Looking for advice on optimizing the failover response time for our 15 BYOC trunks in the Singapore region. The current setup triggers a 200ms delay when the primary carrier drops packets, causing noticeable audio gaps.
The trunk metrics endpoint shows clean metrics, but the actual SIP INVITE retry logic seems to be stalling at the edge. We are using Genesys Cloud Java SDK 11.5.2 for monitoring.
Has anyone tuned the outbound routing rules to bypass the default health check interval? Need to reduce this latency under 50ms.
