBRP4EVBS7Dâ
AttributeCallUUID â39EDAO5G9L41DFO39TP55JK7EC0003UUâ
AttributeConnID 019102a0d93e5fd2
AttributeCallID 16782278
AttributePropagatedCallType 3
AttributeCallType 3
AttributeCallState 5
07:44:10.330 Int 04544 Interaction message âEventDestinationBusyâ generated
Kubig
May 18, 2017, 1:52pm
2
As you can see on SIP level there is a SIP 403 message. Unfortunately, from the fragment is not clear from what site the message coming.
i have the full sip logs - what should i look for before this to find the cause for the busy? Thank you!
ÂŹÂŹ Search for 403 error and follow WHOLE call flowâŚyou need to understand what you are doing. There is no magic answer. That is why logs exists.
the 403 happens just prior to that when it is applying a treatment. That announcement exists and plays except for the occasional busy that happens here.: I appreciate any assistance -
07:44:10.330 Trc 04541 RequestApplyTreatment received from [1328] (000000b8 URS_P 10.21.154.16:58013)
message RequestApplyTreatment
AttributeThisDN â000005000â
AttributeConnID 019102a0d93e5fed
AttributeTreatmentType 7 (TreatmentPlayAnnouncement)
AttributeTreatmentParms [84] 00 02 00 00..
âLANGUAGEâ âEnglish(US)â
âPROMPTâ(list) â1â(list) âINTERRUPTABLEâ 0
âIDâ 19999
AttributeExtensions [39] 00 01 00 00..
âNO_ANSWER_OVERFLOWâ â33333000005000â
AttributeReferenceID 425825
07:44:10.330 Int 04543 Interaction message âRequestApplyTreatmentâ received from 1328 (âURS_Pâ)
07:44:10.330 â created: CRequest@8c66030 RequestApplyTreatment-URS_P[1328]/425825
07:44:10.330: $+TLIB:CTI:Unknown:0:13773
07:44:10.330 +++ CIFace::Request +++
â new invoke
â thisCall by party
Parsed: RequestApplyTreatment
Numbers: +<000005000> -
Calls: 1125a890:1 none
Parties: 000005000.ccc05c0-1125a890:1
none
Status: parsed:1 queued:0 sent:0 acked:0 preevent:0 event:0 context:0 transferred:0
â validate
â state check: ok
CIFace: Sent CRequest@8c66030 RequestApplyTreatment-URS_P[1328]/425825
FinishRequest CRequest@8c66030 RequestApplyTreatment-URS_P[1328]/425825
IFace stats: q=0 s=0
â complete
07:44:10.330: free_dcr 0000000010cd9db0
07:44:10.330: SIPTR(94497): Begin step 0 - SipTransactionProcessMsml(94498)
07:44:10.330: free_dcr 0000000012357fb0
07:44:10.330 SIPCONN(PHX_GVP_8): CtiRequest(3)
07:44:10.330: SIPDLG[45500]: register TRN[1271596]
07:44:10.330: Sending [0,UDP] 913 bytes to 10.94.159.44:5090 >>>>>
INFO sip:Genesys@10.94.148.45:5170 SIP/2.0
From: sip:8043533260@10.92.243.242 ;tag=386ADA4B-D516-4399-B159-7ED3DA8AA348-72962
To: sip:PHX_GVP_8@10.94.159.45:5060 ;tag=D07FD391-9CB1-40AF-EEB5-D725DC154008
Call-ID: 1CA5EF58-FD43-4816-A2C8-11BF7AD35DB4-43495@10.94.159.45
CSeq: 7 INFO
Content-Length: 308
Content-Type: application/vnd.radisys.msml+xml
Via: SIP/2.0/UDP 10.94.159.45:5060;branch=z9hG4bK96F215F5-4695-4921-97CE-24079C79D085-181964
Contact: sip:8043533260@10.94.159.45:5060
Max-Forwards: 69
Route: sip:000000000D40DD20@10.94.159.44:5090;lr;gvp.rm.datanodes=1|2;idtag=0000131C
<?xml version="1.0" encoding="UTF-8"?>
07:44:10.330: SipDialog: event CONNECTED_SEND_REQUEST, t=1271596, s=7, r=6, m=0000000012e615d8
07:44:10.330 SIPCONN(PHX_GVP_8): HandleSipDialogEvent(CONNECTED_SEND_REQUEST) - filtered
â deleted: CRequest@13003320 RequestApplyTreatment-URS_P[1328]/425474
07:44:10.330 â CIFace::Request â
07:44:10.330: $-TLIB:CTI:Unknown:0:566
07:44:10.330: $+NET:SIP::0:0
07:44:10.330: SIPTR: Received [0,UDP] 387 bytes from 10.30.243.242:5060 <<<<<
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP 10.94.159.45:5060;branch=z9hG4bK96F215F5-4695-4921-97CE-24079C79D085-179694;received=10.94.148.24
CSeq: 1 INVITE
Content-Length: 0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
+++ Pre-event +++
none
â Pre-event â
+++ DestBusy +++
âBusinessCallâ 0
AttributeCallType 3
07:44:10.330 Trc 04542 EventDestinationBusy sent to [1772]
Forbidden, so it is trying to access something it doesnât has permission to read at. Check your security and permissions on you WAS.
