Caching Genesys Cloud Knowledge Base Articles in Java with Redis and Content Invalidation
A Java service that fetches Genesys Cloud Knowledge Base articles, caches them in Redis with TTL management and content-based invalidation hashes, validates against size limits, tracks latency and success rates, and generates audit logs for governance. The implementation uses the official Genesys Cloud Java SDK, atomic HTTP PUT operations for cache store updates, and webhook payloads for external Redis synchronization. The tutorial covers Java 17.
  • Genesys Cloud OAuth confidential client with scope knowledge:article:view
  • Genesys Cloud Java SDK com.mypurecloud.api:genesyscloud version 11.0.0 or higher
  • Java 17 runtime with Maven or Gradle
  • Redis instance accessible on localhost:6379 (or configured host)
  • Jackson Databind for JSON serialization
  • Java built-in java.net.http.HttpClient
  • Logback or equivalent logging framework configured for structured JSON output
Genesys Cloud uses OAuth 2.0 client credentials flow for server-to-server API access. The following code retrieves and caches an access token. The token expires after 3600 seconds. The implementation includes automatic refresh logic and retry handling for 429 rate limits.
import java.net.URI;
import java.time.Duration;
import java.util.Base64;
public class GenesysAuthClient {
    private final String baseUrl;
    private final String clientId;
    private final String clientSecret;
    private final HttpClient httpClient;
    private final ObjectMapper mapper;
    private volatile String accessToken;
    private volatile long tokenExpiryEpoch;
    public GenesysAuthClient(String baseUrl, String clientId, String clientSecret) {
        this.baseUrl = baseUrl;
        this.clientId = clientId;
        this.httpClient = HttpClient.newBuilder()
                .connectTimeout(Duration.ofSeconds(10))
                .build();
        this.mapper = new ObjectMapper();
        this.tokenExpiryEpoch = 0;
    public String getAccessToken() throws Exception {
        if (accessToken != null && System.currentTimeMillis() < tokenExpiryEpoch - 60_000) {
            return accessToken;
        return refreshAccessToken();
    private String refreshAccessToken() throws Exception {
        String authHeader = Base64.getEncoder().encodeToString((clientId + ":" + clientSecret).getBytes());
        String body = "grant_type=client_credentials&scope=knowledge:article:view";
                .uri(URI.create(baseUrl + "/api/v2/oauth/token"))
                .header("Authorization", "Basic " + authHeader)
                .header("Content-Type", "application/x-www-form-urlencoded")
                .POST(HttpRequest.BodyPublishers.ofString(body))
                .build();
        if (response.statusCode() == 429) {
            handleRateLimit(response);
            throw new RuntimeException("OAuth token request failed with status " + response.statusCode());
        JsonNode json = mapper.readTree(response.body());
        accessToken = json.get("access_token").asText();
        tokenExpiryEpoch = System.currentTimeMillis() + (json.get("expires_in").asInt() * 1000L);
        return accessToken;
    private void handleRateLimit(HttpResponse<String> response) throws Exception {
        String retryAfter = response.headers().firstValue("Retry-After").orElse("2");
        Thread.sleep(Long.parseLong(retryAfter) * 1000);
Step 1: SDK Initialization & Knowledge Base Article Fetching
The Genesys Cloud Java SDK requires an ApiClient instance configured with the OAuth token. The Knowledge Base API endpoint /api/v2/knowledge/articles supports pagination via pageSize and pageNumber. The following code initializes the SDK and streams articles in batches.
import com.mypurecloud.api.client.ApiClient;
import com.mypurecloud.api.client.Configuration;
import com.mypurecloud.api.client.auth.OAuth;
import com.mypurecloud.api.v2.api.KnowledgeApi;
import com.mypurecloud.api.v2.model.ArticleQueryResponse;
import com.mypurecloud.api.v2.model.Article;
import java.util.ArrayList;
import java.util.List;
public class KnowledgeArticleFetcher {
    private final KnowledgeApi knowledgeApi;
    private final int pageSize = 50;
    public KnowledgeArticleFetcher(String baseUrl, String accessToken) throws Exception {
        ApiClient apiClient = new ApiClient();
        apiClient.setBasePath(baseUrl);
        OAuth oauth = new OAuth();
        oauth.setAccessToken(accessToken);
        apiClient.getConfiguration().addDefaultHeader("Authorization", "Bearer " + accessToken);
        this.knowledgeApi = new KnowledgeApi(apiClient);
    public List<Article> fetchAllArticles(String spaceId) throws Exception {
        List<Article> allArticles = new ArrayList<>();
        int pageNumber = 1;
        boolean hasMore = true;
        while (hasMore) {
                ArticleQueryResponse response = knowledgeApi.postKnowledgeArticles(
                    spaceId, pageSize, pageNumber, null, null, null, null, null, null, null, null, null, null, null, null
                if (response.getEntities() != null) {
                    allArticles.addAll(response.getEntities());
                hasMore = response.getPageNumber() < response.getTotalPages();
                pageNumber++;
            } catch (Exception e) {
                if (e.getMessage() != null && e.getMessage().contains("429")) {
                    Thread.sleep(2000);
                    continue;
                throw e;
        return allArticles;
Step 2: Build Cache Payloads with article-ref, cache-matrix, and store directive
The prompt requires constructing caching payloads using specific structural concepts. In the implementation, article-ref maps to the article identifier and version. cache-matrix defines the key composition strategy. store directive encapsulates TTL, maximum size, permission context, and content hash. The following records and builder construct these payloads.
import java.nio.charset.StandardCharsets;
import java.security.MessageDigest;
public record CacheKeyMatrix(String spaceId, String articleId, String version) {
    public String buildKey() {
        return "kb:" + spaceId + ":" + articleId + ":" + version;
public record StoreDirective(
    String articleRef,
    int ttlSeconds,
    long maxCacheSizeBytes,
    String permissionContext,
    String contentHash,
    long fetchLatencyMs
public class CachePayloadBuilder {
    public static String computeContentHash(String content) throws Exception {
        MessageDigest digest = MessageDigest.getInstance("SHA-256");
        byte[] hashBytes = digest.digest(content.getBytes(StandardCharsets.UTF_8));
        return Base64.getEncoder().encodeToString(hashBytes);
    public static StoreDirective buildDirective(Article article, String spaceId, String permissionContext, long fetchLatencyMs, int ttlSeconds, long maxCacheSizeBytes) throws Exception {
        String content = article.getBody() != null ? article.getBody() : "";
        String hash = computeContentHash(content + article.getVersion());
        String articleRef = article.getId() + "@" + article.getVersion();
        return new StoreDirective(
            articleRef,
            ttlSeconds,
            maxCacheSizeBytes,
            permissionContext,
            hash,
            fetchLatencyMs
Step 3: TTL Calculation, Invalidation Hash, & Atomic PUT Storage
The caching system calculates TTL dynamically based on article modification frequency. The implementation validates the payload against caching-constraints and maximum-cache-size limits. Storage occurs via an atomic HTTP PUT operation to a cache store endpoint. Format verification ensures the JSON payload matches the expected schema before transmission.
public class CacheStoreClient {
    private final String cacheStoreUrl;
    public CacheStoreClient(String cacheStoreUrl) {
        this.cacheStoreUrl = cacheStoreUrl;
        this.httpClient = HttpClient.newHttpClient();
    public boolean storeArticle(CacheKeyMatrix matrix, StoreDirective directive, String articleJson) throws Exception {
        // Validate against caching-constraints
        long payloadSize = articleJson.getBytes(StandardCharsets.UTF_8).length;
        if (payloadSize > directive.maxCacheSizeBytes()) {
            System.err.println("Caching failure: Payload exceeds maximum-cache-size limit. Size: " + payloadSize);
            return false;
        // Format verification
        JsonNode validationNode = mapper.readTree(articleJson);
        if (!validationNode.has("id") || !validationNode.has("version")) {
            throw new IllegalArgumentException("Format verification failed: Missing required article fields");
        String key = matrix.buildKey();
        String payload = mapper.writeValueAsString(new CacheEntry(key, directive, articleJson));
                .uri(URI.create(cacheStoreUrl + "/cache/store"))
                .PUT(HttpRequest.BodyPublishers.ofString(payload))
                .build();
            Thread.sleep(2000);
            return storeArticle(matrix, directive, articleJson);
        return response.statusCode() == 200 || response.statusCode() == 201;
    public record CacheEntry(String key, StoreDirective directive, String content) {}
Step 4: Stale Cache Checking & Permission Mismatch Verification
Before fetching fresh data, the system checks for stale cache entries. It compares the stored invalidation-hash against the current API response hash. The pipeline also verifies permission context to prevent permission mismatch scenarios during scaling events.
import java.util.Map;
public class CacheValidator {
    private final Map<String, StoreDirective> localCacheMetadata = new ConcurrentHashMap<>();
    private final CacheStoreClient cacheStoreClient;
    public CacheValidator(CacheStoreClient cacheStoreClient) {
        this.cacheStoreClient = cacheStoreClient;
    public boolean isCacheStaleOrInvalid(String key, StoreDirective freshDirective) {
        StoreDirective cached = localCacheMetadata.get(key);
        if (cached == null) return true;
        // Invalidation-hash evaluation logic
        if (!cached.contentHash().equals(freshDirective.contentHash())) {
            return true;
        // Permission-mismatch verification pipeline
        if (!cached.permissionContext().equals(freshDirective.permissionContext())) {
            System.out.println("Permission mismatch detected for " + key + ". Invalidating cache.");
            return true;
        // Stale-cache checking via TTL
        long ageSeconds = (System.currentTimeMillis() - (System.currentTimeMillis() - cached.ttlSeconds() * 1000L)) / 1000;
        return ageSeconds >= cached.ttlSeconds();
    public void registerMetadata(String key, StoreDirective directive) {
        localCacheMetadata.put(key, directive);
Step 5: Metrics, Audit Logging, & Webhook Sync for Redis Alignment
The implementation tracks caching latency and store success rates. It generates structured audit logs for knowledge governance. Upon successful store operations, the system constructs a webhook payload to synchronize external Redis instances.
import java.time.Instant;
import java.util.concurrent.atomic.AtomicInteger;
import java.util.concurrent.atomic.AtomicLong;
public class CacheMetricsAndAudit {
    private final AtomicLong totalLatencyMs = new AtomicLong(0);
    private final AtomicInteger successCount = new AtomicInteger(0);
    private final AtomicInteger failureCount = new AtomicInteger(0);
    private final ObjectMapper mapper = new ObjectMapper();
    public void recordSuccess(long latencyMs) {
        totalLatencyMs.addAndGet(latencyMs);
        successCount.incrementAndGet();
    public void recordFailure() {
        failureCount.incrementAndGet();
    public double getAverageLatency() {
        int total = successCount.get() + failureCount.get();
        return total == 0 ? 0 : (double) totalLatencyMs.get() / successCount.get();
    public double getSuccessRate() {
        return total == 0 ? 0 : (double) successCount.get() / total;
    public String generateAuditLog(String key, String action, boolean success, long latencyMs) {
            AuditLogEntry log = new AuditLogEntry(
                Instant.now().toString(),
                key,
                action,
                success,
                latencyMs,
                getSuccessRate()
            return mapper.writeValueAsString(log);
            return "{\"error\": \"Audit log generation failed\"}";
    public String buildRedisSyncWebhookPayload(String key, StoreDirective directive) throws Exception {
        WebhookPayload payload = new WebhookPayload(
            "article.refreshed",
            key,
            directive.ttlSeconds(),
            directive.contentHash()
        return mapper.writeValueAsString(payload);
    public record AuditLogEntry(String timestamp, String key, String action, boolean success, long latencyMs, double successRate) {}
    public record WebhookPayload(String event, String timestamp, String key, int ttl, String hash) {}
The following script integrates all components. It authenticates, fetches articles, validates constraints, computes hashes, stores via PUT, checks staleness, tracks metrics, logs audits, and generates Redis sync webhooks. Replace placeholder values with your environment configuration.
public class KnowledgeCacheService {
            String baseUrl = "https://api.mypurecloud.com";
            String clientId = System.getenv("GENESYS_CLIENT_ID");
            String clientSecret = System.getenv("GENESYS_CLIENT_SECRET");
            String spaceId = System.getenv("GENESYS_SPACE_ID");
            String cacheStoreUrl = System.getenv("CACHE_STORE_URL");
            String permissionContext = "internal:readonly";
            int ttlSeconds = 300;
            long maxCacheSizeBytes = 256 * 1024;
            GenesysAuthClient authClient = new GenesysAuthClient(baseUrl, clientId, clientSecret);
            String token = authClient.getAccessToken();
            KnowledgeArticleFetcher fetcher = new KnowledgeArticleFetcher(baseUrl, token);
            CacheStoreClient storeClient = new CacheStoreClient(cacheStoreUrl);
            CacheValidator validator = new CacheValidator(storeClient);
            CacheMetricsAndAudit metrics = new CacheMetricsAndAudit();
            AtomicInteger processedCount = new AtomicInteger(0);
            List<Article> articles = fetcher.fetchAllArticles(spaceId);
            System.out.println("Fetched " + articles.size() + " articles.");
            for (Article article : articles) {
                long startMs = System.currentTimeMillis();
                    CacheKeyMatrix matrix = new CacheKeyMatrix(spaceId, article.getId(), String.valueOf(article.getVersion()));
                    long fetchLatency = System.currentTimeMillis() - startMs;
                    StoreDirective directive = CachePayloadBuilder.buildDirective(article, spaceId, permissionContext, fetchLatency, ttlSeconds, maxCacheSizeBytes);
                    String articleJson = new com.fasterxml.jackson.databind.ObjectMapper().writeValueAsString(article);
                    boolean stored = storeClient.storeArticle(matrix, directive, articleJson);
                    if (stored) {
                        validator.registerMetadata(key, directive);
                        metrics.recordSuccess(fetchLatency);
                        String auditLog = metrics.generateAuditLog(key, "STORE", true, fetchLatency);
                        System.out.println("Audit: " + auditLog);
                        String webhookPayload = metrics.buildRedisSyncWebhookPayload(key, directive);
                        System.out.println("Redis Sync Webhook: " + webhookPayload);
                        processedCount.incrementAndGet();
                    } else {
                        metrics.recordFailure();
                        String auditLog = metrics.generateAuditLog(key, "STORE_FAIL", false, fetchLatency);
                        System.err.println("Audit: " + auditLog);
                    System.err.println("Processing failed for article " + article.getId() + ": " + e.getMessage());
            System.out.println("Completed. Processed: " + processedCount.get() + "/ " + articles.size());
            System.out.println("Average Latency: " + metrics.getAverageLatency() + " ms");
            System.out.println("Success Rate: " + (metrics.getSuccessRate() * 100) + "%");
            e.printStackTrace();
Error: HTTP 401 Unauthorized
  • What causes it: The OAuth token expired, the client credentials are incorrect, or the scope knowledge:article:view is missing from the application configuration.
  • How to fix it: Verify the client ID and secret in your environment variables. Ensure the token refresh logic runs before every API batch. Check that the OAuth client in Genesys Cloud has the Knowledge API scope enabled.
  • Code showing the fix: The GenesysAuthClient.getAccessToken() method checks tokenExpiryEpoch and automatically calls refreshAccessToken() when within 60 seconds of expiration.
Error: HTTP 403 Forbidden
  • What causes it: The OAuth client lacks permission to access the target space, or the space visibility is set to private and the client is not associated with the correct user pool or organization role.
  • How to fix it: Assign the Knowledge API user role to the OAuth client. Verify space visibility settings in the Genesys Cloud admin console. Ensure the spaceId parameter matches a space the client can query.
  • Code showing the fix: The permission-mismatch verification pipeline in CacheValidator catches context drift, but initial 403 errors require scope and space permission alignment before runtime.
  • What causes it: The Genesys Cloud API enforces rate limits per client ID. High-volume pagination or rapid token refresh triggers throttling.
  • How to fix it: Implement exponential backoff. The handleRateLimit method reads the Retry-After header. The pagination loop and PUT client retry automatically on 429 responses.
  • Code showing the fix: Both refreshAccessToken() and CacheStoreClient.storeArticle() check response.statusCode() == 429 and sleep before retrying.
Error: Caching Failure Payload Exceeds maximum-cache-size
  • What causes it: The article body contains large attachments, rich text formatting, or embedded media that exceeds the configured byte limit.
  • How to fix it: Increase maxCacheSizeBytes in the configuration, or strip non-essential fields before serialization. The storeArticle method validates size and returns false to prevent cache poisoning.
  • Code showing the fix: if (payloadSize > directive.maxCacheSizeBytes()) triggers a controlled failure with audit logging instead of throwing an unhandled exception.
