Call Blending implementation issue
Here we are trying to implement call blending service. Some years ago people tried but it didn’t work.
In our environment, we have a particular setup using 2 alcatel pabx in the same site, so it works like a multisite.
I was looking in the Genesys Guides and read that I should configure outbound service to redirect calls to the same vag as the inbound service.
I did that and the agents receive calls from both services, but with an issue. When the outbound call comes from PABX A and goes to an agent in PABX A, it goes OK, but if it goes to an agent in PABX B, it doesn´t recognize as an outbound call, not sending the calling list info.
When I check in Tserver log, I got the message, in the Delivered event: “CallTypeSet: can’t determine call type!! inbound call ??” and the AttributeCallType is 2 (inbound). In the Tserver from PABX A, it shows AttributeCallType 3 (outbound).
Does anyone have a clue to make the destination Tserver receives the correct call type?
We use here Genesys Solutions version 7.X (without much expectation for upgrade, unfortunately).
Thanks in Advance.
Try this:
propagated-call-type = true
Check for your TServer version if it does support it…I guess 7.6 doesn’t…but check last releases
If the call is generated by an OCS connected to TServer A only, you need to ensure that ISCC is properly configured to allow all UserData to be propagated when the call is transferred to Tserver B.
Fra
Cavagnaro,
The propagated-call-type I’ve already set up in the extrouter option tab … in the guide I read that this change takes effect immediately and didn’t work.
I saw the ISCC Overflow parameter in the switch Access Code General tab … this is the current setup:
  • Target Type : Target ISCC
  • Route Type: Direct Network Call ID
  • ISCC Protocol Parameters: direct-network-callid=ts-gcid
  • ISCC Call Overflow Parameters:
According to the TS Guide, it says to use match-callid,inbound-only=false in the Overflow Parameters, but it seems I need to restart TServer. Is it so?
Ah, ISCC overflow…that’s not a common feature, I’m not very familiar with it.
I suggest you read very carefully the ISCC/Call Overflow Feature and Configuring Multi-Site Support sections of the TServer guide.
Indeed, whenever you change ISCC, you need to restart your TServer.
Fra
Fra,
I’ve already read this sections a couple of times and to me it seems a good try, but my boss is afraid that this change could generate any issue in our common services, because I think that during the solution implementation, instead of configuring accordingly to the guide, people create workarounds in the solution …
So I’d like to know if someone here has ever had this kind of issue before and solved it …
I have done Multisite with ISCC and Alcatel and had no issues on production…but always on lab first where you can destroy everything…
I’d suggest to open a ticket on Genesys if you don’t have a lab as they will provide more details
Cavagnaro,
in your blending implementation did you use both the propagated-call-type=true and ISCC Call Overflow Parameters: match-callid settings?
I didn’t handle the overflow settings, just created the ISCC and this parameter. I do remember there was a very important difference betweeb G7 and G8 on this. G8 was much more effective
Now I think you’re right Cavagnaro: TServer 7.6 doesn´t support propagated-call-type. If this is true, does it means that I can’t implement a blending service using 2 PABX’s?
I took a look in the 7.6 Tserver A4400/OXE Deployment Guide and didn’t see the propagated-call-type option. Only in the Network T-Server for ISCP Configuration Options in the Genesys Wiki Page, that I suppose it’s for the latest version (8.x) and not necessarily is applied to mine (7.6).
“Now I think you are right” :wink: funny guy
You can implement it but with restrictions.
Sorry for taking so long to answer =)
I was successfull on implementing this with restrictions as you said, Cavagnaro. I have to use 2 vags (one for each pabx), and in CME script tab, set the condition “logged in PABX a/b”. For the same campaign I have to work with 2 campaign groups and vag’s, cause my version doesn´t support the propagated call type option, causing an error in tserver where it doesn´t know the call type and assumes it is a inbound call type.
Thanks for all the help!
ps: even here someone calls me “funny guy”. It’s the same thing at work and my kids at home =)
