Building Fallback Response Handlers for NICE Cognigy.AI Using Python
This tutorial builds a FastAPI webhook service that captures low-confidence intent predictions from Cognigy.AI, searches a local vector database for semantically similar knowledge base articles, formats the best matches using template variables, and pushes the results back into the Cognigy session state to maintain context across conversation retries. The implementation uses the Cognigy.AI REST API for session management and HTTPX for asynchronous communication. The code is written in Python 3.10+ with FastAPI, FAISS, and sentence-transformers.
- Cognigy.AI OAuth 2.0 Client Credentials grant with
session:writeandwebhook:executescopes - Cognigy.AI REST API v1
- Python 3.10 or higher
- Dependencies:
fastapi,uvicorn,httpx,faiss-cpu,sentence-transformers,pydantic,tenacity
Install the required packages before proceeding:
pip install fastapi uvicorn httpx faiss-cpu sentence-transformers pydantic tenacity
Cognigy.AI uses OAuth 2.0 Client Credentials for external integrations. The service must acquire an access token, cache it, and refresh it before expiration. The token endpoint requires the client ID, client secret, and requested scopes.
import httpx
from typing import Optional
class CognigyAuth:
def __init__(self, instance: str, client_id: str, client_secret: str, scopes: list[str]):
self.instance = instance
self.client_id = client_id
self.scopes = scopes
self.expires_at: float = 0.0
self.base_url = f"https://{instance}.cognigy.ai"
if self.token and time.time() < self.expires_at - 60:
return self.token
response = await client.post(
f"{self.base_url}/oauth/token",
data={
"client_id": self.client_id,
"scope": " ".join(self.scopes)
response.raise_for_status()
payload = response.json()
self.token = payload["access_token"]
self.expires_at = time.time() + payload["expires_in"]
return self.token
The CognigyAuth class handles token acquisition and caches the token until sixty seconds before expiration. The session:write scope is required for updating session variables. The webhook:execute scope is required for webhook invocation.
Step 1: Webhook Ingestion and Confidence Filtering
Cognigy.AI sends a JSON payload to registered webhooks when a trigger condition is met. The payload contains the user input, session identifier, predicted intent, and confidence score. The webhook must filter requests based on a confidence threshold before processing.
from fastapi import FastAPI, HTTPException, Request
from typing import Any, Dict, Optional
app = FastAPI(title="Cognigy Fallback Handler")
class CognigyWebhookPayload(BaseModel):
input: str
session: Dict[str, Any]
intent: Dict[str, Any]
botId: str
userId: Optional[str] = None
timestamp: int
CONFIDENCE_THRESHOLD = 0.60
@app.post("/webhook/fallback")
async def handle_fallback(payload: CognigyWebhookPayload):
confidence = payload.intent.get("confidence", 0.0)
if confidence >= CONFIDENCE_THRESHOLD:
return {"status": "ignored", "reason": "confidence_above_threshold"}
session_id = payload.session.get("id")
if not session_id:
raise HTTPException(status_code=400, detail="Missing session identifier")
return await process_low_confidence(payload.input, session_id)
The endpoint validates the payload structure and extracts the confidence value. If the confidence meets or exceeds the threshold, the webhook returns immediately without modifying the session. This prevents unnecessary processing for high-confidence matches.
Step 2: Vector Database Query Using Cosine Distance
Semantic search requires converting the user input into a dense vector and comparing it against a pre-indexed knowledge base. FAISS provides efficient similarity search. Cosine distance is computed using inner product search on L2-normalized vectors.
import faiss
import numpy as np
from sentence_transformers import SentenceTransformer
EMBEDDING_MODEL = "sentence-transformers/all-MiniLM-L6-v2"
model = SentenceTransformer(EMBEDDING_MODEL)
# Simulated knowledge base for demonstration
KB_SNIPPETS = [
"To reset your password, navigate to settings and select account recovery.",
"Billing inquiries can be resolved by contacting support at help@example.com.",
"The application requires a stable internet connection to sync data properly.",
"Subscription plans renew automatically on the anniversary date.",
"To export your data, use the admin console under data management."
# Precompute and normalize embeddings
kb_embeddings = model.encode(KB_SNIPPETS, normalize_embeddings=True)
kb_embeddings = np.array(kb_embeddings, dtype=np.float32)
dimension = kb_embeddings.shape[1]
# Initialize FAISS index for inner product (cosine similarity on normalized vectors)
index = faiss.IndexFlatIP(dimension)
index.add(kb_embeddings)
async def query_knowledge_base(query: str, top_k: int = 3) -> list[dict]:
query_embedding = model.encode(query, normalize_embeddings=True)
query_vector = np.array([query_embedding], dtype=np.float32)
distances, indices = index.search(query_vector, top_k)
results = []
for score, idx in zip(distances[0], indices[0]):
if score < 0.5: # Minimum similarity threshold
break
results.append({
"snippet": KB_SNIPPETS[idx],
"similarity": float(score)
return results
The code loads a lightweight transformer model and builds a FAISS index. The normalize_embeddings=True parameter ensures that inner product distance equals cosine similarity. The search function returns snippets that exceed a similarity threshold of 0.5.
Step 3: Template Formatting and Session State Update
The retrieved snippets must be formatted into a conversational response and pushed back to Cognigy.AI. The Cognigy session state API accepts a JSON payload containing key-value pairs. The service must handle rate limits and authentication errors.
from string import Template
from tenacity import retry, wait_exponential, stop_after_attempt, retry_if_exception_type
RESPONSE_TEMPLATE = Template(
"I could not match your request with high confidence. "
"Based on your input, here are some relevant options: "
"$options. Please rephrase your question or select a topic."
async def update_cognigy_session(auth: CognigyAuth, session_id: str, variables: dict) -> dict:
token = await auth.get_token()
url = f"{auth.base_url}/api/v1/sessions/{session_id}/state"
headers = {
payload = {"variables": variables}
response = await client.put(url, json=payload, headers=headers)
return response.json()
async def process_low_confidence(user_input: str, session_id: str) -> dict:
auth = CognigyAuth(
instance="your-instance",
client_id="YOUR_CLIENT_ID",
client_secret="YOUR_CLIENT_SECRET",
scopes=["session:write", "webhook:execute"]
snippets = await query_knowledge_base(user_input, top_k=3)
if not snippets:
fallback_text = "I could not find a matching article. Please try again with different keywords."
options = fallback_text
else:
formatted_snippets = [f"{i+1}. {s['snippet']} (confidence: {s['similarity']:.2f})" for i, s in enumerate(snippets)]
options = " ".join(formatted_snippets)
formatted_response = RESPONSE_TEMPLATE.substitute(options=options)
await update_cognigy_session(
auth=auth,
session_id=session_id,
variables={
"fallbackResponse": formatted_response,
"fallbackTriggered": True,
"fallbackSimilarityScore": float(snippets[0]["similarity"]) if snippets else 0.0
"status": "updated",
"session_id": session_id,
"response": formatted_response
raise HTTPException(status_code=e.response.status_code, detail=str(e))
The update_cognigy_session function authenticates the request and sends a PUT request to /api/v1/sessions/{sessionId}/state. The Cognigy platform merges the provided variables into the existing session object. The template substitutes the top results into a conversational string.
Step 4: Rate Limit Handling and Retry Logic
Cognigy.AI enforces rate limits on session state updates. The service must implement exponential backoff for 429 responses. The tenacity library provides declarative retry decorators.
@retry(
retry=retry_if_exception_type(httpx.HTTPStatusError),
wait=wait_exponential(multiplier=1, min=2, max=30),
stop=stop_after_attempt(3)
async def update_cognigy_session_with_retry(auth: CognigyAuth, session_id: str, variables: dict) -> dict:
headers = {
retry_after = int(response.headers.get("Retry-After", 5))
raise httpx.HTTPStatusError("Rate limited", request=response.request, response=response)
The decorator catches HTTP status errors, waits exponentially between attempts, and stops after three failures. The manual check for 429 extracts the Retry-After header and sleeps before raising the exception to trigger the retry loop. Replace the previous update_cognigy_session call with this function in production deployments.
import asyncio
import httpx
import faiss
import numpy as np
KB_SNIPPETS = [
class CognigyAuth:
return self.token
data={
return self.token
input: str
botId: str
timestamp: int
@retry(
results = []
if score < 0.5:
break
results.append({"snippet": KB_SNIPPETS[idx], "similarity": float(score)})
return results
auth = CognigyAuth(
if not snippets:
options = "I could not find a matching article. Please try again with different keywords."
else:
auth=auth,
variables={
return {"status": "updated", "session_id": session_id, "response": formatted_response}
if not session_id:
import uvicorn
uvicorn.run(app, host="0.0.0.0", port=8000)
Run the service with python main.py. The server listens on port 8000. Configure Cognigy.AI to send low-confidence webhook events to http://your-server:8000/webhook/fallback.
The OAuth token has expired or the client credentials are invalid. Verify that the client_id and client_secret match the Cognigy.AI integration settings. Ensure the token endpoint returns a valid access_token. Check the expires_in field and confirm the caching logic does not reuse expired tokens.
Error: 403 Forbidden
The OAuth token lacks the required scopes. The Cognigy.AI instance requires session:write for state updates and webhook:execute for external triggers. Regenerate the OAuth client with both scopes enabled. Confirm that the webhook URL is whitelisted in the Cognigy security settings.
Cognigy.AI enforces rate limits on session state mutations. The retry decorator handles this automatically. If the error persists, reduce the webhook trigger frequency or batch session updates. Monitor the Retry-After header value to adjust backoff intervals.
Error: FAISS Dimension Mismatch
The embedding model output dimension does not match the FAISS index dimension. This occurs when switching transformer models without rebuilding the index. Verify that kb_embeddings.shape[1] matches the dimension parameter in faiss.IndexFlatIP. Rebuild the index if the model changes.
