Is there a way to determine if a call was answered by an agent without adding functions after all TargetObjests in the strategy. I would like something that behaves like onCallAbandoned. Please help me here
thx
thx
You can create a strategy that you can load on the extension of the agent.
Just create a URServer section in the Annex tab of the extension and then create “event_arrive = ringing” and then “strategy = name_Of_Your_Strategy”.
In the strategy, you will be able to attach data and then to use them in reporting.
Thanks for the reply, but this is not a solution for me… It will be a lot easier for me add functions after each TargetObject than adding extra strategies on specific Agent DNs (Note: I don’t even have a fixed enviroment to do this).
Thx
lol, the solution is good, even on non fix enviroment what changes is the agent position where they login, not the extension (places) unless your PBX numbering plan changes every week.
Not sure what you’re looking for here…Where do you want to display the answered event ? Is it using CCPulse, update some UData and write to database etc ?
