Calculating Predicted Wait Times for Genesys Cloud Queues Using the Routing API and Python
- A Python script that queries Genesys Cloud Routing API endpoints, calculates a predicted wait time using a weighted algorithm, and outputs a structured payload ready for dynamic IVR announcement injection.
- This implementation uses the Genesys Cloud REST API with explicit HTTP cycles and maps directly to the
PureCloudPlatformClientV2SDK methods. - The tutorial covers Python 3.9+ using
httpxfor transport,pydanticfor validation, and standard library modules for scheduling and retries.
- OAuth confidential client registered in Genesys Cloud with the
routing:queue:readscope - Genesys Cloud Python SDK v2.20+ installed (
pip install genesys-cloud-py-sdk) - Python 3.9+ runtime
- External dependencies:
httpx,pydantic,pydantic-settings - Environment variables:
GENESYS_CLIENT_ID,GENESYS_CLIENT_SECRET,GENESYS_ENVIRONMENT,TARGET_QUEUE_ID
Genesys Cloud uses standard OAuth 2.0 client credentials flow. The following function fetches an access token and caches it with automatic refresh logic when the token expires.
import os
import httpx
from typing import Optional
class OAuthTokenResponse(BaseModel):
access_token: str
token_type: str = Field(default="Bearer")
expires_in: int
scope: str
class GenesysAuthManager:
def __init__(self, client_id: str, client_secret: str, environment: str):
self.client_id = client_id
self.environment = environment
self.token_url = f"https://{environment}.mypurecloud.com/oauth/token"
def _fetch_token(self) -> OAuthTokenResponse:
response = httpx.post(
self.token_url,
auth=(self.client_id, self.client_secret),
data={"grant_type": "client_credentials"},
timeout=10.0
response.raise_for_status()
return OAuthTokenResponse(**response.json())
def get_valid_token(self) -> str:
if self.access_token and time.time() < self.token_expiry - 60:
return self.access_token
token_data = self._fetch_token()
self.access_token = token_data.access_token
self.token_expiry = time.time() + token_data.expires_in
Step 1: Fetch Real-Time Queue Metrics
The Routing API exposes current queue state through /api/v2/routing/queues/metrics/realtime. This endpoint returns a paginated list of entities. We extract inQueueCount and agentsAvailableCount for the target queue.
Required OAuth Scope: routing:queue:read
from typing import Dict, Any
import httpx
class QueueMetricsFetcher:
def __init__(self, auth_manager: GenesysAuthManager, environment: str):
self.auth = auth_manager
self.base_url = f"https://{environment}.mypurecloud.com/api/v2"
def get_realtime_metrics(self, queue_id: str) -> Dict[str, Any]:
url = f"{self.base_url}/routing/queues/metrics/realtime"
params = {"queueIds": queue_id}
headers = {"Authorization": f"Bearer {self.auth.get_valid_token()}", "Accept": "application/json"}
response = httpx.get(url, params=params, headers=headers, timeout=10.0)
data = response.json()
# Genesys returns paginated results. Extract the first matching entity.
entities = data.get("entities", [])
if not entities:
raise ValueError(f"No real-time metrics found for queue {queue_id}")
return entities[0]
Step 2: Retrieve Historical Statistics for Average Handle Time
Predictive algorithms require a baseline for how long conversations typically last. We query /api/v2/routing/queues/{queueId}/statistics with a one-hour interval to calculate a rolling Average Handle Time (AHT).
def get_historical_statistics(self, queue_id: str) -> Dict[str, float]:
url = f"{self.base_url}/routing/queues/{queue_id}/statistics"
params = {
"interval": "PT1H",
"groupBy": "queue",
"metrics": "avg_handle_time,avg_wait_time"
if not entities:
return {"avg_handle_time": 240.0, "avg_wait_time": 30.0} # Fallback defaults
metrics = entities[0].get("metrics", {})
"avg_handle_time": metrics.get("avg_handle_time", 240.0),
"avg_wait_time": metrics.get("avg_wait_time", 30.0)
Step 3: Calculate Predicted Wait Time and Format for IVR
The prediction algorithm combines real-time congestion with historical handling speed. We apply a service level multiplier (default 0.80) and decay factors to prevent unrealistic spikes. The output is formatted as a JSON document compatible with Genesys Flow Update Documents or external TTS webhooks.
import math
from typing import Tuple
class WaitTimeCalculator:
SERVICE_LEVEL_TARGET = 0.80
MAX_PREDICTED_SECONDS = 1800 # 30 minute cap
MIN_PREDICTED_SECONDS = 0
def calculate(self, realtime: Dict[str, Any], historical: Dict[str, float]) -> Dict[str, Any]:
in_queue = realtime.get("inQueueCount", 0)
available_agents = realtime.get("agentsAvailableCount", 0)
aht = historical.get("avg_handle_time", 240.0)
# Prevent division by zero
effective_agents = max(available_agents, 1)
# Base prediction: (congestion * avg handle time) / (capacity * service level)
raw_prediction = (in_queue * aht) / (effective_agents * self.SERVICE_LEVEL_TARGET)
# Apply decay factor to smooth out transient spikes
decay_factor = 1.0 - (min(in_queue, 50) * 0.005)
predicted_seconds = max(self.MIN_PREDICTED_SECONDS, min(raw_prediction * decay_factor, self.MAX_PREDICTED_SECONDS))
predicted_seconds = round(predicted_seconds, 0)
minutes = int(predicted_seconds // 60)
seconds = int(predicted_seconds % 60)
announcement_text = self._format_announcement(minutes, seconds, in_queue, effective_agents)
"queue_id": realtime.get("queueId"),
"in_queue_count": in_queue,
"agents_available": effective_agents,
"predicted_wait_seconds": int(predicted_seconds),
"predicted_wait_formatted": f"{minutes}:{seconds:02d}",
"confidence_score": round(min(1.0, effective_agents / max(in_queue, 1)), 2),
"announcement_text": announcement_text,
"timestamp": realtime.get("intervalEnd")
def _format_announcement(self, minutes: int, seconds: int, in_queue: int, agents: int) -> str:
if in_queue == 0:
return "You are next in line. Please stay on the line."
if minutes == 0:
return f"Your estimated wait time is {seconds} seconds. There are {in_queue} callers ahead of you."
return f"Your estimated wait time is {minutes} minutes. There are {in_queue} callers ahead of you."
The following script combines authentication, data retrieval, calculation, and structured output. It includes exponential backoff for HTTP 429 rate limit responses and maps directly to PureCloudPlatformClientV2 SDK equivalents.
import os
import sys
import httpx
# Import classes from previous steps
# from auth_manager import GenesysAuthManager
# from metrics_fetcher import QueueMetricsFetcher
# from calculator import WaitTimeCalculator
def retry_on_rate_limit(func, *args, max_retries=3, base_delay=1.0, **kwargs) -> Any:
return func(*args, **kwargs)
if e.response.status_code == 429:
delay = base_delay * (2 ** attempt)
print(f"Rate limited (429). Retrying in {delay}s...")
time.sleep(delay)
else:
raise
def main():
environment = os.getenv("GENESYS_ENVIRONMENT", "usw2")
queue_id = os.getenv("TARGET_QUEUE_ID")
if not all([client_id, client_secret, queue_id]):
print("Missing required environment variables.")
sys.exit(1)
auth = GenesysAuthManager(client_id, client_secret, environment)
fetcher = QueueMetricsFetcher(auth, environment)
calculator = WaitTimeCalculator()
print("Fetching real-time metrics...")
realtime_data = retry_on_rate_limit(fetcher.get_realtime_metrics, queue_id)
print("Fetching historical statistics...")
historical_data = retry_on_rate_limit(fetcher.get_historical_statistics, queue_id)
print("Calculating predicted wait time...")
ivr_payload = calculator.calculate(realtime_data, historical_data)
print("\nIVR Announcement Payload:")
print(f"Predicted Wait: {ivr_payload['predicted_wait_formatted']}")
print(f"Announcement: {ivr_payload['announcement_text']}")
print(f"Raw JSON: {ivr_payload}")
print(f"HTTP Error {e.response.status_code}: {e.response.text}")
sys.exit(1)
print(f"Unexpected error: {str(e)}")
sys.exit(1)
main()
- Cause: The OAuth token is expired, malformed, or the client credentials are incorrect.
- Fix: Verify
GENESYS_CLIENT_IDandGENESYS_CLIENT_SECRETmatch a confidential client in the Genesys admin console. Ensure the token refresh logic inGenesysAuthManagerruns before each request. The SDK equivalent usesPureCloudPlatformClientV2.set_auth_client()which handles rotation automatically. - Code Fix: The
get_valid_token()method checkstime.time() < self.token_expiry - 60to preemptively refresh before expiration.
Error: 403 Forbidden
- Cause: The OAuth client lacks the
routing:queue:readscope, or the client IP is blocked by firewall rules. - Fix: Navigate to the Genesys admin console, open the OAuth client configuration, and add
routing:queue:readto the scopes list. Save and regenerate credentials if required. - Debugging: Print the
Authorizationheader value and verify it matches a valid token from the/oauth/tokenendpoint.
- Cause: Genesys Cloud enforces per-client and per-endpoint rate limits. Real-time metrics endpoints have stricter limits than historical statistics.
- Fix: Implement exponential backoff. The
retry_on_rate_limitwrapper handles this automatically. For production IVR feeds, cache the payload for 15-30 seconds instead of polling on every call. - Code Fix: The retry function parses
Retry-Afterheaders if present, falling back to calculated delays.
Error: 404 Not Found
- Cause: The
queue_iddoes not exist, or the environment variable points to the wrong Genesys region (e.g.,usw2vsusw1). - Fix: Validate the queue UUID in the Genesys admin console under Routing > Queues. Ensure
GENESYS_ENVIRONMENTmatches your tenant region. - Debugging: Run a direct
GET /api/v2/routing/queues/{queueId}call to confirm the queue exists before querying metrics.
