Running the quarterly PCI-DSS audit on our telephony stack. The Admin UI throws a SIP_TRUNK_CONFIG_400_INCOMPATIBLE_CIPHER error when trying to force TLS 1.3 on the inbound signaling path. The compliance checklist requires all SIP INVITE messages to carry encrypted headers before they hit the Genesys Cloud edge. We’ve uploaded the certificates in the Organization Security section, but the trunk configuration page keeps rejecting the cipher suite selection. The error log shows Error: Cipher suite TLS_AES_256_GCM_SHA384 not supported for legacy SIP media negotiation.
Media encryption is already set to SRTP in the routing rules, so I’m not sure why the signaling path is complaining about media negotiation. The audit team needs the TLS handshake logs to verify the SOC2 control for data in transit. Console shows the trunk status as PARTIAL_SYNC after the save attempt. Tried clearing the browser cache and switching to the mobile admin app, but the dropdown doesn’t respond. Doing jack all right now except waiting on the vendor ticket. Audit logs keep timing out. No clear path forward.
Is there a separate toggle in the Admin UI to bypass the legacy media check? The documentation mentions “Secure SIP” but the button only appears for outbound campaigns. We just need the signaling encryption to pass the compliance scanner. The current setup drops the audit trail whenever a call routes through the legacy Avaya gateway. Mic stays hot during the handoff, but the recording metadata gets flagged as unencrypted.
Requesting the exact UI path to enable TLS 1.3 without breaking the existing SRTP media streams. The compliance deadline is Friday and the trunk keeps rolling back to TLS 1.2 automatically. Environment is Genesys Cloud org version 2024.02, Admin UI v23.11, hosted in us-east-1.
GET /api/v2/telephony/providers/edges/trunks/{trunkId} returns 409 Conflict: Incompatible cipher configuration detected during PCI validation.
That SIP_TRUNK_CONFIG_400_INCOMPATIBLE_CIPHER error is usually the platform rejecting a cipher negotiation that doesn’t match the internal hard-coded list. Forcing TLS 1.3 across the board often breaks things if the provider’s stack isn’t sending the exact suite the edge expects. It’s better to pin the TLS_CIPHER_SUITE explicitly on the TRUNK_ENDPOINT rather than relying on the global Organization Security defaults. The list is picky.
You’ll want to check if the TLS_VERIFY_PEER flag is actually the bottleneck. Sometimes the cert chain validates fine, but the handshake aborts because the cipher order is wrong. The audit scanner might be seeing a failed handshake instead of a clean TLS 1.3 connection. It’s a pain to debug without the raw traces. We’ve seen this happen when the ISP pushes an outdated list that the platform just ignores.
Try dropping this config into the trunk definition. It forces the specific suites that actually work with the PCI requirements without tripping the 400 error.
"tls": {
"version": "1.3",
"cipher_suites": [
"TLS_AES_256_GCM_SHA384",
"TLS_CHACHA20_POLY1305_SHA256"
"verify_mode": "REQUIRED"
Make sure the SIP_TRUNK status shows as ACTIVE after the change. If the scanner still complains, check the raw SIP traces. The INVITE might be getting dropped before encryption kicks in. Also, watch out for the TLS_CERTIFICATE_EXPIRY date. If the cert is close to expiring, the platform can throw weird cipher errors instead of a clear expiration warning. The KEY CONFIGURATIONS page doesn’t always show the actual negotiated suite, so you’re guessing.
Problem
- The platform rejects the cipher negotiation when the UI forces a global TLS 1.3 override. The suggestion above mentions pinning it on the endpoint, but the REST payload structure often drops the cipher array if you don’t wrap it correctly.
Code
- PureCloudPlatformClientV2 expects the trunk configuration to carry the explicit cipher list inside the
sip_trunk object. You’ll need to patch the resource directly.
from platform_sdk_v2 import PureCloudPlatformClientV2
client = PureCloudPlatformClientV2('us-east-2')
client.login('', 'client_id', 'client_secret', 'https://yourdomain.com')
update_body = {
"name": "pci-compliant-trunk",
"protocol": "sip",
"tls_cipher_suite": ["TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384", "TLS_AES_256_GCM_SHA384"],
"encryption": "tls",
"version": 2
client.sip_trunks_api.patch_sip_trunk(trunk_id="abc-123", body=update_body)
Error
- You’ll hit a
409 CONFLICT if the version field isn’t incremented. The SDK doesn’t fetch the current etag automatically, so you have to read it first or bump the integer manually. pretty annoying workflow.
Question
- Checking the intermediate CA chain usually fixes the handshake drop. The edge parser is strict about certificate ordering
The endpoint pinning suggestion actually works if you skip the UI. Pinned the cipher suite directly and it passed the audit. The UI drops the array anyway. Here’s how I fixed it:
- Grab the trunk ID from GET /api/v2/telephony/providers/edges/{edgeId}/trunks.
- Send a PUT to /api/v2/telephony/providers/edges/trunkbasesettings/{trunkBaseSettingsId} with the explicit tls_cipher_suite array.
curl -X PUT "https://api.mypurecloud.com/api/v2/telephony/providers/edges/trunkbasesettings/{trunkBaseSettingsId}" \
-H "Authorization: Bearer <token>" \
-H "Content-Type: application/json" \
-d '{
"tls_cipher_suite": ["TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384", "TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256"],
"tls_version": "TLSv1_3"
Direct fetch works fine when you bypass the wrapper. Just toss in the telephony:edge:write scope on the Authorization header. Check the edge logs if it still bombs.
The Genesys Cloud telephony provider docs explicitly state that the Admin UI enforces a legacy cipher whitelist, which breaks when you try to force TLS 1.3 during a PCI scan. The REST endpoint handles it fine as long as you bypass the UI validation layer.
Problem
The trunk configuration API drops the cipher array if you submit it inside the security object instead of the root level. You also need the telephony:providers:edges:write scope or the PATCH request will silently strip the TLS parameters before hitting the edge. I’m running this through my Express webhook middleware to keep the audit config in sync with our deployment pipeline.
Code
Here’s the exact Node.js snippet I use to patch the trunk without triggering the UI validation trap. It grabs the current config, injects the explicit cipher suite, and pushes it back.
const platformClient = require('genesyscloud').platformClient;
const auth = platformClient.auth;
async function patchTrunkCipher(edgeId) {
await auth.loginOAuthClientCredentials({
clientId: process.env.GC_CLIENT_ID,
clientSecret: process.env.GC_CLIENT_SECRET,
scope: ['telephony:providers:edges:write', 'telephony:providers:edges:read']
const telephony = platformClient.TelephonyProvidersEdgesApi();
const trunk = await telephony.getTelephonyProvidersEdge(edgeId);
// *Warning: omitting the 'tls_version' field here will cause the edge to fallback to 1.2*
trunk.body.tls_cipher_suite = ['TLS_AES_256_GCM_SHA384'];
trunk.body.tls_version = 'TLSv1.3';
await telephony.patchTelephonyProvidersEdge(edgeId, trunk.body);
Error
You’ll hit a 400 Bad Request with SIP_TRUNK_CONFIG_400_INCOMPATIBLE_CIPHER if the array contains a suite that isn’t in the platform’s internal allowlist. Stick to the GCM variants. The error response doesn’t tell you which cipher failed, it just blocks the whole payload. It’s a pain to debug when the logs only show a generic handshake failure.
Question
Does your provider actually support a full TLS 1.3 handshake on the SIP signaling port, or are they just doing transport encryption on the media path. Check the SIP trace on the ingress port. The handshake usually times out before the INVITE even leaves the local stack.
