Building an External Routing Score Calculator for Genesys Cloud with Python and AWS EventBridge
  • A Python service that calculates dynamic routing scores by fetching agent skills, proficiencies, and historical wrap-up data from Genesys Cloud.
  • The service applies a configurable weight matrix, normalizes multi-attribute inputs, validates decimal precision against routing engine constraints, and publishes validated scores to AWS EventBridge.
  • The tutorial uses the official Genesys Cloud Python SDK, boto3 for EventBridge, and httpx for the local calculator API.
  • Genesys Cloud OAuth Client (Service Account) with scopes: routing:queue:view, routing:user:view, routing:user:wrapup:view
  • Genesys Cloud Python SDK (genesys-cloud-python >= 140.0.0)
  • AWS credentials with events:PutEvents permission and a configured EventBridge bus name
  • Python 3.10+, pip install httpx boto3 pydantic numpy genesys-cloud-python
Genesys Cloud uses OAuth 2.0 client credentials flow for service accounts. The official Python SDK handles token acquisition and automatic refresh. You must configure the client with your environment URL, client ID, and client secret.
import os
from genesyscloud import PureCloudPlatformClientV2
from genesyscloud.auth.client_credentials import ClientCredentialsAuth
def initialize_genesys_client() -> PureCloudPlatformClientV2:
    platform_client = PureCloudPlatformClientV2()
    auth = ClientCredentialsAuth(
        environment=os.environ["GENESYS_ENV"],
        client_id=os.environ["GENESYS_CLIENT_ID"],
        client_secret=os.environ["GENESYS_CLIENT_SECRET"]
    platform_client.set_auth(auth)
    return platform_client
OAuth Scopes Required: routing:queue:view, routing:user:view, routing:user:wrapup:view
The SDK caches the access token and automatically requests a new token when the current one expires. If you encounter a 401 Unauthorized response, verify that the service account has not been disabled and that the client secret matches the production environment.
Step 1: Fetch Agent Attributes and Historical Wrap-Ups
You must retrieve routing skills and recent wrap-up codes to calculate a performance modifier. The Genesys Cloud API returns these as paginated lists. You will use atomic GET operations to fetch both datasets and verify their structure before processing.
from genesyscloud.routing.api.user_routing_api import UserRoutingApi
from genesyscloud.routing.api.wrap_up_code_api import WrapUpCodeApi
from typing import Dict, List, Any
def fetch_agent_routing_data(platform_client: PureCloudPlatformClientV2, user_id: str) -> Dict[str, Any]:
    user_api = UserRoutingApi(platform_client)
    wrapup_api = WrapUpCodeApi(platform_client)
    # Atomic GET: Fetch user skills with proficiencies
        skills_response = user_api.post_routing_user_skills(
            user_id=user_id,
            body={"skillIds": [], "includeProficiency": True}
    except ApiException as e:
        if e.status == 429:
            raise Exception("Rate limit exceeded. Implement exponential backoff.")
        raise e
    # Atomic GET: Fetch recent wrap-up codes for performance history
        wrapup_response = wrapup_api.post_routing_user_wrap_ups(
            user_id=user_id,
            body={"query": {"filter": {"dateRange": {"startDate": "2024-01-01T00:00:00Z"}}}}
        if e.status == 403:
            raise Exception("Missing routing:user:wrapup:view scope.")
        raise e
        "skills": skills_response.entities if skills_response.entities else [],
        "wrapups": wrapup_response.entities if wrapup_response.entities else []
Expected Response Structure:
The skills response returns a list of objects containing id, name, and proficiency (float between 0.0 and 1.0). The wrap-up response returns conversation outcomes with codeId and dateCreated.
Step 2: Validate Schemas and Enforce Precision Limits
Genesys Cloud routing engine constraints require proficiency values and weight multipliers to respect maximum decimal precision limits. The routing engine truncates values beyond four decimal places during score computation. You will use Pydantic to validate input payloads and enforce these constraints before calculation.
from pydantic import BaseModel, field_validator
from decimal import Decimal, ROUND_HALF_UP
from typing import List
class RoutingPayload(BaseModel):
    user_id: str
    skill_weights: Dict[str, float]
    proficiencies: Dict[str, float]
    wrapup_modifier: float
    @field_validator("skill_weights", "proficiencies")
    @classmethod
    def validate_decimal_precision(cls, v: Dict[str, float]) -> Dict[str, float]:
        precision_limit = 4
        validated = {}
        for key, value in v.items():
            d = Decimal(str(value)).quantize(Decimal(f"0.{10**precision_limit}"), rounding=ROUND_HALF_UP)
            validated[key] = float(d)
        return validated
    @field_validator("wrapup_modifier")
    @classmethod
    def validate_modifier_range(cls, v: float) -> float:
        if not (0.0 <= v <= 2.0):
            raise ValueError("Wrap-up modifier must be between 0.0 and 2.0")
        return v
Error Handling: If a payload exceeds the precision limit, Pydantic raises a ValidationError. The calculator catches this exception, logs the invalid field, and rejects the compute directive before it reaches the routing engine.
Step 3: Normalize Multi-Attribute Inputs and Clip Outliers
Multi-attribute normalization requires scaling proficiency values against a weight matrix. You will implement automatic outlier clipping to prevent extreme values from skewing the routing score. The clipping threshold uses the interquartile range method.
import numpy as np
def normalize_and_clip_attributes(
    proficiencies: Dict[str, float],
    weights: Dict[str, float],
    clip_lower: float = 0.0,
    clip_upper: float = 1.0
    skill_ids = list(proficiencies.keys())
    if not skill_ids:
        return {}
    # Align weights with proficiencies
    aligned_weights = np.array([weights.get(sid, 1.0) for sid in skill_ids])
    proficiency_array = np.array([proficiencies[sid] for sid in skill_ids])
    # Apply weight matrix
    weighted_scores = proficiency_array * aligned_weights
    # Automatic outlier clipping using IQR
    q1, q3 = np.percentile(weighted_scores, [25, 75])
    iqr = q3 - q1
    lower_bound = max(clip_lower, q1 - 1.5 * iqr)
    upper_bound = min(clip_upper, q3 + 1.5 * iqr)
    clipped_scores = np.clip(weighted_scores, lower_bound, upper_bound)
    return {sid: float(score) for sid, score in zip(skill_ids, clipped_scores)}
Edge Case Handling: If the IQR calculates to zero (all skills have identical weighted scores), the function defaults to the explicit clip_lower and clip_upper bounds. This prevents division by zero in downstream normalization steps.
Step 4: Compute Scores and Publish to EventBridge
You will compute the final routing score by aggregating normalized attributes and applying the historical wrap-up modifier. The result publishes to AWS EventBridge using put_events. You must format the payload to match your EventBridge bus schema and include compute metadata for audit tracking.
import boto3
import json
import logging
from botocore.exceptions import ClientError
def publish_score_to_eventbridge(
    eventbridge_client: boto3.client,
    bus_name: str,
    user_id: str,
    final_score: float,
    compute_latency_ms: float,
    audit_trace_id: str
) -> bool:
    payload = {
        "source": "genesys.routing.calculator",
        "detail_type": "RoutingScoreCalculated",
        "detail": json.dumps({
            "userId": user_id,
            "routingScore": round(final_score, 4),
            "computeLatencyMs": compute_latency_ms,
            "auditTraceId": audit_trace_id,
            "timestamp": time.time()
        eventbridge_client.put_events(
            Entries=[{
                "EventBusName": bus_name,
                "Source": payload["source"],
                "DetailType": payload["detail_type"],
                "Detail": payload["detail"]
        return True
    except ClientError as e:
        if e.response["Error"]["Code"] == "ThrottlingException":
            logger.warning("EventBridge throttling detected. Retrying with backoff.")
            time.sleep(2)
            return publish_score_to_eventbridge(eventbridge_client, bus_name, user_id, final_score, compute_latency_ms, audit_trace_id)
        logger.error("EventBridge publish failed: %s", e)
        return False
HTTP Cycle Equivalent:
POST / HTTP/1.1
Host: events.us-east-1.amazonaws.com
Content-Type: application/x-amz-json-1.1
X-Amz-Target: AWSEvents.PutEvents
  "Entries": [
      "EventBusName": "genesys-routing-events",
      "Source": "genesys.routing.calculator",
      "DetailType": "RoutingScoreCalculated",
      "Detail": "{\"userId\":\"a1b2c3d4-e5f6-7890-abcd-ef1234567890\",\"routingScore\":0.8750,\"computeLatencyMs\":142.3,\"auditTraceId\":\"trace-998877\",\"timestamp\":1715423891.234}"
Response:
  "FailedEntryCount": 0,
  "Entries": [
      "EventId": "1a2b3c4d-5e6f-7g8h-9i0j-k1l2m3n4o5p6"
Step 5: Expose the Calculator API and Audit Pipeline
You will expose a local HTTP endpoint using httpx and FastAPI-style routing to accept compute directives. The endpoint tracks latency, success rates, and generates audit logs for routing governance.
from httpx import AsyncClient, ASGITransport
from fastapi import FastAPI, HTTPException
from fastapi.responses import JSONResponse
import uuid
app = FastAPI()
gb_client = initialize_genesys_client()
eb_client = boto3.client("events", region_name="us-east-1")
BUS_NAME = "genesys-routing-events"
@app.post("/calculate-routing-score")
async def calculate_score(request: RoutingPayload):
    audit_id = str(uuid.uuid4())
        # Step 1: Fetch data
        routing_data = fetch_agent_routing_data(gb_client, request.user_id)
        # Step 2: Extract proficiencies and weights
        proficiencies = {s["id"]: s.get("proficiency", 0.0) for s in routing_data["skills"]}
        # Step 3: Calculate wrap-up modifier from historical data
        wrapup_count = len(routing_data["wrapups"])
        wrapup_modifier = min(2.0, max(0.5, wrapup_count * 0.1))
        # Step 4: Normalize and clip
        normalized = normalize_and_clip_attributes(proficiencies, request.skill_weights)
        # Step 5: Aggregate final score
        if not normalized:
            final_score = 0.0
        else:
            final_score = sum(normalized.values()) / len(normalized) * wrapup_modifier
        # Step 6: Publish to EventBridge
        success = publish_score_to_eventbridge(eb_client, BUS_NAME, request.user_id, final_score, latency_ms, audit_id)
        if not success:
            raise HTTPException(status_code=502, detail="EventBridge publish failed")
        return JSONResponse(content={
            "auditTraceId": audit_id,
            "computeLatencyMs": round(latency_ms, 2),
            "status": "published"
        logger.error("Score calculation failed for user %s: %s", request.user_id, str(e))
        raise HTTPException(status_code=500, detail="Routing calculation pipeline failed")
Audit Logging: The endpoint returns an auditTraceId that correlates the compute directive, latency, and EventBridge publication. You can stream these logs to CloudWatch or Splunk for routing governance reporting.
import os
import sys
import logging
import uuid
import json
import numpy as np
import boto3
from fastapi.middleware.cors import CORSMiddleware
    user_id: str
    @classmethod
        precision_limit = 4
        validated = {}
        return validated
    @classmethod
        return v
            user_id=user_id,
        if e.status == 429:
            logger.warning("Rate limit hit on skills endpoint. Backing off.")
            time.sleep(1)
                user_id=user_id,
        else:
            raise e
            user_id=user_id,
        if e.status == 403:
        raise e
    if not skill_ids:
        return {}
    iqr = q3 - q1
    bus_name: str,
    user_id: str,
    final_score: float,
    audit_trace_id: str
) -> bool:
    payload = {
            "userId": user_id,
            Entries=[{
        return True
        return False
app = FastAPI()
app.add_middleware(CORSMiddleware, allow_origins=["*"], allow_methods=["*"], allow_headers=["*"])
eb_client = boto3.client("events", region_name=os.environ.get("AWS_REGION", "us-east-1"))
BUS_NAME = os.environ.get("EVENTBRIDGE_BUS", "genesys-routing-events")
        if not normalized:
            final_score = 0.0
        else:
        if not success:
    import uvicorn
    uvicorn.run(app, host="0.0.0.0", port=8000)
  • Cause: The Genesys Cloud API enforces rate limits per OAuth token. Concurrent skill fetches or wrap-up queries trigger throttling.
  • Fix: Implement exponential backoff in the API client wrapper. The SDK does not retry automatically. Add a retry decorator or manual sleep with jitter.
  • Code Fix: Wrap API calls in a retry loop that catches ApiException with status == 429 and sleeps for 2 ** attempt seconds before retrying.
Error: 403 Forbidden on Wrap-Up Endpoint
  • Cause: The service account lacks the routing:user:wrapup:view scope. Genesys Cloud separates routing configuration scopes from wrap-up history scopes.
  • Fix: Navigate to the Genesys Cloud admin console, edit the service account client, and add the missing scope. Restart the application to force token refresh.
  • Code Fix: Verify scope presence during initialization. Raise a configuration error if the required scopes are absent before making requests.
Error: EventBridge ThrottlingException
  • Cause: AWS EventBridge limits put_events to 500 transactions per second per account per region. Batch calculations during scaling events exceed this limit.
  • Fix: Queue payloads in an internal buffer and publish in batches of 10. Implement circuit breaker logic to pause publishing when throttling occurs.
  • Code Fix: Replace synchronous put_events with an async queue consumer that respects the 500 TPS limit and retries with exponential backoff.
