BYOC Edge Node Latency Impact on Architect Flow Logic
Is it possible to configure the Genesys Cloud BYOC edge nodes to prioritize internal routing logic over external web service calls during high-latency events? The current setup in our Paris data center is causing Architect flow timeouts when the edge connection experiences packet loss above 2%.
The dashboard indicates that conversation detail views are recording significant delays in the ‘Web Service’ block, yet the queue activity metrics remain stable. We need to understand if there is a native failover mechanism for edge-to-core communication that does not require manual API intervention.
Check your BYOC edge configuration for the specific timeout thresholds applied to outbound web service calls. The issue described often stems from the default connection timeout being too aggressive for high-latency environments, causing the Architect flow to abort before the response returns, rather than the edge node itself failing.
In Genesys Cloud, you cannot directly “prioritize” internal logic over external calls via a simple toggle. Instead, you must adjust the Connect Timeout and Read Timeout settings within the Web Service block configuration in Architect. For a Paris data center experiencing packet loss, increasing these values can provide the necessary buffer.
Ensure your ServiceNow integration uses an asynchronous pattern where possible. If the flow is synchronous, consider implementing a retry mechanism with exponential backoff directly in the Data Action or using a local cache for non-critical data. Here is an example of how to structure the timeout settings in the Web Service block JSON configuration if you are managing this via API:
 "name": "ServiceNow_Update",
 "connectTimeoutMs": 5000,
 "readTimeoutMs": 10000,
 "retryPolicy": {
 "maxRetries": 2,
 "initialDelayMs": 1000
Additionally, verify that the BYOC edge node is correctly routing traffic through the lowest latency path. Packet loss above 2% suggests a network infrastructure issue rather than a Genesys configuration problem. Review the edge node logs for dropped packets and consider implementing circuit breakers in your ServiceNow REST API layer to fail fast and prevent cascading timeouts in the Architect flow. This approach aligns with best practices for handling unstable network conditions in digital channel integrations.
As far as I remember, the issue isn’t just about timeout thresholds but how Architect handles the state of a failing web service block when migrating from Zendesk’s more forgiving ticket-update model. In Zendesk, a failed macro might just log an error and continue; here, the flow often halts or loops unpredictably if the Connect Timeout isn’t paired with a robust fallback path.
The suggestion to adjust the Connect Timeout is valid, but for high-latency BYOC edges in Europe, you need to implement a circuit breaker pattern within Architect itself. Instead of relying solely on the block’s timeout, wrap the Web Service call in a Try/Catch block. Set the Connect Timeout to 3000 ms and the Read Timeout to 5000 ms. Crucially, add a Catch branch that redirects to a local data block or a cached response if the call fails.
Also, check your Edge Node configuration in the Admin console. Ensure Keep-Alive is enabled to reduce handshake overhead. If the packet loss is above 2%, the TCP retransmissions alone can push the effective latency past your limits. Consider adding a Delay block of 500 ms before the Web Service call to allow the edge connection to stabilize after the previous step. This is a common fix we used during our Zendesk-to-GC migration for the Paris region.
Here is a snippet of how the Architect block configuration should look:
 "type": "web_service",
 "config": {
 "connectTimeout": 3000,
 "readTimeout": 5000,
 "retryCount": 1,
 "retryDelay": 500
This approach prevents the flow from timing out completely and allows the agent to proceed with partial data, similar to how Zendesk would handle a failed external API update without dropping the ticket.
