Caching Genesys Cloud Knowledge Article Metadata with Python SDK
- A Python service that fetches Knowledge article metadata from Genesys Cloud, constructs cache payloads with article UUID references, vector embedding matrices, and TTL expiration directives, and persists them via atomic POST operations.
- A validation pipeline that checks cache schemas against memory allocation constraints and maximum index size limits to prevent caching failure.
- A complete caching layer with relevance score checking, duplicate entry verification, latency tracking, hit ratio metrics, audit logging, and external CMS synchronization callbacks.
- OAuth Client Credentials flow configuration in Genesys Cloud
- Required OAuth scope:
knowledge:article:view - Python 3.10 or newer
- Dependencies:
genesyscloud>=4.0.0,httpx>=0.27.0,pydantic>=2.0.0,redis>=5.0.0 - Access to a cache persistence endpoint (HTTP POST) or local Redis instance
- Network connectivity to
api.mypurecloud.comand your cache service
Genesys Cloud uses OAuth 2.0 Client Credentials flow for server-to-server API access. You must request the knowledge:article:view scope to read article metadata. The following code demonstrates token acquisition, caching, and automatic refresh logic using httpx.
import httpx
from typing import Optional
class GenesysAuthManager:
def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
self.client_id = client_id
self.http = httpx.Client(timeout=15.0)
def _fetch_token(self) -> dict:
"""Exchange client credentials for an OAuth token."""
response = self.http.post(
f"{self.base_url}/oauth/token",
data={
"client_id": self.client_id,
"scope": "knowledge:article:view"
response.raise_for_status()
return response.json()
def get_token(self) -> str:
"""Return a valid access token, refreshing if expired or missing."""
if not self.access_token or time.time() >= self.token_expiry - 60:
token_data = self._fetch_token()
self.token_expiry = time.time() + token_data["expires_in"]
return self.access_token
"""Return headers ready for Genesys Cloud API requests."""
"Authorization": f"Bearer {self.get_token()}",
"Accept": "application/json"
HTTP Request Cycle for Token Acquisition
POST /oauth/token HTTP/1.1
Host: api.mypurecloud.com
grant_type=client_credentials&client_id=YOUR_CLIENT_ID&client_secret=YOUR_CLIENT_SECRET&scope=knowledge:article:view
HTTP Response
"token_type": "Bearer",
"expires_in": 299,
Step 1: Initialize Platform Client and Fetch Articles with Pagination
The Genesys Cloud Knowledge API uses cursor-based and page-based pagination. The /api/v2/knowledge/articles/search endpoint returns articles matching query parameters. You must handle pageSize and pageNumber to retrieve all results. The SDK class PureCloudPlatformClientV2 handles serialization and deserialization automatically.
from genesyscloud import PureCloudPlatformClientV2
from genesyscloud.knowledge import Api as KnowledgeApi
class KnowledgeCacher:
def __init__(self, auth_manager: GenesysAuthManager):
self.auth = auth_manager
self.platform_client = PureCloudPlatformClientV2()
self.platform_client.set_access_token(auth_manager.get_token)
self.knowledge_api = KnowledgeApi(self.platform_client)
def fetch_articles(self, query: str = "", page_size: int = 25) -> list:
"""Fetch all articles matching the query with pagination."""
all_articles = []
page_number = 1
while True:
response = self.knowledge_api.post_knowledge_articles_search(
body={
"query": query,
"pageSize": page_size,
"pageNumber": page_number
print(f"API error on page {page_number}: {e}")
break
if not response.body or not response.body.entities:
break
all_articles.extend(response.body.entities)
# Pagination check
if len(response.body.entities) < page_size:
break
page_number += 1
return all_articles
Required Scope: knowledge:article:view
Step 2: Construct Cache Payloads and Validate Schema Constraints
Cache payloads must include article UUID references, vector embedding matrices, and TTL expiration directives. You must validate the payload against memory allocation constraints and maximum index size limits before persistence. Pydantic provides strict schema validation.
from pydantic import BaseModel, Field, field_validator
import json
class CachePayload(BaseModel):
article_id: str
title: str
folder_id: Optional[str] = None
vector_embedding_matrix: List[List[float]] = Field(default_factory=list)
ttl_seconds: int = Field(default=3600, ge=60, le=86400)
relevance_score: float = Field(default=0.0, ge=0.0, le=1.0)
@field_validator("vector_embedding_matrix")
@classmethod
def validate_embedding_size(cls, v: List[List[float]]) -> List[List[float]]:
"""Enforce maximum index size limits to prevent caching failure."""
total_elements = sum(len(row) for row in v)
if total_elements > 4096:
raise ValueError("Vector embedding matrix exceeds maximum index size limit of 4096 elements.")
return v
def serialize(self) -> str:
"""Return JSON string for atomic POST operations."""
return self.model_dump_json()
@classmethod
def from_genesis_article(cls, article: object, embedding: List[List[float]], ttl: int) -> "CachePayload":
"""Construct cache payload from Genesys Cloud article object."""
return cls(
article_id=article.id or "",
title=article.title or "",
folder_id=article.folder_id,
vector_embedding_matrix=embedding,
ttl_seconds=ttl,
relevance_score=0.0
Step 3: Atomic Persistence with Format Verification and 429 Retry Logic
You must handle data persistence via atomic POST operations with format verification. The cache endpoint expects JSON. You must implement retry logic for 429 rate-limit responses to prevent cascading failures.
import logging
class CachePersistenceLayer:
def __init__(self, cache_endpoint: str):
self.endpoint = cache_endpoint
self.http = httpx.Client(timeout=10.0)
def persist_atomic(self, payload: CachePayload, idempotency_key: str) -> bool:
"""Persist cache payload with atomic POST and 429 retry logic."""
headers = {
"Idempotency-Key": idempotency_key,
"X-Cache-TTL": str(payload.ttl_seconds)
max_retries = 3
self.endpoint,
content=payload.serialize(),
headers=headers
if response.status_code == 201:
logger.info(f"Successfully cached article {payload.article_id}")
return True
elif response.status_code == 429:
retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
logger.warning(f"Rate limited (429). Retrying after {retry_after}s...")
time.sleep(retry_after)
elif response.status_code == 413:
raise ValueError("Payload exceeds cache server maximum size limit.")
else:
raise httpx.HTTPStatusError(f"Cache POST failed: {response.status_code}", response=response, request=response.request)
logger.error(f"Cache persistence failed: {e}")
return False
return False
HTTP Request Cycle for Cache POST
POST /api/cache/knowledge-articles HTTP/1.1
Host: cache.internal.service
Idempotency-Key: cache-uuid-a1b2c3d4
X-Cache-TTL: 3600
"article_id": "1a2b3c4d-5e6f-7g8h-9i0j-k1l2m3n4o5p6",
"title": "How to Reset Your Password",
"folder_id": "folder-uuid-xyz",
"vector_embedding_matrix": [[0.12, -0.45, 0.88], [0.33, 0.12, -0.91]],
"ttl_seconds": 3600,
"relevance_score": 0.0
HTTP Response
"status": "cached",
"id": "cache-entry-789",
"expires_at": "2024-12-01T12:00:00Z"
Step 4: Cache Validation Logic with Relevance Checking and Duplicate Verification
You must implement cache validation logic using relevance score checking and duplicate entry verification pipelines. This ensures rapid search retrieval and prevents stale content delivery during Knowledge scaling.
import uuid
import hashlib
class CacheValidator:
def __init__(self, cache_persistence: CachePersistenceLayer):
self.persistence = cache_persistence
self.seen_hashes: set = set()
self.min_relevance_threshold: float = 0.35
def compute_content_hash(self, article_id: str, title: str) -> str:
"""Generate a deterministic hash for duplicate verification."""
raw = f"{article_id}:{title}".encode("utf-8")
return hashlib.sha256(raw).hexdigest()
def validate_and_persist(self, payload: CachePayload, external_relevance: float) -> bool:
"""Run duplicate verification and relevance checking before persistence."""
content_hash = self.compute_content_hash(payload.article_id, payload.title)
if content_hash in self.seen_hashes:
logger.info(f"Duplicate entry detected. Skipping article {payload.article_id}")
return False
payload.relevance_score = external_relevance
if payload.relevance_score < self.min_relevance_threshold:
logger.info(f"Article {payload.article_id} below relevance threshold. Skipping.")
return False
idempotency_key = f"cache-{payload.article_id}-{content_hash[:8]}"
success = self.persistence.persist_atomic(payload, idempotency_key)
if success:
self.seen_hashes.add(content_hash)
return success
Step 5: Metrics Tracking, Audit Logging, and CMS Synchronization
You must track caching latency and hit ratio success rates for cache efficiency, generate caching audit logs for knowledge governance, and synchronize caching events with external CMS platforms via callback handlers.
import logging
from typing import Callable, Optional
class CacheMetricsAndAudit:
def __init__(self, cms_callback_url: Optional[str] = None):
self.cms_callback_url = cms_callback_url
self.http = httpx.Client(timeout=5.0)
self.total_requests: int = 0
self.cache_hits: int = 0
self.total_latency_ms: float = 0.0
self.audit_log: list = []
def record_fetch(self, article_id: str, latency_ms: float, was_cached: bool) -> None:
self.total_requests += 1
self.total_latency_ms += latency_ms
if was_cached:
self.cache_hits += 1
self.audit_log.append({
"timestamp": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime()),
"article_id": article_id,
"latency_ms": latency_ms,
"was_cached": was_cached,
"action": "cache_fetch"
if self.cms_callback_url:
self._notify_cms(article_id, was_cached)
def _notify_cms(self, article_id: str, cached: bool) -> None:
self.http.post(
self.cms_callback_url,
json={
"event": "knowledge_cache_sync",
"cached": cached,
"synced_at": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime())
logger.warning(f"CMS callback failed: {e}")
def get_metrics(self) -> dict:
hit_ratio = self.cache_hits / self.total_requests if self.total_requests > 0 else 0.0
avg_latency = self.total_latency_ms / self.total_requests if self.total_requests > 0 else 0.0
"total_requests": self.total_requests,
"cache_hits": self.cache_hits,
"hit_ratio": round(hit_ratio, 4),
"avg_latency_ms": round(avg_latency, 2)
The following script combines authentication, article fetching, payload construction, validation, persistence, metrics tracking, and audit logging into a single executable module. Replace placeholder values with your environment credentials.
import os
import logging
def run_knowledge_cache_pipeline():
# Configuration
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
CACHE_ENDPOINT = os.getenv("CACHE_ENDPOINT", "https://cache.internal.service/api/cache/knowledge-articles")
CMS_CALLBACK = os.getenv("CMS_CALLBACK_URL", "https://cms.internal.service/hooks/genesys-sync")
EMBEDDING_SERVICE_URL = os.getenv("EMBEDDING_SERVICE_URL")
if not CLIENT_ID or not CLIENT_SECRET:
raise ValueError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET environment variables are required.")
# Initialize components
auth_manager = GenesysAuthManager(CLIENT_ID, CLIENT_SECRET)
cacher = KnowledgeCacher(auth_manager)
persistence = CachePersistenceLayer(CACHE_ENDPOINT)
validator = CacheValidator(persistence)
metrics = CacheMetricsAndAudit(CMS_CALLBACK)
# Fetch articles
query = "password reset"
print(f"Fetching articles for query: {query}")
articles = cacher.fetch_articles(query=query, page_size=25)
print(f"Retrieved {len(articles)} articles.")
# Process each article
for idx, article in enumerate(articles):
# Simulate external vector embedding retrieval
# Genesys Cloud does not expose raw embeddings via public API.
# Replace this with your actual vectorization service call.
embedding_matrix = [[0.12, -0.45, 0.88], [0.33, 0.12, -0.91]]
if EMBEDDING_SERVICE_URL:
emb_resp = httpx.get(f"{EMBEDDING_SERVICE_URL}/embed", params={"text": article.title or ""})
if emb_resp.status_code == 200:
embedding_matrix = emb_resp.json().get("vectors", embedding_matrix)
logging.warning(f"Embedding fetch failed: {e}")
payload = CachePayload.from_genesis_article(article, embedding_matrix, ttl=3600)
external_relevance = 0.85 # Replace with actual relevance scoring logic
success = validator.validate_and_persist(payload, external_relevance)
end_time = time.perf_counter()
latency_ms = (end_time - start_time) * 1000
metrics.record_fetch(article.id or "unknown", latency_ms, success)
# Output final metrics
print("\n=== Cache Pipeline Complete ===")
print(f"Metrics: {metrics.get_metrics()}")
print(f"Audit Log Entries: {len(metrics.audit_log)}")
- Cause: The OAuth token expired, or the client credentials are invalid.
- Fix: Verify
GENESYS_CLIENT_IDandGENESYS_CLIENT_SECRETmatch your Genesys Cloud integration. Ensure theGenesysAuthManagerrefreshes the token before each API call. Theget_token()method includes a 60-second buffer to prevent mid-request expiration. - Code Fix: The
GenesysAuthManager.get_token()method already handles automatic refresh. If you bypass it, callauth_manager._fetch_token()explicitly.
Error: 403 Forbidden
- Cause: The OAuth token lacks the
knowledge:article:viewscope, or the integration is restricted by environment permissions. - Fix: Edit the OAuth client in Genesys Cloud Admin. Navigate to Platform > Integrations > API. Select your client. Add
knowledge:article:viewto the scopes. Save and regenerate credentials if necessary. - Code Fix: Verify the
scopeparameter in_fetch_token()matches exactly:"scope": "knowledge:article:view".
- Cause: Genesys Cloud rate limits are exceeded, or your cache persistence endpoint is throttling writes.
- Fix: Implement exponential backoff. The
CachePersistenceLayer.persist_atomic()method includes a retry loop withRetry-Afterheader parsing. For Genesys Cloud API calls, add a similar retry wrapper aroundpost_knowledge_articles_search. - Code Fix: The provided implementation already handles 429 responses with
time.sleep(retry_after)and up to 3 retries.
Error: 413 Payload Too Large
- Cause: The cache payload exceeds the maximum index size limit or memory allocation constraints of your cache service.
- Fix: Reduce the
vector_embedding_matrixdimensions. TheCachePayload.validate_embedding_size()validator enforces a 4096-element limit. If your cache server has stricter limits, adjust thefield_validatorthreshold accordingly. - Code Fix: Modify
validate_embedding_sizeto match your infrastructure:if total_elements > 2048: raise ValueError(...)
Error: Pydantic Validation Error
- Cause: The
ttl_secondsvalue falls outside the allowed range (60-86400), orrelevance_scoreis outside 0.0-1.0. - Fix: Validate inputs before constructing
CachePayload. Ensure external services return normalized relevance scores and valid TTL values. - Code Fix: Wrap
CachePayload(...)in a try-except block to catchpydantic.ValidationErrorand log malformed inputs.
