Building Custom Genesys Cloud Flow REST Nodes with Go
- A Go application that programmatically registers a Genesys Cloud custom integration REST node, executes it locally with dynamic variable injection, implements retry logic with configurable backoff, validates responses against JSON schemas, caches results, and exposes a simulator endpoint for flow testing.
- This uses the Genesys Cloud Custom Integrations API (
/api/v2/custom-integrations/nodes) and the official Genesys Cloud Go SDK. - The tutorial covers Go 1.21+ with production-grade HTTP handling, concurrency-safe caching, and JSON schema validation.
- OAuth Client ID and Secret with
custom-integrations:node:writeandcustom-integrations:node:readscopes - Genesys Cloud Go SDK v1.x (
github.com/mypurecloud/genesyscloud) - Go 1.21+ runtime
- External dependencies:
github.com/invopop/jsonschema,github.com/sethvargo/go-retry,github.com/gorilla/mux,encoding/json,crypto/sha256,sync,time,net/http,io
Genesys Cloud uses OAuth 2.0 client credentials flow for server-to-server API access. You must exchange your client ID and secret for a bearer token before initializing the SDK. The token expires after 3600 seconds and requires periodic refresh.
package main
import (
"bytes"
"encoding/json"
"fmt"
"io"
"net/http"
"os"
"time"
type OAuthTokenResponse struct {
RefreshToken string `json:"refresh_token"`
Scope string `json:"scope"`
func GetGenesysToken(clientID, clientSecret, region string) (string, error) {
url := fmt.Sprintf("https://%s/oauth/token", region)
payload := map[string]string{
"client_id": clientID,
"client_secret": clientSecret,
"scope": "custom-integrations:node:write custom-integrations:node:read",
jsonPayload, err := json.Marshal(payload)
if err != nil {
return "", fmt.Errorf("failed to marshal oauth payload: %w", err)
req, err := http.NewRequest("POST", url, bytes.NewBuffer(jsonPayload))
if err != nil {
return "", fmt.Errorf("failed to create oauth request: %w", err)
resp, err := client.Do(req)
if err != nil {
return "", fmt.Errorf("oauth request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("oauth failed with status %d: %s", resp.StatusCode, string(body))
var tokenResp OAuthTokenResponse
return "", fmt.Errorf("failed to decode oauth response: %w", err)
return tokenResp.AccessToken, nil
Step 1: Define Node Input Schema and Register via API
Genesys Cloud custom integration nodes require a JSON schema that defines the input variables available at flow runtime. The schema drives dynamic URL construction and template injection. You register the node using the /api/v2/custom-integrations/nodes endpoint.
package main
import (
"context"
"fmt"
"github.com/mypurecloud/genesyscloud"
"github.com/mypurecloud/genesyscloud/model/platform"
func RegisterCustomNode(ctx context.Context, token string, region string) (string, error) {
cfg := genesyscloud.NewConfiguration()
cfg.BasePath = fmt.Sprintf("https://%s/api/v2", region)
cfg.AccessToken = token
apiClient := genesyscloud.NewAPIClient(cfg)
customIntegrationsAPI := apiClient.PlatformAPI // Official SDK path for custom integrations
// Define input schema for dynamic URL and payload construction
inputSchema := map[string]interface{}{
"type": "object",
"properties": map[string]interface{}{
"targetId": map[string]interface{}{
"type": "string",
"description": "External system identifier for dynamic URL path",
"requestPayload": map[string]interface{}{
"type": "object",
"description": "JSON body template values",
"required": []string{"targetId"},
nodeConfig := &platform.CustomIntegrationNodeConfig{
Description: genesyscloud.String("Go-driven custom REST node with dynamic injection"),
Type: genesyscloud.String("REST"),
RequestUrl: genesyscloud.String("https://api.external-system.com/v1/resources/{{input.targetId}}"),
RequestMethod: genesyscloud.String("POST"),
RequestHeaders: map[string]string{
"Authorization": "Bearer {{input.authToken}}",
RequestBody: genesyscloud.String(`{"resourceId":"{{input.targetId}}","data":{{input.requestPayload}}}`),
ResponseSchema: &platform.JSONSchema{
Type: genesyscloud.String("object"),
Properties: map[string]*platform.JSONSchemaProperty{
"status": {Type: genesyscloud.String("string")},
"resultId": {Type: genesyscloud.String("string")},
RetryConfig: &platform.RetryConfig{
MaxRetries: genesyscloud.Int(3),
BackoffType: genesyscloud.String("exponential"),
InitialDelay: genesyscloud.Int(1000),
MaxDelay: genesyscloud.Int(10000),
node, _, err := customIntegrationsAPI.PostCustomIntegrationsNodes(ctx, nodeConfig)
if err != nil {
return "", fmt.Errorf("failed to register node: %w", err)
return *node.Id, nil
Expected Response: HTTP 201 Created with a JSON body containing id, name, type, requestUrl, and configuration metadata.
Error Handling: The SDK returns a GenericOpenAPIError on 4xx/5xx. Check resp.StatusCode for 401 (invalid token), 403 (missing scope), or 400 (invalid schema).
Step 2: Inject Flow Variables and Construct Dynamic Requests
Flow variables arrive as a JSON map. You must replace template placeholders ({{input.key}}) in URLs, headers, and body templates. This step uses a deterministic string replacement strategy that preserves JSON structure.
package main
import (
"encoding/json"
"fmt"
"regexp"
"strings"
var templateRegex = regexp.MustCompile(`\{\{input\.(\w+)\}\}`)
func InjectVariables(template string, variables map[string]interface{}) (string, error) {
result := templateRegex.ReplaceAllStringFunc(template, func(match string) string {
key := templateRegex.FindStringSubmatch(match)[1]
val, exists := variables[key]
if !exists {
return match // Preserve placeholder if variable is missing
return fmt.Sprintf("%v", val)
return result, nil
func BuildHTTPRequest(urlTemplate string, headers map[string]string, bodyTemplate string, variables map[string]interface{}) (*http.Request, error) {
resolvedURL, err := InjectVariables(urlTemplate, variables)
if err != nil {
return nil, fmt.Errorf("url injection failed: %w", err)
resolvedBody, err := InjectVariables(bodyTemplate, variables)
if err != nil {
return nil, fmt.Errorf("body injection failed: %w", err)
// Validate JSON body structure
var jsonCheck interface{}
if err := json.Unmarshal([]byte(resolvedBody), &jsonCheck); err != nil {
return nil, fmt.Errorf("injected body is not valid JSON: %w", err)
req, err := http.NewRequest("POST", resolvedURL, strings.NewReader(resolvedBody))
if err != nil {
return nil, fmt.Errorf("request creation failed: %w", err)
for k, v := range headers {
resolvedHeader, _ := InjectVariables(v, variables)
req.Header.Set(k, resolvedHeader)
return req, nil
Edge Case Handling: Missing variables preserve the original placeholder to prevent silent data loss. Invalid JSON after injection fails fast before network transmission.
Step 3: Implement Retry Logic, Caching, and JSON Schema Validation
Production REST nodes require resilience. This step implements exponential backoff retry, concurrent-safe response caching, and strict JSON schema validation using invopop/jsonschema.
package main
import (
"crypto/sha256"
"encoding/json"
"fmt"
"io"
"net/http"
"sync"
"time"
"github.com/invopop/jsonschema"
"github.com/sethvargo/go-retry"
type ResponseCache struct {
mu sync.RWMutex
entries map[string]cachedEntry
type cachedEntry struct {
statusCode int
body []byte
expiresAt time.Time
func NewResponseCache(ttl time.Duration) *ResponseCache {
return &ResponseCache{entries: make(map[string]cachedEntry)}
func (c *ResponseCache) Get(key string) ([]byte, int, bool) {
c.mu.RLock()
defer c.mu.RUnlock()
entry, exists := c.entries[key]
if !exists || time.Now().After(entry.expiresAt) {
return nil, 0, false
return entry.body, entry.statusCode, true
func (c *ResponseCache) Set(key string, body []byte, status int, ttl time.Duration) {
c.mu.Lock()
defer c.mu.Unlock()
c.entries[key] = cachedEntry{
statusCode: status,
body: body,
expiresAt: time.Now().Add(ttl),
func cacheKey(url string, body string) string {
hash := sha256.Sum256([]byte(url + body))
return fmt.Sprintf("%x", hash)
func ValidateResponse(schemaBytes []byte, responseBody []byte) error {
compiler := jsonschema.NewCompiler()
if err := compiler.AddResource("schema.json", strings.NewReader(string(schemaBytes))); err != nil {
return fmt.Errorf("schema compilation failed: %w", err)
schema, err := compiler.Compile("schema.json")
if err != nil {
return fmt.Errorf("schema compile error: %w", err)
var data interface{}
if err := json.Unmarshal(responseBody, &data); err != nil {
return fmt.Errorf("response body is not valid JSON: %w", err)
if err := schema.Validate(data); err != nil {
return fmt.Errorf("response validation failed: %w", err)
return nil
func ExecuteWithRetry(req *http.Request, client *http.Client, cache *ResponseCache, schemaBytes []byte) ([]byte, int, error) {
b := retry.NewExponential(time.Millisecond * 500)
b.Multiplier = 2.0
b.MaxDelay = time.Second * 10
ctx := context.Background()
var lastErr error
for attempt := uint(0); attempt < 3; attempt++ {
if err := retry.Sleep(ctx, b); err != nil {
return nil, 0, fmt.Errorf("retry backoff interrupted: %w", err)
cKey := cacheKey(req.URL.String(), "") // Simplified cache key for GET/POST
if cachedBody, status, found := cache.Get(cKey); found {
return cachedBody, status, nil
if err != nil {
lastErr = fmt.Errorf("http request failed: %w", err)
body, err := io.ReadAll(resp.Body)
if err != nil {
lastErr = fmt.Errorf("failed to read response: %w", err)
if resp.StatusCode >= 500 {
lastErr = fmt.Errorf("server error: %d", resp.StatusCode)
if err := ValidateResponse(schemaBytes, body); err != nil {
lastErr = fmt.Errorf("schema validation failed: %w", err)
cache.Set(cKey, body, resp.StatusCode, time.Minute*5)
return body, resp.StatusCode, nil
return nil, 0, fmt.Errorf("exhausted retries: %w", lastErr)
Non-Obvious Parameters: retry.Multiplier controls backoff growth. cacheKey combines URL and body to prevent cache collisions. Schema validation runs after successful HTTP status but before payload consumption.
Step 4: Build the Node Simulator and Error Mapping
The simulator exposes an HTTP endpoint that accepts flow variables, executes the node logic, and returns a standardized response. Error mapping translates HTTP failures into Genesys Cloud-compatible error payloads.
package main
import (
"encoding/json"
"fmt"
"net/http"
"time"
"github.com/gorilla/mux"
type FlowPayload struct {
TargetID string `json:"targetId"`
AuthToken string `json:"authToken"`
RequestPayload map[string]interface{} `json:"requestPayload"`
type NodeResponse struct {
Success bool `json:"success"`
Status int `json:"status"`
Data json.RawMessage `json:"data,omitempty"`
Error string `json:"error,omitempty"`
Retries int `json:"retries"`
type NodeSimulator struct {
httpClient *http.Client
schema []byte
func NewNodeSimulator() *NodeSimulator {
return &NodeSimulator{
cache: NewResponseCache(time.Minute * 5),
httpClient: &http.Client{Timeout: 15 * time.Second},
schema: []byte(`{
"type": "object",
"properties": {
"status": {"type": "string"},
"resultId": {"type": "string"}
"required": ["status"]
func (s *NodeSimulator) HandleSimulator(w http.ResponseWriter, r *http.Request) {
var payload FlowPayload
if err := json.NewDecoder(r.Body).Decode(&payload); err != nil {
http.Error(w, "invalid payload", http.StatusBadRequest)
return
variables := map[string]interface{}{
"targetId": payload.TargetID,
"authToken": payload.AuthToken,
"requestPayload": payload.RequestPayload,
req, err := BuildHTTPRequest(
"https://api.external-system.com/v1/resources/{{input.targetId}}",
map[string]string{
`{"resourceId":"{{input.targetId}}","data":{{input.requestPayload}}}`,
variables,
if err != nil {
writeResponse(w, NodeResponse{Success: false, Error: fmt.Sprintf("request build failed: %v", err)})
return
body, status, err := ExecuteWithRetry(req, s.httpClient, s.cache, s.schema)
if err != nil {
writeResponse(w, NodeResponse{Success: false, Status: status, Error: err.Error()})
return
writeResponse(w, NodeResponse{Success: true, Status: status, Data: body})
func writeResponse(w http.ResponseWriter, resp NodeResponse) {
json.NewEncoder(w).Encode(resp)
func main() {
r := mux.NewRouter()
sim := NewNodeSimulator()
r.HandleFunc("/simulate/node", sim.HandleSimulator).Methods("POST")
fmt.Println("Node simulator listening on :8080")
http.ListenAndServe(":8080", r)
Error Mapping: HTTP 4xx/5xx errors are caught by the retry loop. After exhaustion, the error string is serialized into the NodeResponse.Error field. Schema validation failures bypass retry if the structure is fundamentally broken.
package main
import (
"context"
"encoding/json"
"fmt"
"io"
"net/http"
"os"
"regexp"
"strings"
"sync"
"time"
mu sync.RWMutex
statusCode int
body []byte
expiresAt time.Time
c.mu.RLock()
c.mu.Lock()
defer c.mu.Unlock()
c.entries[key] = cachedEntry{statusCode: status, body: body, expiresAt: time.Now().Add(ttl)}
func InjectVariables(template string, variables map[string]interface{}) string {
return templateRegex.ReplaceAllStringFunc(template, func(match string) string {
if val, ok := variables[key]; ok {
return match
func BuildHTTPRequest(urlT, bodyT string, headers map[string]string, vars map[string]interface{}) (*http.Request, error) {
u := InjectVariables(urlT, vars)
b := InjectVariables(bodyT, vars)
var j interface{}
if err := json.Unmarshal([]byte(b), &j); err != nil {
return nil, fmt.Errorf("invalid json after injection: %w", err)
req, err := http.NewRequest("POST", u, strings.NewReader(b))
if err != nil {
return nil, err
req.Header.Set(k, InjectVariables(v, vars))
return req, nil
func ValidateResponse(schemaBytes, body []byte) error {
if err := compiler.AddResource("s", strings.NewReader(string(schemaBytes))); err != nil {
return err
s, err := compiler.Compile("s")
if err != nil {
return err
var d interface{}
if err := json.Unmarshal(body, &d); err != nil {
return err
return s.Validate(d)
func ExecuteWithRetry(req *http.Request, client *http.Client, cache *ResponseCache, schema []byte) ([]byte, int, error) {
b.Multiplier = 2.0
var lastErr error
for i := uint(0); i < 3; i++ {
return nil, 0, err
cKey := fmt.Sprintf("%x", []byte(req.URL.String()))
if cached, st, ok := cache.Get(cKey); ok {
return cached, st, nil
if err != nil {
lastErr = err
if err != nil {
lastErr = err
lastErr = fmt.Errorf("status %d", resp.StatusCode)
if err := ValidateResponse(schema, body); err != nil {
lastErr = fmt.Errorf("schema fail: %w", err)
return nil, 0, fmt.Errorf("retries exhausted: %w", lastErr)
func GetToken(id, sec, region string) (string, error) {
p := map[string]string{"grant_type": "client_credentials", "client_id": id, "client_secret": sec, "scope": "custom-integrations:node:write custom-integrations:node:read"}
j, _ := json.Marshal(p)
req, _ := http.NewRequest("POST", url, strings.NewReader(string(j)))
resp, err := http.DefaultClient.Do(req)
if err != nil {
return "", err
if resp.StatusCode != 200 {
return "", fmt.Errorf("oauth %d", resp.StatusCode)
var t OAuthTokenResponse
json.NewDecoder(resp.Body).Decode(&t)
return t.AccessToken, nil
func RegisterNode(ctx context.Context, token, region string) error {
api := genesyscloud.NewAPIClient(cfg)
node := &platform.CustomIntegrationNodeConfig{
RequestHeaders: map[string]string{"Authorization": "Bearer {{input.authToken}}"},
RetryConfig: &platform.RetryConfig{MaxRetries: genesyscloud.Int(3), BackoffType: genesyscloud.String("exponential")},
_, _, err := api.PlatformAPI.PostCustomIntegrationsNodes(ctx, node)
return err
type Simulator struct {
schema []byte
func (s *Simulator) Handle(w http.ResponseWriter, r *http.Request) {
var p FlowPayload
if err := json.NewDecoder(r.Body).Decode(&p); err != nil {
http.Error(w, "bad payload", 400)
return
v := map[string]interface{}{"targetId": p.TargetID, "authToken": p.AuthToken, "requestPayload": p.RequestPayload}
req, err := BuildHTTPRequest("https://api.external-system.com/v1/resources/{{input.targetId}}", map[string]string{"Authorization": "Bearer {{input.authToken}}"}, `{"resourceId":"{{input.targetId}}","data":{{input.requestPayload}}}`, v)
if err != nil {
w.WriteHeader(500)
json.NewEncoder(w).Encode(NodeResponse{Success: false, Error: err.Error()})
return
body, st, err := ExecuteWithRetry(req, &http.Client{Timeout: 15 * time.Second}, s.cache, s.schema)
if err != nil {
w.WriteHeader(502)
json.NewEncoder(w).Encode(NodeResponse{Success: false, Status: st, Error: err.Error()})
return
json.NewEncoder(w).Encode(NodeResponse{Success: true, Status: st, Data: body})
func main() {
region := os.Getenv("GENESYS_REGION")
clientID := os.Getenv("GENESYS_CLIENT_ID")
clientSecret := os.Getenv("GENESYS_CLIENT_SECRET")
if region == "" || clientID == "" || clientSecret == "" {
fmt.Println("Missing env vars")
return
token, err := GetToken(clientID, clientSecret, region)
if err != nil {
fmt.Println("Token error:", err)
return
if err := RegisterNode(context.Background(), token, region); err != nil {
fmt.Println("Register error:", err)
sim := &Simulator{cache: NewResponseCache(time.Minute * 5), schema: []byte(`{"type":"object","properties":{"status":{"type":"string"}},"required":["status"]}`)}
r.HandleFunc("/simulate/node", sim.Handle).Methods("POST")
fmt.Println("Simulator running on :8080")
- Cause: Expired OAuth token or missing
custom-integrations:node:writescope. - Fix: Verify client credentials and scope configuration in Genesys Cloud admin. Implement token refresh before SDK initialization.
- Code: Check
resp.StatusCodeinGetTokenand retry with a fresh client credentials request.
- Cause: Genesys Cloud API rate limits or external endpoint throttling.
- Fix: The retry loop uses exponential backoff. Add
resp.Header.Get("Retry-After")parsing for precise delay calculation. - Code: Modify
ExecuteWithRetryto readRetry-Afterheader and overridebdelay.
Error: Schema Validation Failed
- Cause: External API returns unexpected structure or missing required fields.
- Fix: Update
responseSchemain node configuration to match actual payload. Log raw response before validation during debugging. - Code: Wrap
ValidateResponsein a debug flag that printsbodybefore callings.Validate(data).
Error: Template Injection Produces Invalid JSON
- Cause: Variable values contain unescaped quotes or newlines.
- Fix: Marshal variable values to JSON strings before injection when embedding in JSON bodies.
- Code: Replace
fmt.Sprintf("%v", val)withstring(json.Marshal(val))for object/array types.
