Bulk export metadata mismatch in Architect flow
Quick question about the POST /api/v2/flows/export/jobs endpoint. Context: Running a bulk export job for legal discovery on a digital channel flow. The S3 integration delivers files, but the metadata timestamp in the response does not match the file creation date. Question: Is this a known latency issue with the chain of custody logs in the EU-West region?
you need to check the exported_at field in the job definition rather than relying on the s3 object creation date. coming from zendesk, we often expected the export timestamp to mirror the file system, but genesys cloud handles this differently. the api response includes a created_date which reflects when the job started, not when the file landed in s3. this gap can be a few minutes depending on the queue depth in eu-west. if you are using the sdk, parse the application/json response from the job status endpoint. the metadata mismatch is normal behavior, not a latency bug. for legal discovery, always log the job id and the started_at timestamp from the api, then cross-reference with the s3 logs if needed. this aligns with how gc tracks audit trails versus zendesk’s simpler file-based exports. trust the api timestamps for compliance records.
What’s happening here is that relying on the s3 object metadata for chain of custody in a legal discovery context is fundamentally flawed because the export job lifecycle decouples the logical completion from the physical file transfer. the previous suggestion about checking exported_at is correct for operational tracking, but it does not solve the audit trail gap. in serviceNow integrations, we often face similar discrepancies when webhook payloads are processed asynchronously. to get a true immutable timestamp, you need to trigger a custom data action or a post-job webhook that captures the completed_at timestamp from the Genesys Cloud API response and writes it directly into your evidence repository or serviceNow incident record before the file is even touched by s3. this ensures the timestamp is locked in at the source of truth. here is a rough example of the webhook payload structure you should look for in the job completion event:
 "event": "flow.export.completed",
 "timestamp": "2023-10-27T14:30:00Z",
 "job_id": "abc-123",
 "status": "COMPLETED"
use this timestamp field as your authoritative record. do not trust the s3 LastModified header. additionally, consider adding a checksum verification step in your data action to validate file integrity against the hash provided in the genecys response. this adds another layer of assurance for legal teams. the eu-west latency is real, but the solution lies in capturing the state change at the application layer, not the storage layer. if you are using the sdk, make sure you are polling the job status endpoint until it returns COMPLETED and then immediately log that specific response payload. this approach has worked well in our environments for compliance reporting.
The docs actually state the exported_at field marks logical completion, not physical S3 upload. For audit trails, rely on the job status endpoint rather than file timestamps.
 "status": "completed",
 "exported_at": "2023-10-27T10:00:00Z",
 "s3_upload_status": "pending"
This ensures accurate chain of custody tracking.
