Building an Email Deliverability Reputation Monitor with Genesys Cloud Python SDK
A Python service that queries Genesys Cloud email delivery metrics, validates domain authentication records, enforces monitoring frequency limits, and routes reputation alerts to external webhooks. This uses the Genesys Cloud Email and Organization APIs via the official Python SDK. The tutorial covers Python 3.9+ with production-ready error handling, pagination, and retry logic.
  • OAuth confidential client with scopes: email:messages:read, organization:read, webhooks:readwrite, analytics:email:read
  • genesys-cloud-python-sdk>=4.0.0
  • Python 3.9+ runtime
  • External dependencies: httpx>=0.25.0, pydantic>=2.0.0, tenacity>=8.2.0, dnspython>=2.4.0
  • Genesys Cloud organization with at least one configured email domain and account
Genesys Cloud uses OAuth 2.0 client credentials flow. The SDK handles token acquisition and caching, but production systems must implement explicit expiry tracking to avoid 401 errors during long-running monitoring loops.
from purecloudplatformclientv2 import Configuration, PureCloudPlatformClientV2
class GenesysAuthManager:
    def __init__(self, host: str, client_id: str, client_secret: str, scopes: list[str]):
        self.config = Configuration(host=host)
        self.client = PureCloudPlatformClientV2(self.config)
        self.oauth = self.client.oauth
        self.scopes = scopes
        self.client_id = client_id
        self._token_expiry = 0.0
    def get_authenticated_client(self) -> PureCloudPlatformClientV2:
        current_time = time.time()
        if current_time >= self._token_expiry:
            self.oauth.client_credentials(self.client_id, self.client_secret, self.scopes)
            self._token_expiry = current_time + 5400  # Tokens expire at 90 minutes; refresh at 90
        return self.client
The client_credentials method exchanges your credentials for an access token. The SDK caches the token internally. The manual _token_expiry guard prevents race conditions during concurrent monitoring threads.
Step 1: Initialize Domain Configuration and Gateway Constraints
You must load domain identifiers and validate monitoring payloads against gateway constraints before querying metrics. Genesys Cloud email gateways enforce maximum polling frequencies to prevent abuse. You will construct a validation schema that rejects unsafe intervals and enforces blacklisting thresholds.
from pydantic import BaseModel, field_validator, ValidationError
from purecloudplatformclientv2 import ApiException
class MonitorDirective(BaseModel):
    domain_id: str
    account_id: str
    max_frequency_seconds: int = 300
    bounce_rate_threshold: float = 0.05
    blacklist_threshold: int = 3
    ip_rotation_enabled: bool = True
    @field_validator("max_frequency_seconds")
    @classmethod
    def validate_frequency(cls, v: int) -> int:
        if v < 60:
            raise ValueError("Monitoring frequency must be at least 60 seconds to prevent gateway throttling.")
        return v
    @field_validator("bounce_rate_threshold")
    @classmethod
    def validate_bounce_rate(cls, v: float) -> float:
        if not (0.0 <= v <= 1.0):
            raise ValueError("Bounce rate threshold must be between 0.0 and 1.0.")
        return v
def load_domain_config(auth_manager: GenesysAuthManager, directive: MonitorDirective) -> dict:
    client = auth_manager.get_authenticated_client()
        domain_response = client.organization_api.get_organization_domain(directive.domain_id)
        if domain_response.email_configuration is None:
            raise ValueError("Domain does not have email configuration enabled.")
            "domain_id": domain_response.id,
            "spf_record": domain_response.email_configuration.spf_record,
            "dkim_record": domain_response.email_configuration.dkim_record,
            "gateway_max_frequency": 300,
            "ip_pool_size": domain_response.email_configuration.ip_pool_size if hasattr(domain_response.email_configuration, 'ip_pool_size') else 1
    except ApiException as e:
        if e.status == 404:
            raise ValueError(f"Domain {directive.domain_id} not found.")
        raise
OAuth Scope Required: organization:read
Endpoint: GET /api/v2/organization/domains/{domainId}
This step validates the monitoring schema against Genesys Cloud gateway constraints. The ip_pool_size field determines whether automatic IP rotation triggers will activate in Step 2.
Step 2: Aggregate Email Metrics and Construct Bounce Rate Matrices
You will query delivered, bounced, and rejected messages using atomic GET operations. The SDK requires pagination handling via continuation_token. You will also implement exponential backoff for 429 rate-limit responses.
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
import httpx
@retry(
    stop=stop_after_attempt(3),
    wait=wait_exponential(multiplier=1.5, min=2, max=15),
    retry=retry_if_exception_type(ApiException),
    reraise=True
def fetch_email_page(client, domain_id: str, account_id: str, since: str, continuation_token: str | None = None) -> tuple:
        response = client.email_api.get_email_messages(
            domain_id=domain_id,
            account_id=account_id,
            since=since,
            continuation_token=continuation_token
        return response.entities, response.continuation_token
        if e.status == 429:
            print(f"Rate limit hit. Retrying in {wait_exponential(multiplier=1.5, min=2, max=15).get_sleep_time()}s")
            raise
        raise
def aggregate_bounce_matrix(auth_manager: GenesysAuthManager, directive: MonitorDirective, window_hours: int = 24) -> dict:
    import datetime
    since_timestamp = datetime.datetime.utcnow() - datetime.timedelta(hours=window_hours)
    since_iso = since_timestamp.isoformat() + "Z"
    total_sent = 0
    total_bounced = 0
    total_rejected = 0
    continuation = None
    while True:
        messages, continuation = fetch_email_page(client, directive.domain_id, directive.account_id, since_iso, continuation)
        for msg in messages:
            if msg.status == "delivered":
                total_sent += 1
            elif msg.status == "bounced":
                total_bounced += 1
            elif msg.status == "rejected":
                total_rejected += 1
        if continuation is None:
            break
    bounce_rate = total_bounced / total_sent if total_sent > 0 else 0.0
    blacklist_score = total_rejected / total_sent if total_sent > 0 else 0.0
        "bounce_rate": bounce_rate,
        "blacklist_score": blacklist_score,
        "total_sent": total_sent,
        "total_bounced": total_bounced,
        "total_rejected": total_rejected,
        "threshold_exceeded": bounce_rate > directive.bounce_rate_threshold or total_rejected >= directive.blacklist_threshold
OAuth Scope Required: email:messages:read
Endpoint: GET /api/v2/email/messages
HTTP Request/Response Cycle Example:
GET /api/v2/email/messages?domainId=abc123&accountId=def456&since=2024-01-15T10:00:00Z HTTP/1.1
Host: api.mypurecloud.com
Authorization: Bearer eyJhbGciOiJSUzI1NiIs...
Accept: application/json
HTTP/1.1 200 OK
  "entities": [
      "id": "msg-789",
      "subject": "Order Confirmation",
      "to": ["customer@example.com"],
      "status": "delivered",
      "createdDate": "2024-01-15T10:05:12.000Z"
      "id": "msg-790",
      "subject": "Promotional Update",
      "to": ["invalid@domain.com"],
      "status": "bounced",
      "createdDate": "2024-01-15T10:06:45.000Z"
  "continuationToken": "eyJwYWdlIjoyLCJzaW5jZSI6IjIwMjQtMDEtMTVUMTA6MDA6MDBaIn0="
The pagination loop terminates when continuation_token returns null. The 429 retry decorator ensures monitoring does not fail during peak gateway load.
Step 3: Validate SPF/DKIM Alignment and Sender Score Pipelines
Deliverability reputation depends on DNS authentication alignment. You will construct a validation pipeline that checks SPF/DKIM records against the domain configuration and queries a reputation scoring service. Automatic IP rotation triggers activate when the blacklist score exceeds thresholds.
import dns.resolver
import httpx
def validate_spf_dkim_alignment(domain: str, expected_spf: str | None, expected_dkim: str | None) -> dict:
    alignment_status = {"spf_aligned": False, "dkim_aligned": False, "errors": []}
        spf_records = dns.resolver.resolve(domain, "TXT")
        for record in spf_records:
            txt_value = str(record.to_text()).strip('"')
            if "v=spf1" in txt_value:
                if expected_spf is None or txt_value == expected_spf:
                    alignment_status["spf_aligned"] = True
        alignment_status["errors"].append(f"SPF resolution failed: {str(e)}")
        dkim_domain = f"_domainkey.{domain}"
        dkim_records = dns.resolver.resolve(dkim_domain, "TXT")
        for record in dkim_records:
            if "v=DKIM1" in txt_value:
                if expected_dkim is None or txt_value == expected_dkim:
                    alignment_status["dkim_aligned"] = True
        alignment_status["errors"].append(f"DKIM resolution failed: {str(e)}")
    return alignment_status
def query_sender_score(reputation_api_url: str, api_key: str, domain: str) -> float:
    headers = {"Authorization": f"Bearer {api_key}", "Content-Type": "application/json"}
    payload = {"domain": domain, "metrics": ["sender_score", "blacklist_status"]}
    with httpx.Client(timeout=10.0) as client:
        response = client.post(f"{reputation_api_url}/v1/reputation", json=payload, headers=headers)
        response.raise_for_status()
        data = response.json()
        return float(data.get("sender_score", 0))
def trigger_ip_rotation(auth_manager: GenesysAuthManager, domain_id: str, account_id: str) -> bool:
        # Genesys Cloud supports IP rotation via account configuration updates
        client.email_api.put_email_account(
            body={"ipRotationEnabled": True}
        return True
        if e.status in [400, 403, 409]:
            return False
        raise
OAuth Scopes Required: email:accounts:write (for rotation trigger), email:messages:read
Endpoints: PUT /api/v2/email/accounts/{accountId}, GET /api/v2/email/messages
The SPF/DKIM validation uses dnspython to query TXT records directly. The sender score pipeline calls an external reputation management platform. IP rotation triggers execute a configuration update when thresholds are breached.
Step 4: Synchronize Webhooks, Track Latency, and Generate Audit Logs
You will expose the reputation monitor as a unified service that logs audit trails, calculates monitoring latency, and pushes synchronization events to external platforms.
import json
from typing import Any
class ReputationAuditLogger:
    def __init__(self, log_file: str = "reputation_audit.jsonl"):
        self.log_file = log_file
    def log(self, event: dict[str, Any]) -> None:
        event["timestamp"] = time.time()
        with open(self.log_file, "a") as f:
            f.write(json.dumps(event) + "\n")
def sync_external_webhook(webhook_url: str, payload: dict[str, Any]) -> None:
    headers = {"Content-Type": "application/json"}
    with httpx.Client(timeout=15.0) as client:
        response = client.post(webhook_url, json=payload, headers=headers)
        if response.status_code not in [200, 201, 204]:
            raise httpx.HTTPStatusError(f"Webhook sync failed: {response.status_code}", request=response.request, response=response)
def run_monitoring_cycle(
    domain_config: dict,
    reputation_api_key: str,
    webhook_url: str
) -> dict[str, Any]:
    start_time = time.time()
    logger = ReputationAuditLogger()
    # Step 2: Aggregate metrics
    metrics = aggregate_bounce_matrix(auth_manager, directive)
    # Step 3: Validate alignment and score
    alignment = validate_spf_dkim_alignment(
        domain_config["domain_id"],
        domain_config["spf_record"],
        domain_config["dkim_record"]
    sender_score = query_sender_score(reputation_api_url, reputation_api_key, domain_config["domain_id"])
    # Step 3: Trigger rotation if thresholds exceeded
    rotation_triggered = False
    if metrics["threshold_exceeded"] and directive.ip_rotation_enabled:
        rotation_triggered = trigger_ip_rotation(auth_manager, directive.domain_id, directive.account_id)
    audit_event = {
        "domain_id": directive.domain_id,
        "bounce_rate": metrics["bounce_rate"],
        "blacklist_score": metrics["blacklist_score"],
        "spf_aligned": alignment["spf_aligned"],
        "dkim_aligned": alignment["dkim_aligned"],
        "sender_score": sender_score,
        "ip_rotation_triggered": rotation_triggered,
        "monitoring_latency_ms": latency_ms,
        "status": "alert" if metrics["threshold_exceeded"] else "healthy"
    logger.log(audit_event)
    # Step 4: Sync to external platform
    sync_external_webhook(webhook_url, audit_event)
    return audit_event
The audit logger writes newline-delimited JSON for governance compliance. Latency tracking measures the complete aggregation and validation pipeline. Webhook synchronization ensures external reputation management platforms receive real-time alignment data.
The following script combines all components into a production-ready monitoring service. Replace placeholder credentials and endpoints before execution.
import sys
# Import classes from previous steps
# from auth_module import GenesysAuthManager
# from config_module import MonitorDirective, load_domain_config
# from metrics_module import aggregate_bounce_matrix
# from validation_module import validate_spf_dkim_alignment, query_sender_score, trigger_ip_rotation
# from sync_module import run_monitoring_cycle
def main():
    # Configuration
    GENESYS_HOST = "https://api.mypurecloud.com"
    CLIENT_ID = "your_client_id"
    CLIENT_SECRET = "your_client_secret"
    SCOPES = ["email:messages:read", "organization:read", "webhooks:readwrite", "analytics:email:read"]
    DOMAIN_ID = "your_domain_id"
    ACCOUNT_ID = "your_account_id"
    REPUTATION_API_URL = "https://reputation.example.com"
    REPUTATION_API_KEY = "your_reputation_key"
    WEBHOOK_URL = "https://hooks.example.com/genesys-reputation"
    # Initialize authentication
    auth = GenesysAuthManager(GENESYS_HOST, CLIENT_ID, CLIENT_SECRET, SCOPES)
    # Initialize monitoring directive
    directive = MonitorDirective(
        domain_id=DOMAIN_ID,
        account_id=ACCOUNT_ID,
        max_frequency_seconds=120,
        bounce_rate_threshold=0.04,
        blacklist_threshold=5,
        ip_rotation_enabled=True
        # Load domain configuration
        domain_config = load_domain_config(auth, directive)
        print(f"Domain {domain_config['domain_id']} configured. IP pool size: {domain_config['ip_pool_size']}")
        # Execute monitoring cycle
        result = run_monitoring_cycle(
            auth_manager=auth,
            directive=directive,
            domain_config=domain_config,
            reputation_api_url=REPUTATION_API_URL,
            reputation_api_key=REPUTATION_API_KEY,
            webhook_url=WEBHOOK_URL
        print(f"Monitoring complete. Status: {result['status']}")
        print(f"Bounce Rate: {result['bounce_rate']:.2%} | Sender Score: {result['sender_score']}")
        print(f"SPF Aligned: {result['spf_aligned']} | DKIM Aligned: {result['dkim_aligned']}")
        print(f"Latency: {result['monitoring_latency_ms']:.2f}ms")
    except ValidationError as ve:
        print(f"Schema validation failed: {ve}")
        sys.exit(1)
    except ApiException as ae:
        print(f"Genesys API error {ae.status}: {ae.reason}")
        sys.exit(2)
        print(f"Unexpected error: {e}")
        sys.exit(3)
    main()
Install dependencies with:
pip install genesys-cloud-python-sdk httpx pydantic tenacity dnspython
Run the script directly. The service will authenticate, fetch metrics, validate DNS alignment, check sender reputation, trigger IP rotation if thresholds breach, log the audit trail, and push synchronization events to your webhook endpoint.
Common Errors and Debugging
  • Cause: OAuth token expired or client credentials are invalid.
  • Fix: Verify CLIENT_ID and CLIENT_SECRET match your Genesys Cloud application configuration. Ensure the token refresh guard in GenesysAuthManager executes before each API call.
  • Code Fix: The get_authenticated_client method already implements a 90-minute expiry guard. If errors persist, reduce the buffer to 4500 seconds.
Error: 403 Forbidden
  • Cause: Missing OAuth scopes or insufficient organization permissions.
  • Fix: Add email:messages:read, organization:read, and webhooks:readwrite to the application scopes in the Genesys Cloud admin console. Assign the service account the Email Administrator role.
  • Code Fix: Update the SCOPES list in the initialization block.
  • Cause: Exceeding Genesys Cloud rate limits during pagination or rapid monitoring cycles.
  • Fix: The tenacity decorator handles automatic backoff. Ensure max_frequency_seconds in MonitorDirective is at least 60. Reduce concurrent thread counts.
  • Code Fix: Adjust wait_exponential(multiplier=2, min=5, max=30) in the fetch_email_page retry configuration.
Error: 503 Service Unavailable
  • Cause: Genesys Cloud email gateway maintenance or external reputation API downtime.
  • Fix: Implement circuit breaker logic for external calls. Retry with exponential backoff capped at 60 seconds.
  • Code Fix: Wrap query_sender_score and sync_external_webhook in a retry decorator identical to fetch_email_page.
Error: Pydantic Validation Error
  • Cause: Monitoring payload violates gateway constraints (e.g., frequency below 60 seconds).
  • Fix: Adjust max_frequency_seconds to comply with gateway limits. Verify bounce rate thresholds use decimal notation (0.05 for 5 percent).
  • Code Fix: Review field_validator outputs in MonitorDirective.
