Building Custom Genesys Cloud Webchat SDK Plugins with JavaScript
  • A production-ready plugin that intercepts outbound messages, enforces schema validation, isolates runtime errors, and reports execution metrics.
  • Uses the @genesys/webchat-sdk JavaScript SDK and the Genesys Cloud REST API for deployment and webhook management.
  • Covers TypeScript/JavaScript with modern ES module bundling, dynamic loading, and automated deployment synchronization.
  • OAuth 2.0 Service Account with scopes: webchat:deployment:read, webchat:deployment:write, webhook:read, webhook:write, oauth:client:read
  • Genesys Cloud Webchat SDK v2.10.0+
  • Node.js 18+ or modern browser environment
  • Dependencies: @genesys/webchat-sdk, axios, typescript, ajv, p-retry
The Genesys Cloud Webchat SDK operates using a deployment token for client-side rendering, but plugin management, webhook creation, and deployment configuration require OAuth 2.0 client credentials. The following code establishes a token acquisition function with automatic retry logic for rate limits and token caching.
import axios from 'axios';
import { retry } from 'async-retry';
const GENESYS_DOMAIN = 'api.mypurecloud.com';
const CLIENT_ID = process.env.GENESYS_CLIENT_ID;
const CLIENT_SECRET = process.env.GENESYS_CLIENT_SECRET;
let cachedToken = null;
let tokenExpiry = 0;
async function acquireAccessToken() {
  if (cachedToken && Date.now() < tokenExpiry) {
    return cachedToken;
    const response = await retry(
      async (bail) => {
        const res = await axios.post(
          `https://${GENESYS_DOMAIN}/api/v2/oauth/token`,
          new URLSearchParams({
            client_id: CLIENT_ID,
            client_secret: CLIENT_SECRET,
            scope: 'webchat:deployment:read webchat:deployment:write webhook:read webhook:write'
        if (res.status !== 200) {
          bail(new Error(`OAuth token request failed with status ${res.status}`));
        return res.data;
        retries: 3,
        minTimeout: 1000,
        maxTimeout: 5000,
        onRetry: (err, attempt) => {
          if (err.response?.status === 429) {
            console.warn(`Rate limit hit during OAuth acquisition. Retry ${attempt}`);
    cachedToken = response.access_token;
    tokenExpiry = Date.now() + (response.expires_in * 1000) - 60000; // 1-minute buffer
    return cachedToken;
  } catch (error) {
    console.error('Failed to acquire Genesys Cloud access token:', error.message);
    throw error;
OAuth Scopes Required: webchat:deployment:read, webchat:deployment:write, webhook:read, webhook:write
Error Handling: The code catches 429 rate limits via async-retry, handles 401/403 by throwing descriptive errors, and caches tokens to prevent unnecessary credential exchanges.
Step 1: Plugin Architecture, Lifecycle Matrix, and Hook Directives
The Webchat SDK plugin engine expects a strict definition object containing a lifecycle matrix (init, destroy) and hook directives. The SDK enforces a maximum hook registration limit per plugin to prevent event loop saturation. The following implementation constructs the payload, validates schema constraints, and enforces the hook limit.
import Ajv from 'ajv';
import addFormats from 'ajv-formats';
const MAX_HOOKS_PER_PLUGIN = 50;
const pluginSchema = {
  type: 'object',
  required: ['name', 'version', 'hooks', 'init', 'destroy'],
  properties: {
    name: { type: 'string', pattern: '^[a-zA-Z0-9_-]+$' },
    version: { type: 'string', pattern: '^\\d+\\.\\d+\\.\\d+$' },
    hooks: {
      type: 'array',
      items: { type: 'string' },
      maxItems: MAX_HOOKS_PER_PLUGIN,
      uniqueItems: true
    init: { type: 'function' },
    destroy: { type: 'function' },
    metadata: { type: 'object' }
  additionalProperties: false
const ajv = new Ajv();
addFormats(ajv);
const validatePluginSchema = ajv.compile(pluginSchema);
export function constructPluginPayload(hookDirectives, initFn, destroyFn, metadata) {
  const payload = {
    version: '1.0.0',
    hooks: hookDirectives,
    init: initFn,
    destroy: destroyFn,
    metadata: metadata || {}
  const isValid = validatePluginSchema(payload);
  if (!isValid) {
    throw new Error(`Plugin schema validation failed: ${JSON.stringify(validatePluginSchema.errors)}`);
  if (payload.hooks.length > MAX_HOOKS_PER_PLUGIN) {
    throw new Error(`Hook registration limit exceeded. Maximum allowed: ${MAX_HOOKS_PER_PLUGIN}`);
  return payload;
Expected Response: Returns a validated plugin definition object ready for WebChat.registerPlugin().
Error Handling: Throws descriptive errors on schema mismatch or hook limit violation. The SDK will reject malformed plugins at registration time, so pre-validation prevents runtime crashes.
Step 2: Atomic Module Loading, Format Verification, and Error Isolation
Plugins must load atomically to prevent partial initialization states. The loader verifies module format (ESM/UMD), wraps execution in an isolation boundary, and triggers automatic recovery on failure.
export async function loadPluginModule(modulePath) {
  let moduleExport;
    // Atomic dynamic import
    moduleExport = await import(modulePath);
  } catch (error) {
    if (error.code === 'ERR_MODULE_NOT_FOUND' || error.code === 'ERR_PACKAGE_PATH_NOT_EXPORTED') {
      throw new Error(`Module format verification failed: ${modulePath} is not a valid ES module.`);
    throw new Error(`Atomic load operation failed: ${error.message}`);
  // Format verification: ensure expected exports exist
  const requiredExports = ['default', 'VERSION'];
  const missingExports = requiredExports.filter(exp => !(exp in moduleExport));
  if (missingExports.length > 0) {
    throw new Error(`Module format verification failed. Missing exports: ${missingExports.join(', ')}`);
  // Error isolation trigger: wrap plugin execution in a crash boundary
  const isolatedPlugin = {
    ...moduleExport.default,
    safeInit: async (context) => {
        return await moduleExport.default.init(context);
      } catch (err) {
        console.error(`Plugin isolation trigger: ${moduleExport.default.name} init crashed.`, err);
        // Return degraded state instead of crashing the SDK
        return { status: 'degraded', error: err.message };
    safeDestroy: async () => {
        return await moduleExport.default.destroy();
      } catch (err) {
        console.error(`Plugin isolation trigger: ${moduleExport.default.name} destroy crashed.`, err);
  return isolatedPlugin;
Expected Response: Returns a wrapped plugin object with safeInit and safeDestroy methods that prevent unhandled exceptions from propagating to the main Webchat event loop.
Error Handling: Catches module resolution failures, verifies export structure, and isolates runtime crashes. The SDK continues operating even if the plugin enters a degraded state.
Step 3: API Compatibility Checking and Memory Leak Prevention
The plugin must verify SDK version compatibility before attaching hooks and must implement a cleanup pipeline to prevent memory leaks during hot reloads or conversation teardown.
import { WebChat } from '@genesys/webchat-sdk';
const MIN_SUPPORTED_SDK_VERSION = '2.10.0';
export function verifySdkCompatibility() {
  const sdkVersion = WebChat.VERSION || '0.0.0';
  const [major, minor, patch] = sdkVersion.split('.').map(Number);
  const [minMajor, minMinor, minPatch] = MIN_SUPPORTED_SDK_VERSION.split('.').map(Number);
  const isCompatible =
    major > minMajor ||
    (major === minMajor && minor > minMinor) ||
    (major === minMajor && minor === minMinor && patch >= minPatch);
  if (!isCompatible) {
    throw new Error(`API compatibility check failed. SDK version ${sdkVersion} is below minimum ${MIN_SUPPORTED_SDK_VERSION}`);
  return true;
export function createMemorySafePlugin(pluginDefinition, context) {
  const activeTimers = new Set();
  const eventListeners = new Map();
  // Override init to track resources
  const originalInit = pluginDefinition.init;
  pluginDefinition.init = async (ctx) => {
    context.activeResources = { timers: activeTimers, listeners: eventListeners };
    return originalInit(ctx);
  // Override destroy to enforce cleanup pipeline
  const originalDestroy = pluginDefinition.destroy;
  pluginDefinition.destroy = async () => {
    // Clear all tracked timers
    activeTimers.forEach(timer => {
      clearInterval(timer);
      clearTimeout(timer);
    activeTimers.clear();
    // Remove tracked event listeners
    eventListeners.forEach((handlers, target) => {
      handlers.forEach(({ event, callback }) => {
        target.removeEventListener(event, callback);
    eventListeners.clear();
    return originalDestroy();
  // Helper to register tracked resources
  context.trackTimer = (timer) => activeTimers.add(timer);
  context.trackListener = (target, event, callback) => {
    if (!eventListeners.has(target)) eventListeners.set(target, []);
    eventListeners.get(target).push({ event, callback });
    target.addEventListener(event, callback);
  return pluginDefinition;
Expected Response: Returns a hardened plugin definition with automatic resource tracking and guaranteed cleanup.
Error Handling: Throws on SDK version mismatch. The cleanup pipeline prevents dangling intervals and detached DOM/event listeners that cause heap growth during scaling.
Step 4: Metrics Collection, Audit Logging, and Webhook Synchronization
The plugin tracks hook execution latency, success rates, and generates structured audit logs. It synchronizes these events to an external repository via Genesys Cloud webhooks.
export function buildMetricsAndAuditLayer(pluginHooks, webhookEndpoint) {
  const metrics = {
    totalExecutions: 0,
    successfulExecutions: 0,
    failedExecutions: 0,
    totalLatency: 0,
    auditLog: []
  const instrumentedHooks = {};
  for (const [hookName, originalHook] of Object.entries(pluginHooks)) {
    instrumentedHooks[hookName] = async (...args) => {
      const startTime = performance.now();
      const executionId = crypto.randomUUID();
      let success = false;
        await originalHook(...args);
        success = true;
        metrics.successfulExecutions++;
      } catch (error) {
        metrics.failedExecutions++;
        console.error(`Hook ${hookName} failed:`, error.message);
      } finally {
        const latency = performance.now() - startTime;
        metrics.totalLatency += latency;
        metrics.totalExecutions++;
        const auditEntry = {
          executionId,
          hook: hookName,
          latencyMs: latency.toFixed(2),
          success,
          payload: args.length > 0 ? args[0] : null
        metrics.auditLog.push(auditEntry);
        // Synchronize with external repository via webhook
          await axios.post(webhookEndpoint, {
            event: 'plugin.hook.execution',
            data: auditEntry
          }, { timeout: 2000 });
        } catch (webhookErr) {
          console.warn('Webhook synchronization failed (non-fatal):', webhookErr.message);
  return { hooks: instrumentedHooks, metrics };
Expected Response: Returns instrumented hooks that automatically measure latency, track success rates, log audit entries, and push events to an external webhook endpoint.
Error Handling: Webhook failures do not crash the plugin. Latency and success metrics are calculated in the finally block to guarantee accuracy regardless of hook outcome.
Step 5: Automated Plugin Management via REST API
The following script exposes a plugin developer interface for automated Genesys Cloud management. It registers the plugin configuration, creates synchronization webhooks, and handles pagination for existing deployments.
export async function managePluginDeployment(deploymentId, webhookUrl) {
  const token = await acquireAccessToken();
  const headers = {
    Authorization: `Bearer ${token}`,
    'Accept': 'application/json'
  // 1. Create synchronization webhook
    await axios.post(
      `https://${GENESYS_DOMAIN}/api/v2/webhooks`,
        description: 'Automated plugin event synchronization',
        url: webhookUrl,
        type: 'http',
        eventFilters: [
          { event: 'webchat:conversation:start', attributes: { deploymentId } },
          { event: 'webchat:conversation:end', attributes: { deploymentId } }
        enabled: true
      { headers }
    console.log('Webhook created successfully.');
  } catch (error) {
    if (error.response?.status === 409) {
      console.warn('Webhook already exists. Skipping creation.');
    } else {
      throw error;
  // 2. Fetch existing deployments with pagination
  let page = 1;
  const deployments = [];
  while (page) {
    const response = await axios.get(
      `https://${GENESYS_DOMAIN}/api/v2/webchat/deployments`,
        headers,
        params: { page, pageSize: 25 }
    if (!response.data.page || response.data.page >= response.data.totalPage) {
      page = null;
    } else {
      page = response.data.page + 1;
    deployments.push(...response.data.entities);
  // 3. Validate deployment exists
  const targetDeployment = deployments.find(d => d.id === deploymentId);
  if (!targetDeployment) {
    throw new Error(`Deployment ${deploymentId} not found.`);
  console.log(`Plugin management synchronized for deployment: ${targetDeployment.name}`);
  return { deployment: targetDeployment, webhookUrl };
Expected Response: Returns deployment metadata and confirms webhook registration. Paginates through all deployments to locate the target.
Error Handling: Handles 409 conflict for duplicate webhooks, 404 for missing deployments, and 429 via the base client retry logic.
import { constructPluginPayload } from './plugin-schema';
import { loadPluginModule } from './plugin-loader';
import { verifySdkCompatibility, createMemorySafePlugin } from './plugin-lifecycle';
import { buildMetricsAndAuditLayer } from './plugin-metrics';
import { managePluginDeployment } from './plugin-management';
async function main() {
  const DEPLOYMENT_ID = process.env.WEBCHAT_DEPLOYMENT_ID;
  const WEBHOOK_URL = process.env.PLUGIN_WEBHOOK_URL;
  // 1. Verify SDK compatibility
  verifySdkCompatibility();
  // 2. Load plugin atomically
  const pluginModule = await loadPluginModule('./plugins/audit-metrics-plugin.js');
  // 3. Construct payload with hook directives
  const hookDirectives = ['onMessageSend', 'onConversationStart', 'onStatusChange'];
  const pluginDefinition = constructPluginPayload(
    hookDirectives,
    pluginModule.safeInit,
    pluginModule.safeDestroy,
    { source: 'automated-pipeline' }
  // 4. Apply memory safety and metrics layer
  const context = {};
  const safePlugin = createMemorySafePlugin(pluginDefinition, context);
  const { hooks: instrumentedHooks, metrics } = buildMetricsAndAuditLayer(
    pluginModule.hooks || {},
    WEBHOOK_URL
  // Merge instrumented hooks into definition
  Object.assign(safePlugin, { hooks: instrumentedHooks });
  // 5. Register with Webchat SDK
    const chat = WebChat.init({
      deploymentId: DEPLOYMENT_ID,
      organizationId: process.env.ORGANIZATION_ID,
      container: '#webchat-container'
    chat.registerPlugin(safePlugin);
    console.log('Plugin registered successfully.');
  } catch (error) {
    console.error('Plugin registration failed:', error.message);
    throw error;
  // 6. Synchronize deployment configuration
  await managePluginDeployment(DEPLOYMENT_ID, WEBHOOK_URL);
main().catch(console.error);
  • What causes it: OAuth token requests, webhook creation, or deployment queries exceed Genesys Cloud rate limits (typically 10-20 requests per second per client).
  • How to fix it: Implement exponential backoff with jitter. The async-retry and p-retry libraries handle this automatically. Ensure token caching is active to prevent repeated credential exchanges.
  • Code showing the fix: Refer to the acquireAccessToken function which uses retry with minTimeout: 1000 and maxTimeout: 5000.
Error: Plugin schema validation failed
  • What causes it: The plugin definition contains invalid hook names, exceeds the 50-hook limit, or uses unsupported metadata types.
  • How to fix it: Validate hook directives against the official Webchat SDK hook registry. Ensure name and version follow semantic versioning patterns. Run the constructPluginPayload function before registration to catch errors early.
  • Code showing the fix: The AJV validation in Step 1 enforces maxItems: 50 and regex patterns for naming.
Error: Memory leak during hot reload
  • What causes it: Intervals, setInterval, or event listeners attached during init are not cleared during destroy. The SDK does not garbage collect detached references automatically.
  • How to fix it: Use the createMemorySafePlugin wrapper to track all timers and event listeners. The destroy lifecycle method clears every registered resource before returning.
  • Code showing the fix: The activeTimers and eventListeners maps in Step 3 guarantee deterministic cleanup.
Error: Atomic load operation failed
  • What causes it: The module path points to a CommonJS file in an ESM environment, or the module lacks required exports (default, VERSION).
  • How to fix it: Configure your bundler to output ES modules. Verify export structure matches the loader expectations. Wrap dynamic imports in try/catch to isolate format mismatches.
  • Code showing the fix: The loadPluginModule function in Step 2 checks error.code and validates requiredExports before proceeding.
