BYOC Edge Health Check Failing with 412 Precondition Failed During WFM Sync
Stuck on a weird integration issue between our BYOC Edge nodes and the WFM scheduling service.
We are running a custom script to validate edge health before the weekly schedule publish. The script hits the /v2/edges/health endpoint. It works fine for 95% of the requests, but suddenly fails with a 412 Precondition Failed for specific edge instances in the Chicago cluster.
The error payload looks like this:
“message”: “Edge node certificate rotation pending”,
“code”: “412”,
“details”: “Precondition failed: TLS handshake requires updated CA bundle.”
This is blocking the schedule adherence report generation because the WFM module refuses to sync if the edge health check returns non-200 status codes. We updated the CA bundle on the edge nodes last Tuesday, but the platform seems to still be expecting the old fingerprint.
Has anyone seen this lag in certificate validation propagation? The edges are definitely using the new certs, but the Genesys platform API is rejecting them. Restarting the edge service didn’t help. Is there a cache invalidation step we are missing in the BYOC management console?
Check your edge configuration for stale WFM adherence tokens, as the 412 usually indicates the local cache is out of sync with the central scheduler state rather than a network failure. Force a manual cache invalidation via the BYOC management API before retrying the health check.
Check your Performance Dashboard views to see if the Chicago edge instances are showing elevated conversation drop rates or increased handle times leading up to the 412 error. While the previous suggestion regarding cache invalidation is technically sound, it often masks a deeper synchronization gap between the real-time edge state and the WFM scheduling engine. If the edge node reports healthy connectivity but the scheduler expects different adherence data, the precondition fails.
Review the Queue Activity view for those specific agents. If you see a spike in “Not Ready” states or missed intervals, the issue likely stems from the edge node failing to push real-time status updates to the central scheduler, causing the token mismatch. Try clearing the local browser cache for the admin console as well, as stale session data can sometimes mimic this API failure.
Note: Forcing a manual cache invalidation is a temporary fix. If this persists, investigate the network latency between the Chicago cluster and the Genesys Cloud region, as high jitter can cause the WFM sync to timeout before the health check completes.
My usual workaround is to adding a JMeter loop to hammer the cache invalidation endpoint with high concurrency to force the state sync. Check your WebSocket connection limits to ensure the edge isn’t throttling the reset signal during peak load.
