Call Generators
Thanks Wyn, Ill give it a try :slight_smile:
Hi All,
Just a quick update on BCG. I will be releasing a v2 in about a month that adds the following functionality:
*Support for upto 2000 simultaneous calls
*Calls can be predefined so that the same test scenarios can be repeated.
*Calls can have a predetermined length
*CDRs produced
It will of course be available for free download.
Wyn
Hi Wyn, could i get a copy of bcg as well. thank you.
Could you please send a copy of our BCG to: [email removed]?
thanks,
Johnathan
Hello
Is there anyway I could get a copy of the BCG app? If so, please send it to [email removed]. Thank you very much,
Could you also send a copy of our BCG to: [email removed]?
thanks,
Jelle
Could you also send a copy of your BCG to: [email removed]?
Kind regards,
Franklin.
Check out http://www.cyarasolutions.com/ I use them on all my projects since I found out about them. Their solution is great for Functional and Load Testing, but with a Business User friendly interface, which makes it a way better proposition than a Hammer as you don’t need a techie to set it up. The solution is also sold as a service, so there is also no CAPEX cost.
Their solution is also available to do Customer Experience monitoring. What they do is initiate a call every X minutes and record the customer experience (which can be replayed from their portal) and sent out a notification is a threshold is breached.
It’s really worth a try…
this sounds just like what i have been looking for,
Please could you send me over a copy,
thanks
Ross
[email removed]
I would really appreciate if you can send the copy of BCG tool to [email removed] and [email removed]
Thank you
I’d like a copy of BCG as well. My email is klincolnATemblemhealth.com
Kevin Lincoln
is it possible for me to get this tool also: [email removed]
Mihai
Could I also get a copy as well please: [email removed]
Thanks for your time and effort.
AHA
Could I get a copy of this awsome BCG. I have a need to stress test our VOIP server.
My email is [email removed]
Thank you so much in advance!
Arsalan
Hello Can some one send me a copy of the BCG my email is
[email removed]
appreciate it
Wyn,
Is the BCG still available at all? I would like to take a look at it if possible.
Jeff
If this is still a working project I’d like to take a look at the software,
send me a copy to [email removed]
Ross
If this is still a working project I’d like to a copy of the software,
Please send me a copy to [email removed]
Tony
Wow this is an old thread of mine.
Is the demand out there for me to re-do BGC?
PM me if you have comments.
Hi Adam,
Just stumbled upon you post while searching for call generators to test one of my CTI App.
Can I have copy of BCG ?
