BYOC Edge deployment 422 on routing region key
Pushing the BYOC EDGE CONFIGURATION through the standard PIPELINE DEPLOYMENT script doesn’t work. The logic follows a linear path. First, the script validates the EDGE ID against the tenant manifest. Next, the payload includes the required edgeType set to BYOC. The error log points to a missing routingRegion key, but the JSON clearly contains the REGION MAPPING object. Console is empty and the build hangs.
