Bulk filter indexing fails with 400 clause depth error on Python SDK
The Python SDK keeps rejecting the bulk filter payload with a 400 Bad Request, and the error log just screams “clause depth exceeded” without pointing to the specific node in the boolean matrix.
  1. Constructed the attribute value matrix with nested AND directives.
  2. Hit the post_analytics_search_filters endpoint expecting an atomic index refresh.
The filter indexer hates deep trees and I’m stuck parsing the validationErrors array while the webhook callbacks time out waiting for the sync.
 "type": "boolean",
 "condition": "and",
 "clauses": [
 { "type": "field", "field": "routing.queueId", "operator": "equals", "value": "queue-uuid" },
 { "type": "field", "field": "interaction.media", "operator": "equals", "value": "voice" }
The indexer doesn’t perform an atomic refresh. That’s a slight misunderstanding. Updates process asynchronously. The clause depth error triggers on deep nesting. Flatten the structure.
How do I set up the complete analytics pipeline without hitting SDK walls? The goal is to configure queues, IVR, and schedules all at once. The setup feels overwhelming.
Use a single boolean operator with a flat list of clauses. Don’t wrap conditions inside other condition objects. The parser rejects deep nesting. The payload needs to stay shallow. Anything deeper just fails.
PYTHON SDK processes filter definitions through a recursive tree builder, and the maximum clause depth is strictly five levels. When you stack nested AND blocks like (A AND B) AND (C AND D), the serializer pushes the JSON past that threshold before it reaches the gateway. The indexer does process updates asynchronously, so the 400 response comes from the validation middleware, not the background worker. You’ll need to flatten the boolean matrix into a single array of conditions instead of nesting objects. Start by pulling all your field checks into one list, then wrap them in a parent boolean node with condition: "and". The SDK expects the structure to look like {"type": "boolean", "condition": "and", "clauses": [{"type": "field", "field": "routing.queueId", "operator": "equals", "value": "queue-uuid"}, {"type": "field", "field": "interaction.media", "operator": "equals", "value": "voice"}]}. This keeps the depth at two levels and bypasses the parser error completely. It’s a strict rule, so you can’t nest deeper than that.
Running the payload through the local validator first usually catches these structural breaks before deployment. You can test it by calling client.analytics_api.post_analytics_search_filters(organization_id, body=flattened_filter) in a sandbox environment. The response will return a 202 Accepted if the shape matches the schema, which means the async job will queue correctly. Make sure the version header matches the current index state, otherwise the gateway drops the request silently. The filter builder in the Python SDK doesn’t auto-collapse redundant operators, so manual flattening stays the only reliable path. Structure has to be flat. The gateway won’t wait. Check the raw JSON before sending it over the wire.
Are you nesting those AND clauses inside a parent boolean object? genesys-cloud-python-sdk handles serialization differently based on depth. Step one is inspecting the filter_definition before the request leaves the client. Stacking clauses like {"condition": "and", "clauses": [...]} inside another array bumps the counter instantly. The validation middleware chokes once that tree passes five levels. You’ll see the 400 error at the gateway, not during the async refresh.
Flatten the structure by moving all leaf nodes into a single top-level clauses array. The SDK method create_filter_clause accepts a list, so multiple field checks can go directly without wrapper boolean objects. Set the operator to and at the root. This bypasses the recursion limit. The indexer processes the flat payload and updates asynchronously without triggering the depth limit.
The Python SDK serializer doesn’t just count the boolean nodes you define, it counts every implicit wrapper it injects during the JSON dump. You’ll hit that five-level cap way faster than expected because the gateway treats each nested clauses array as a separate depth tier. Don’t rely on the SDK to auto-flatten your boolean matrix before the request hits the validation middleware. If you’re building those filters dynamically, the recursive builder will silently push past the limit once you cross three layers of AND conditions. The indexer itself isn’t the bottleneck here. The 400 response fires at the edge proxy before the payload ever touches the search queue. You need to strip the nesting manually and pass a flat list of field conditions instead of wrapping them in parent objects. The web messaging SDK handles this exact serialization trap by forcing a single-level array for pre-chat validations, so the same pattern applies here. Just dump the raw payload before calling the API to verify the tree structure. The analytics search filters endpoint rejects anything past that threshold without a useful trace.
from genesyscloud.platform import PureCloudPlatformClientV2
# Requires analytics:read scope. platformClient serializes nested objects recursively.
flat_filter = {
 "type": "boolean",
 "condition": "and",
 "clauses": [
# The analytics search filters endpoint expects a single-level array
