Hi
I’m using SIP Server 8.0 with X-Lite 4.0, somehow the call always dropped at the 8th second. I went through the logs and noticed this:
Reason: SIP;description=“media stream error: 8008”
Any idea what’s this is about?
thanks in advance,
cp
Hi
thanks in advance,
cp
Hi cpoon,
This error means there are some troubles related to RTP stream. Is this error generated by Stream Manager?
PS. X-Lite 4.0 has not been officially tested with SIP Serve thus it might not work correctly. I would suggest you using supported SIP soft phone for testing…
