Call attached data not displayed for Inbound call through Asterisk
I have integrated Asterisk to Genesys SIP Server and created sample IVR application which collects input from user and transfer it to agent. I used InteractionData block to attach the user input. When i call the IVR app from agent extension, the Interaction Workspace displays the user data in Case Data window (Internal Call). However, when i call the IVR app from Asterisk extension the user data not displayed in case data window. I could not attach complete sip logs. Please let me know what configuration are required to display call attached data to agent.
There are two connectionid created.
Logs for ConnectionID1
@18:06:18.5830 [0] 8.1.101.34 distribute_event: message EventRinging
	AttributeEventSequenceNumber	000000000000016d
	AttributeTimeinuSecs	583000
	AttributeTimeinSecs	1419856578 (18:06:18)
	AttributeExtensions	[38] 00 01 00 00..
		'OtherTrunkName'	'Trunk_To_Asterisk'
	AttributeThisDNRole	2
	AttributeThisDN	'647'
	AttributeANI	'328'
	AttributeDNIS	'647'
	AttributeCallUUID	'70PISC0MJ560NEEEBK73KPILOC00000G'
	AttributeConnID	006e0259ab160010
	AttributeCallID	16
	AttributePropagatedCallType	2
	AttributeCallType	2
	AttributeCallState	0
	AttributeOtherDNRole	1
	AttributeOtherDN	'328'
18:06:18.583 Int 04544 Interaction message "EventRinging" generated
     -- Cleanup call leg
  --- Ringing ---
  +++ Post-event +++
    Type EventRinging
    Devices: <647/647> <-/328> <-/->
    Calls: 16/006e0259ab160010/16.3093330/c:2/r:0 0/none
    Parties:	D647/647.327cab0-3093330:1/l:2/r:0/Alerting,Destination
    		X328/328.327cce0-3093330:1/l:1/r:0/Dialing,Origination
    		none
    Call type: Inbound/2
    Flags: divert=0 hook=0 postCall=0 active=1 moveAll=1 callType=1 hideOtherPi=0 InternalOther=0
  --- Post-event ---
18:06:18.583 --- CIFace::Event ---
18:06:18.583: SIPTR(214): complete
18:06:18.583: SIPTR(209): Step 4 - SipTransactionConnectNewParty(214) complete
18:06:18.583: SIPTR(209): complete
18:06:18.583: SIPCM: transaction SipScenario(209) complete
18:06:18.583: PI: 00 S[IN]D[328]C[*D[328]]P[647]
18:06:18.583: PI: 00 S[AN]D[647]C[*D[647]]P[328]
18:06:18.583: CALLSTATE(a:2,d:0,i:0,e:1,r:0,o:0)
18:06:18.583: call1 16 idle
18:06:18.583: $-NET:SIP::0:924
@18:06:18.6230 [0] 8.1.101.34 distribute_event: message EventEstablished
	AttributeEventSequenceNumber	000000000000016e
	AttributeTimeinuSecs	623000
	AttributeANI	'328'
	AttributeDNIS	'647'
	AttributeCallID	16
	AttributeCallType	2
18:06:18.623 Int 04544 Interaction message "EventEstablished" generated
     -- TellEstablished
    SetActive: party 647.327cab0-3093330:1, cause Null
     -- Cleanup call leg
  --- Established ---
  +++ Post-event +++
    Type EventEstablished
    Parties:	D647/647.327cab0-3093330:1/l:2/r:0/Established,Destination
    		X328/328.327cce0-3093330:1/l:1/r:0/Established,Origination
    		none
  --- Post-event ---
18:06:18.623 --- CIFace::Event ---
18:06:18.623 SIPCONN(647): NotifyOnComplete
18:06:18.623: $-NET:SIP::0:1047
@18:06:44.3080 [0] 8.1.101.34 distribute_event: message EventAttachedDataChanged
	AttributeEventSequenceNumber	000000000000016f
	AttributeTimeinuSecs	308000
	AttributeTimeinSecs	1419856604 (18:06:44)
	AttributeThirdPartyDN	'647'
	AttributeANI	'328'
	AttributeDNIS	'647'
	AttributeUserData	[184] 00 04 00 00..
		'GVP-Session-ID'	'BDABB232-6764-4BCA-71AD-F1D178A6F6A3;gvp.rm.datanodes=1;gvp.rm.tenant-id=1.101_Test_TestIVR'
		'PhoneNumber'	'9962484333'
		'TicketNumber'	'12345'
		'language'	'english'
	AttributeCallID	16
	AttributeCallType	2
18:06:44.308 Int 04544 Interaction message "EventAttachedDataChanged" generated
@18:06:44.3080 [ISCC] Updated call:
	i c:006e0259ab160010,00000000031d3fe0 @ m:0000000000000000,0000000000000000 p:2 i:00000010 nw:0000000000000000 t:2
	  p:0000000000000000,00000000025ff160 @ c:006e0259ab160010,00000000031d3fe0 r:1 ----- n:328:
	  p:0000000000000000,00000000025fe860 @ c:006e0259ab160010,00000000031d3fe0 r:2 ----- n:647:
@18:06:44.3080 [ISCC] UserData propagation has been started
@18:06:44.3080 [ISCC] UserData propagation has been finished
18:06:44.308  -- call_info::committed changed
18:06:44.308 SIPCONN(647): SendResponse(200,14853)
18:06:44.308: add party info '647' state 3.
18:06:44.308: Sending  [0,UDP] 643 bytes to 192.168.3.43:5060 >>>>>
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.3.43:5060;branch=z9hG4bK000000001B1D41B0a14adcabcdef09;received=192.168.3.43
Via: SIP/2.0/TCP 192.168.3.43:5070;branch=z9hG4bK00000000207A13A0a14adc
From: <sip:647@192.168.3.43:5080>;tag=202E2B17-C796-4293-94A6-3601AFE1C786
To: "Sourabh" <sip:328@192.168.3.25>;tag=14323D32-D1F1-498D-BF58-77BC3B17B7AD-52
CSeq: 1 INFO
Call-ID: EB254399-574A-46CD-BD1C-AEFBB35A7B40-24@192.168.3.43
Contact: <sip:328@192.168.3.43:5080>
X-Genesys-CallUUID: 70PISC0MJ560NEEEBK73KPILOC00000G
Allow: INVITE, ACK, PRACK, CANCEL, BYE, REFER, INFO, UPDATE, MESSAGE, NOTIFY, OPTIONS
Supported: uui
Content-Length: 0
@18:07:27.5120 [0] 8.1.101.34 distribute_event: message EventAttachedDataChanged
	AttributeEventSequenceNumber	000000000000018c
	AttributeTimeinuSecs	512000
	AttributeTimeinSecs	1419856647 (18:07:27)
	AttributeANI	'328'
	AttributeDNIS	'647'
	AttributeUserData	[201] 00 05 00 00..
		'__reason'	'exit'
	AttributeCallID	16
	AttributeCallType	2
18:07:27.512 Int 04544 Interaction message "EventAttachedDataChanged" generated
@18:07:27.5120 [ISCC] Updated call:
@18:07:27.5120 [ISCC] UserData propagation has been started
@18:07:27.5120 [ISCC] UserData propagation has been finished
18:07:27.512  -- call_info::committed changed
18:07:27.512 SIPCONN(647): SendResponse(200,14911)
18:07:27.512: add party info '647' state 3.
18:07:27.512: Sending  [0,UDP] 673 bytes to 192.168.3.43:5060 >>>>>
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.3.43:5060;branch=z9hG4bK000000001B1D4A20a14b07abcdef09;received=192.168.3.43
Via: SIP/2.0/TCP 192.168.3.43:5070;branch=z9hG4bK00000000205040F0a14b07
CSeq: 3 BYE
Server: Asterisk PBX 1.6.2.24
Supported: uui
Content-Length: 0
Log for connectionID2:
@18:06:57.5030 [0] 8.1.101.34 distribute_event: message EventQueued
	AttributeEventSequenceNumber	0000000000000170
	AttributeTimeinuSecs	503000
	AttributeTimeinSecs	1419856617 (18:06:57)
	AttributeExtensions	[59] 00 02 00 00..
		'BusinessCall'	1
	AttributeThisQueue	'8101'
	AttributeThisDN	'8101'
	AttributeANI	'328'
	AttributeDNIS	'8101'
	AttributeCallUUID	'70PISC0MJ560NEEEBK73KPILOC00000H'
	AttributeConnID	006e0259ab160011
	AttributeCallID	17
	AttributeCallType	2
18:06:57.503 Int 04544 Interaction message "EventQueued" generated
18:06:57.503 Trc 04542 EventQueued sent to [624] (00000006 URS 192.168.3.43:51453)
18:06:57.503 Trc 04542 EventQueued sent to [528] (00000003 StatServer 192.168.3.43:51406)
@18:06:57.5030 [0] 8.1.101.34 distribute_event: message EventRouteRequest
	AttributeEventSequenceNumber	0000000000000171
		'BusinessCall'	1
	AttributeANI	'328'
	AttributeCallID	17
	AttributeCallType	2
18:06:57.503 Int 04544 Interaction message "EventRouteRequest" generated
18:06:57.503 Trc 04542 EventRouteRequest sent to [624] (00000006 URS 192.168.3.43:51453)
18:06:57.503 Trc 04542 EventRouteRequest sent to [528] (00000003 StatServer 192.168.3.43:51406)
     -- Cleanup call leg
  --- Ringing ---
  +++ Post-event +++
    Type EventRouteRequest
    Devices: <8101/8101> <-/328> <-/->
    Calls: 17/006e0259ab160011/17.31c0b80/c:2/r:0 0/none
    Parties:	D8101/8101.327cf10-31c0b80:1/l:2/r:0/Queued,RtRequest,Destination
    		X328/328.327c650-31c0b80:1/l:1/r:0/Dialing,Origination
    		none
  --- Post-event ---
18:06:57.503 --- CIFace::Event ---
18:06:57.503 SIPCONN(328): SendResponse(180,14871)
18:06:57.503: add party info '328' state 1.
18:06:57.503: Sending  [0,UDP] 454 bytes to 192.168.3.25:5060 >>>>>
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 192.168.3.25:5060;branch=z9hG4bK6d717087;rport;received=192.168.3.25
From: "Sourabh" <sip:328@192.168.3.25>;tag=as075dea9e
To: <sip:8101@192.168.3.43:5080>;tag=14323D32-D1F1-498D-BF58-77BC3B17B7AD-53
Call-ID: 50a29d01189ea04b1d89c6d449144c5b@192.168.3.25
CSeq: 102 INVITE
X-Genesys-CallUUID: 70PISC0MJ560NEEEBK73KPILOC00000H
Allow: INVITE, ACK, PRACK, CANCEL, BYE, UPDATE
Supported: uui
Content-Length: 0
18:06:57.503: SipDialog: event CALLED_RESPROV, t=14871, s=1, r=11, m=00000000031d8448
18:06:57.503 SIPCONN(328): HandleSipDialogEvent(CALLED_RESPROV) - filtered
18:06:57.503: SIPTR(230): complete
18:06:57.503: SIPTR(225): Step 4 - SipTransactionConnectNewParty(230) complete
18:06:57.503: SIPTR(225): complete
18:06:57.503: SIPCM: transaction SipScenario(225) complete
18:06:57.503: PI: 00 S[IN]D[328]C[*D[328]]P[-]
18:06:57.503: PI: 00 S[QN]D[8101]E[-]
18:06:57.503: call1 17 idle
18:06:57.503: $-NET:SIP::0:2365
@18:06:57.5130 [0] 8.1.101.34 distribute_response: message EventAttachedDataChanged
	AttributeEventSequenceNumber	0000000000000175
	AttributeTimeinuSecs	513000
	AttributeReferenceID	47
	AttributeThirdPartyDN	'8101'
	AttributeANI	'328'
	AttributeUserData	[78] 00 02 00 00..
		'RTargetAgentGroup'	'AgentGroup1'
		'RPVQID'	'DRAIBV7K2D14R5KMJEHH93URTO000007'
	AttributeCallID	17
	AttributeCallType	2
18:06:57.513 Int 04544 Interaction message "EventAttachedDataChanged" generated
18:06:57.513 Trc 04542 EventAttachedDataChanged sent to [624] (00000006 URS 192.168.3.43:51453)
18:06:57.513 Trc 04542 EventAttachedDataChanged sent to [528] (00000003 StatServer 192.168.3.43:51406)
@18:06:57.5130 [ISCC] Updated call:
	i c:006e0259ab160011,00000000032186c0 @ m:0000000000000000,0000000000000000 p:2 i:00000011 nw:0000000000000000 t:2
	  p:0000000000000000,00000000025fea60 @ c:006e0259ab160011,00000000032186c0 r:1 ----- n:328:
	  p:0000000000000000,00000000025fef60 @ c:006e0259ab160011,00000000032186c0 r:2 ----- n:8101:
@18:06:57.5130 [ISCC] UserData propagation has been started
@18:06:57.5130 [ISCC] UserData propagation has been finished
18:06:57.513  -- call_info::committed changed
18:06:57.513  -- created: CRequest@3284ab0 RequestUpdateUserData-URS[624]/47
18:06:57.513: $+TLIB:CTI:Unknown:0:403
18:06:57.513  -- deleted: CRequest@3284ab0 RequestUpdateUserData-URS[624]/47
18:06:57.513: $-TLIB:CTI:Unknown:0:8
@18:06:57.5630 [0] 8.1.101.34 distribute_response: message EventRouteUsed
	AttributeEventSequenceNumber	000000000000017e
	AttributeTimeinuSecs	563000
		'BusinessCall'	1
	AttributeReason	[14] 00 01 01 00..
		'RTR'	114
	AttributeReferenceID	50
	AttributeThirdPartyDNRole	2
	AttributeThirdPartyDN	'1001'
	AttributeANI	'328'
	AttributeUserData	[656] 00 18 00 00..
		'RVQID'	'DRAIBV7K2D14R5KMJEHH93URTO000007'
		'RVQDBID'	'114'
		'RTargetTypeSelected'	'2'
		'RTargetRuleSelected'	''
		'RTargetObjectSelected'	'AgentGroup1'
		'RTargetObjSelDBID'	'106'
		'RTargetAgentSelected'	'1399'
		'RTargetPlaceSelected'	'Desk1'
		'RTenant'	'TestLab'
		'RStrategyName'	'Test_Strategy'
		'RStrategyDBID'	'103'
		'CBR-actual_volume'	''
		'CBR-Interaction_cost'	''
		'CBR-contract_DBIDs'	''
		'CBR-IT-path_DBIDs'	''
		'RRequestedSkillCombination'	''
		'RRequestedSkills'(list)
		'RTargetRequested'	'AgentGroup1'
		'CustomerSegment'	'default'
		'ServiceType'	'default'
		'ServiceObjective'	''
		'PegAGAgentGroup1'	1
	AttributeCallID	17
	AttributeCallType	2
18:06:57.563 Int 04544 Interaction message "EventRouteUsed" generated
18:06:57.563 Trc 04542 EventRouteUsed sent to [624] (00000006 URS 192.168.3.43:51453)
18:06:57.563 Trc 04542 EventRouteUsed sent to [528] (00000003 StatServer 192.168.3.43:51406)
     -- Cleanup call leg
  --- Diverted ---
  +++ Post-event +++
    Type EventRouteUsed
    Devices: <8101/8101> <1001/1001> <-/->
    Calls: 17/006e0259ab160011/17.31c0b80/c:2/r:2 0/none
    Parties:	D8101/8101.327cf10-31c0b80:1/l:2/r:2/Queued,Destination
    		D1001/1001.327d140-31c0b80:1/l:2/r:0/Null,DNull,Destination
    		none
    Cause: Distributed/38, Info: 0
    Flags: divert=0 hook=0 postCall=0 active=1 moveAll=1 callType=1 hideOtherPi=0 InternalOther=1
  --- Post-event ---
18:06:57.563 --- CIFace::Event ---
18:06:57.563  -- thisCall by party
18:06:57.563: Adding OtherTrunkName(Trunk_To_Asterisk): done
18:06:57.563 ClearContext: party 8101.327cf10-31c0b80:1
18:06:57.563 +++ CIFace::Event +++
  +++ Pre-event +++
    Type EventDiverted
    		none
  --- Pre-event ---
  +++ Diverted +++
    DoDivert: from 8101.327cf10-31c0b80:1 to 1001.327d140-31c0b80:1 cause Distributed
@18:06:57.5630 [0] 8.1.101.34 distribute_event: message EventDiverted
	AttributeEventSequenceNumber	000000000000017f
		'BusinessCall'	1
	AttributeANI	'328'
		'RVQDBID'	'114'
		'RTenant'	'TestLab'
	AttributeCallID	17
	AttributeCallType	2
18:06:57.563 Int 04544 Interaction message "EventDiverted" generated
18:06:57.563 Trc 04542 EventDiverted sent to [624] (00000006 URS 192.168.3.43:51453)
18:06:57.563 Trc 04542 EventDiverted sent to [528] (00000003 StatServer 192.168.3.43:51406)
    inherit_queues: from 25fef60 to 25ff260
     -- party_info 8101.25fef60 state change: from <Queued> to <Null>
@18:06:57.5630 [ISCC] Party removed [ssp view]:
	@ c:006e0259ab160011,00000000032186c0 @ m:0000000000000000,0000000000000000,0000000000000000 p:3 i:00000011 nw:00000000:0000000000000000 t:2
	  p:00000000025fea60 @ c:006e0259ab160011,00000000032186c0 r:1 t:1 s:1000c n:328
	- p:00000000025fef60 @ c:006e0259ab160011,00000000032186c0 r:2 t:0 s:0 n:8101
	  p:00000000025ff260 @ c:006e0259ab160011,00000000032186c0 r:2 t:0 s:0 n:1001
@18:06:57.5630 [ISCC] Party removed:
	@ c:006e0259ab160011,00000000032186c0 @ m:0000000000000000,0000000000000000 p:2 i:00000011 nw:0000000000000000 t:2
	- p:0000000000000000,00000000025fef60 @ c:006e0259ab160011,00000000032186c0 r:2 ----- n:8101:
@18:06:57.5630 [ISCC] Party object is removed: p:0000000000000000,0000000000000000 n:8101:
  --- Diverted ---
  +++ Post-event +++
    Type EventDiverted
    Calls: 17/006e0259ab160011/17.31c0b80/c:1/r:2 0/none
    Parties:	D8101/8101.327cf10-31c0b80:1/l:2/r:2/Released,Destination
    		none
  --- Post-event ---
18:06:57.563: check call postponed until end of operation
18:06:57.563 SIPCONN(328): 18x response, state 1,1,0,0,1
18:06:57.563 SIPCONN(328): SendResponse(180,14871)
18:06:57.563: add party info '328' state 1.
18:06:57.563: Sending  [0,UDP] 514 bytes to 192.168.3.25:5060 >>>>>
SIP/2.0 180 Ringing
CSeq: 102 INVITE
User-Agent: X-Lite release 4.7.0 stamp 73589 2047bcfc-W6.1
Supported: uui
Content-Length: 0
Who attach the KVP/Case Data - strategy, IVR app or agent application? Be more specific please.
IVR app
And IVR is on Genesys level? As I wrote, be more specific in your description. No one has crystal ball. In your fragment of logs, in second case, I did not see any attach data from GVP application.
The IVR is on Genesys level. In SIP server application, under TServer options i have the following options configured related to userdata.
  1. userdata-map-all-calls: true
  2. userdata-map-trans-prefix: X-Genesys-
  3. merged-user-data: main-over-merged
  4. consult-user-data: seperate
Environment
  1. Genesys SIP Server 8.1
  2. GVP 8.5
  3. URS 8.1
  4. Asterisk pbx (Integrated with Genesys, Asterisk simply forward the call to genesys DID which is mapped to IVR profile)
Call Flow:
  1. Dial Extn (647) from Asterisk extension forwards the call to Genesys DID 647 which are mapped to IVR profile
  2. Genesys IVR collects inputs from user & used InteractionData block to attach the user data.
  3. The call will be transferred to Routing Point (8101) where i loaded strategy to route call to AgentGroup1 if any agents are in Ready State.
Post fragment of SIP server log covering the updating of userdata from GVP for both case (good and bad).
Is there anything specific configuration required in SIP Server to resolve this problem? Which document do i need to refer?
Just deployment guide for SIP server. All depends on how to you attach data from VXML application - if through CTI or through SIP INFO messages, etc.
