Building Genesys Cloud Data Actions with Python SDK
A production-grade Data Action handler that validates incoming payloads, executes external service calls with strict timeout enforcement, registers with the Genesys Cloud platform, and emits structured audit logs and performance metrics. This tutorial uses the official genesyscloud Python SDK and the /api/v2/platform/actions API surface. The implementation covers Python 3.9+ with type hints, Pydantic schemas, and httpx for HTTP transport.
- OAuth2 Client Credentials flow configured in the Genesys Cloud Admin Console
- Required scopes:
platform:action:write,platform:action:read,integration:action:read - SDK version:
genesyscloud>=2.0.0 - Runtime: Python 3.9+
- External dependencies:
pydantic>=2.0,httpx>=0.25,tenacity>=8.2,pyyaml>=6.0
Genesys Cloud requires OAuth2 bearer tokens for all API interactions. The Python SDK handles token acquisition and automatic refresh, but you must initialize the client with explicit environment configuration and credential injection. Token caching occurs automatically in the SDK session object, which prevents unnecessary credential rotation during long-running processes.
import os
from genesyscloud import PureCloudPlatformClientV2
def initialize_genesys_client() -> PureCloudPlatformClientV2:
Initializes and configures the Genesys Cloud SDK client.
Required OAuth scopes: platform:action:write, platform:action:read
client = PureCloudPlatformClientV2()
# Environment selection must match your Genesys Cloud deployment
client.set_environment(os.getenv("GENESYS_ENVIRONMENT", "mypurecloud.ie2"))
# Client credentials flow configuration
client.set_credentials(
client_id=os.getenv("GENESYS_CLIENT_ID"),
client_secret=os.getenv("GENESYS_CLIENT_SECRET"),
grant_type="client_credentials"
# Verify connectivity before proceeding
client.login()
raise RuntimeError(f"Failed to authenticate with Genesys Cloud: {e}") from e
return client
The client.login() method triggers the POST request to /api/v2/oauth/token. The SDK caches the resulting access token and automatically appends the Authorization: Bearer <token> header to subsequent requests. If the token expires, the SDK intercepts the 401 response and performs a silent refresh before retrying the original call.
Step 1: Define Action Handler with Input/Output Schemas
Data Actions in Genesys Cloud exchange JSON payloads. You must define strict schemas to prevent runtime type coercion errors and to satisfy the SDK validation layer. Pydantic v2 provides compile-time type checking and runtime validation with detailed error reporting.
from pydantic import BaseModel, Field, ValidationError
from typing import Any
class ActionInput(BaseModel):
customer_id: str = Field(..., pattern=r"^cust_[a-zA-Z0-9]+$", description="Internal customer identifier")
request_type: str = Field(..., pattern=r"^(lookup|update|delete)$", description="Operation to perform")
payload: dict[str, Any] = Field(default_factory=dict, description="Contextual data for the operation")
class ActionOutput(BaseModel):
success: bool
message: str
data: dict[str, Any] = Field(default_factory=dict)
trace_id: str = Field(default="unknown", description="Request correlation identifier")
The pattern constraints in Pydantic mirror the validation rules enforced by the Genesys Cloud platform. When you register the action definition, the platform expects the input schema to match the actual handler signature. Mismatches cause 400 Bad Request responses during execution.
Step 2: Implement Authentication Middleware and Business Logic
External service calls require authentication middleware that injects API keys or OAuth tokens into outbound requests. You must also enforce execution timeouts. Genesys Cloud terminates Data Action executions after 30 seconds. Exceeding this limit returns a 504 Gateway Timeout to the caller and marks the action as failed in the platform.
import httpx
import uuid
import logging
logger = logging.getLogger("genesys_action_handler")
class ExternalServiceClient:
def __init__(self, base_url: str, api_key: str):
self.api_key = api_key
self.timeout = httpx.Timeout(connect=5.0, read=15.0, pool=5.0)
def _build_headers(self) -> dict[str, str]:
"Authorization": f"Bearer {self.api_key}",
"X-Request-Source": "genesys-data-action"
def execute_operation(self, input_data: ActionInput) -> ActionOutput:
trace_id = str(uuid.uuid4())
# Enforce Genesys Cloud 30-second execution limit
if time.perf_counter() - start_time > 28.0:
raise TimeoutError("Action execution approaching Genesys Cloud 30s limit")
async with httpx.AsyncClient(timeout=self.timeout) as client:
response = await client.post(
f"{self.base_url}/api/v1/operations/{input_data.request_type}",
headers=self._build_headers(),
json={"customer_id": input_data.customer_id, **input_data.payload}
response.raise_for_status()
elapsed_ms = (time.perf_counter() - start_time) * 1000
logger.info("External service call completed", extra={
"trace_id": trace_id,
"latency_ms": round(elapsed_ms, 2),
"status_code": response.status_code
return ActionOutput(
success=True,
message="Operation completed successfully",
data=response.json(),
trace_id=trace_id
logger.error("HTTP error during external call", extra={"trace_id": trace_id, "status": e.response.status_code})
return ActionOutput(success=False, message=f"HTTP {e.response.status_code}: {e.response.text}", trace_id=trace_id)
logger.exception("Unexpected failure in action handler", extra={"trace_id": trace_id})
return ActionOutput(success=False, message=str(e), trace_id=trace_id)
The middleware constructs headers dynamically and uses httpx.AsyncClient for non-blocking I/O. The explicit 28-second guard prevents the Genesys Cloud platform from killing the process mid-execution. The platform expects the handler to return a valid JSON object matching the output schema. Returning malformed JSON causes a 400 Bad Request at the platform ingress layer.
Step 3: Validate Against SDK Constraints and Register Action
Action registration requires serializing the handler metadata into the Action model expected by the SDK. You must define the action version, timeout configuration, and input/output schemas in the payload. The SDK validates these fields against OpenAPI specifications before transmission.
from genesyscloud.platform.v2 import ActionsApi
from genesyscloud.platform.v2.models import Action, ActionDefinition, ActionSchema
def register_action(client: PureCloudPlatformClientV2, action_name: str, version: str) -> dict:
Registers a Data Action with Genesys Cloud.
Required OAuth scope: platform:action:write
actions_api = ActionsApi(client)
# Construct the action definition matching SDK type constraints
action_def = ActionDefinition(
name=action_name,
description="Customer data lookup and mutation handler",
version=version,
timeout=30000, # Milliseconds. Must not exceed 30000
input_schema=ActionSchema(
type="object",
properties={
"customer_id": {"type": "string", "pattern": "^cust_[a-zA-Z0-9]+$"},
"request_type": {"type": "string", "enum": ["lookup", "update", "delete"]},
"payload": {"type": "object"}
required=["customer_id", "request_type"]
output_schema=ActionSchema(
type="object",
properties={
"success": {"type": "boolean"},
"message": {"type": "string"},
"data": {"type": "object"},
"trace_id": {"type": "string"}
required=["success", "message"]
action = Action(action_definition=action_def)
# SDK call translates to POST /api/v2/platform/actions
response = actions_api.post_platform_action(action_body=action)
logger.info("Action registered successfully", extra={
"action_id": response.id,
"version": response.version,
"status": response.state
return response.to_dict()
The timeout field must be exactly 30000 milliseconds. The platform rejects values above this threshold. Version management follows semantic versioning. Incrementing the version creates a new immutable revision. The SDK returns the action_id which you must store for subsequent updates or executions.
Step 4: Error Handling, Retry Logic, Monitoring, and Audit Logging
Production actions require structured retry policies for transient failures, latency tracking for SLO compliance, and audit trails for security reviews. The tenacity library provides declarative retry decorators. You must configure exponential backoff with jitter to avoid thundering herd problems during external service degradation.
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
import json
class ActionExecutionError(Exception):
"""Custom exception for action-specific failures"""
pass
@retry(
stop=stop_after_attempt(3),
wait=wait_exponential(multiplier=1, min=2, max=10),
retry=retry_if_exception_type((httpx.NetworkError, httpx.TimeoutException)),
reraise=True
def execute_with_retry(client: ExternalServiceClient, input_data: ActionInput) -> ActionOutput:
result = client.execute_operation(input_data)
if not result.success:
raise ActionExecutionError(f"Action failed: {result.message}")
return result
def generate_audit_log(action_id: str, input_data: ActionInput, output: ActionOutput, latency_ms: float) -> str:
Generates a structured audit log entry for compliance tracking.
audit_entry = {
"action_id": action_id,
"version": "1.0.0",
"input_hash": hash(json.dumps(input_data.model_dump(), sort_keys=True)),
"output_status": output.success,
"trace_id": output.trace_id,
"latency_ms": latency_ms,
"compliance_level": "SOC2_TYPE2",
"pii_masked": True
return json.dumps(audit_entry)
def export_action_metadata(action_id: str, schema_version: str) -> dict:
Exports action metadata for external developer portal synchronization.
Required OAuth scope: platform:action:read
# Simulated metadata export structure
"portal_sync_id": f"portal_{action_id}",
"schema_version": schema_version,
"input_schema": ActionInput.model_json_schema(),
"output_schema": ActionOutput.model_json_schema(),
"documentation_url": f"https://docs.example.com/actions/{action_id}",
"exported_at": datetime.now(timezone.utc).isoformat()
The retry decorator intercepts network errors and timeouts, applying exponential backoff. The audit log function hashes the input payload to prevent storing sensitive data while maintaining traceability. The metadata export function serializes Pydantic schemas into JSON Schema format for external documentation portals.
The following script combines all components into a runnable module. Replace the environment variables and external service URL before execution.
import os
import logging
import asyncio
import httpx
import uuid
import json
customer_id: str = Field(..., pattern=r"^cust_[a-zA-Z0-9]+$")
request_type: str = Field(..., pattern=r"^(lookup|update|delete)$")
payload: dict = Field(default_factory=dict)
success: bool
message: str
data: dict = Field(default_factory=dict)
trace_id: str = Field(default="unknown")
pass
def _build_headers(self) -> dict:
async def execute_operation(self, input_data: ActionInput) -> ActionOutput:
logger.info("External service call completed", extra={"trace_id": trace_id, "latency_ms": round(elapsed_ms, 2)})
return ActionOutput(success=True, message="Operation completed successfully", data=response.json(), trace_id=trace_id)
logger.exception("Unexpected failure", extra={"trace_id": trace_id})
@retry(
reraise=True
loop = asyncio.new_event_loop()
result = loop.run_until_complete(client.execute_operation(input_data))
loop.close()
return result
name=action_name,
version=version,
timeout=30000,
type="object",
properties={
type="object",
properties={
logger.info("Action registered successfully", extra={"action_id": response.id, "version": response.version})
audit_entry = {
def main():
genesys_client = PureCloudPlatformClientV2()
genesys_client.set_environment(os.getenv("GENESYS_ENVIRONMENT", "mypurecloud.ie2"))
genesys_client.set_credentials(
genesys_client.login()
reg_response = register_action(genesys_client, "customer_data_handler", "1.0.0")
action_id = reg_response["id"]
external_client = ExternalServiceClient(
base_url=os.getenv("EXTERNAL_SERVICE_URL"),
api_key=os.getenv("EXTERNAL_API_KEY")
test_input = ActionInput(customer_id="cust_abc123", request_type="lookup", payload={"region": "us-east"})
start = time.perf_counter()
result = execute_with_retry(external_client, test_input)
latency = (time.perf_counter() - start) * 1000
audit_log = generate_audit_log(action_id, test_input, result, latency)
logger.info("Audit log generated", extra={"audit": audit_log})
logger.info("Action execution completed", extra={"trace_id": result.trace_id, "latency_ms": round(latency, 2)})
except ActionExecutionError as e:
logger.error("Action execution failed after retries", extra={"error": str(e)})
logger.exception("Critical failure in action pipeline", extra={"error": str(e)})
main()
- Cause: Expired OAuth token, invalid client credentials, or missing
platform:action:writescope. - Fix: Verify the client ID and secret in the Admin Console. Ensure the OAuth application has the required scopes assigned. The SDK automatically refreshes tokens, but initial credential rotation requires a new
client.login()call. - Code adjustment: Add explicit scope validation during initialization.
if not all(s in client.get_scopes() for s in ["platform:action:write", "platform:action:read"]):
raise PermissionError("Missing required OAuth scopes for action registration")
Error: 403 Forbidden
- Cause: The OAuth application lacks permission to write actions, or the action name conflicts with a reserved platform namespace.
- Fix: Assign the
Action AdministratororDeveloperrole to the OAuth application. Use a unique action name prefix to avoid namespace collisions. - Code adjustment: Implement name validation before registration.
if not action_name.startswith("custom_"):
raise ValueError("Action names must be prefixed with 'custom_' to avoid platform conflicts")
- Cause: Exceeding the platform rate limit of 100 requests per second for action registration or execution.
- Fix: Implement client-side rate limiting. The SDK does not enforce this automatically. Use a token bucket algorithm or sleep intervals between batch operations.
- Code adjustment: Add a rate limiter wrapper.
from collections import deque
class RateLimiter:
def __init__(self, max_calls: int, period: float):
self.max_calls = max_calls
self.period = period
self.calls = deque()
def acquire(self):
now = time.time()
while self.calls and self.calls[0] < now - self.period:
self.calls.popleft()
if len(self.calls) >= self.max_calls:
sleep_time = self.period - (now - self.calls[0])
if sleep_time > 0:
time.sleep(sleep_time)
self.calls.append(time.time())
Error: 504 Gateway Timeout
- Cause: The external service call exceeded the 30-second Genesys Cloud execution limit.
- Fix: Reduce external service timeout values. Implement circuit breakers to fail fast when downstream services degrade. Never block the main thread for synchronous HTTP calls.
- Code adjustment: The 28-second guard in
execute_operationprevents this. Ensure external service SLAs align with the limit.
