Building a WebSocket-Driven Queue Patch Orchestrator for NICE CXone with Go
- A Go service that subscribes to NICE CXone WebSockets routing events, constructs validated patch payloads, and executes atomic queue updates against the CXone REST API.
- The implementation uses the CXone WebSockets API for real-time event streaming and the CXone REST API for configuration patching.
- The tutorial covers Go with standard library HTTP,
gorilla/websocket, and structured audit logging.
- OAuth 2.0 Client Credentials grant configured in CXone Developer Portal
- Required scopes:
routing:queue:write,routing:queue:read,webchat:websocket - CXone API v2
- Go 1.21 or later
- External dependencies:
github.com/gorilla/websocket,github.com/google/uuid
NICE CXone uses a standard OAuth 2.0 client credentials flow. You must cache the access token and implement refresh logic before initiating WebSocket connections or REST patch operations. The token expires after one hour, so your service must validate expiration and re-authenticate automatically.
package main
import (
"bytes"
"encoding/json"
"fmt"
"net/http"
"time"
type OAuthTokenResponse struct {
func fetchCXoneToken(clientID, clientSecret, scope string) (string, error) {
endpoint := fmt.Sprintf("https://api-%s.niceincontact.com/api/v2/oauth/token", "us")
payload := map[string]string{
"client_id": clientID,
"client_secret": clientSecret,
"scope": scope,
jsonBody, err := json.Marshal(payload)
if err != nil {
return "", fmt.Errorf("failed to marshal oauth payload: %w", err)
req, err := http.NewRequest(http.MethodPost, endpoint, bytes.NewBuffer(jsonBody))
if err != nil {
return "", fmt.Errorf("failed to create oauth request: %w", err)
resp, err := client.Do(req)
if err != nil {
return "", fmt.Errorf("oauth request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("oauth authentication failed with status %d", resp.StatusCode)
var tokenResp OAuthTokenResponse
return "", fmt.Errorf("failed to decode oauth response: %w", err)
return tokenResp.AccessToken, nil
Step 1: WebSocket Event Subscription and Stream Initialization
CXone WebSockets operate over a secure channel endpoint. You must pass the access token in the Authorization header. The service subscribes to the routing channel to receive queue state changes and message routing events. The connection handles ping/pong frames to maintain liveness and parses incoming JSON events into structured payloads.
package main
import (
"fmt"
"log"
"net/http"
"time"
"github.com/gorilla/websocket"
type RoutingEvent struct {
EventID string `json:"eventId"`
Sequence int64 `json:"sequence"`
Timestamp int64 `json:"timestamp"`
Payload map[string]interface{} `json:"payload"`
func establishWebSocketConnection(wssURL, token string) (*websocket.Conn, error) {
headers := http.Header{}
headers.Set("Authorization", fmt.Sprintf("Bearer %s", token))
headers.Set("Accept", "application/json")
dialer := websocket.Dialer{
HandshakeTimeout: 15 * time.Second,
conn, resp, err := dialer.Dial(wssURL, headers)
if err != nil {
if resp != nil {
return nil, fmt.Errorf("websocket handshake failed %d: %w", resp.StatusCode, err)
return nil, fmt.Errorf("websocket connection failed: %w", err)
// Configure pong handler to reset read deadline
conn.SetReadDeadline(time.Now().Add(60 * time.Second))
conn.SetPongHandler(func(appData string) error {
return nil
go func() {
ticker := time.NewTicker(30 * time.Second)
defer ticker.Stop()
for range ticker.C {
conn.WriteMessage(websocket.PingMessage, nil)
return conn, nil
Step 2: Payload Construction and Schema Validation
Patch payloads must conform to CXone queue engine constraints. You must validate the message matrix (routing rules), offset directive (routing priority adjustments), and maximum retention period limits before transmission. The service verifies format integrity, checks retention against CXone limits (maximum 365 days), and ensures sequence continuity to prevent data corruption during scaling events.
package main
import (
"fmt"
"time"
type PatchPayload struct {
ID string `json:"id"`
MessageMatrix []RoutingRule `json:"routingRules"`
OffsetDirective map[string]interface{} `json:"offsetDirective"`
MaxRetentionDays int `json:"maxRetentionDays"`
LastUpdated string `json:"lastUpdated"`
type RoutingRule struct {
QueueID string `json:"queueId"`
Priority int `json:"priority"`
SkillGroup string `json:"skillGroup"`
type IdempotencyStore struct {
Keys map[string]time.Time
Sequence int64
func (store *IdempotencyStore) VerifyAndStore(idempotencyKey string, sequence int64) error {
// Check idempotency key
if _, exists := store.Keys[idempotencyKey]; exists {
return fmt.Errorf("duplicate patch request detected for key: %s", idempotencyKey)
// Sequence continuity verification
if sequence != store.Sequence+1 && store.Sequence != 0 {
return fmt.Errorf("sequence discontinuity detected: expected %d, received %d", store.Sequence+1, sequence)
store.Keys[idempotencyKey] = time.Now()
store.Sequence = sequence
return nil
func validatePatchPayload(payload *PatchPayload) error {
// Validate maximum retention period limit
if payload.MaxRetentionDays < 1 || payload.MaxRetentionDays > 365 {
return fmt.Errorf("maxRetentionDays must be between 1 and 365")
// Validate message matrix structure
if len(payload.MessageMatrix) == 0 {
return fmt.Errorf("message matrix cannot be empty")
for _, rule := range payload.MessageMatrix {
if rule.Priority < 0 || rule.Priority > 10 {
return fmt.Errorf("routing rule priority must be between 0 and 10")
if rule.QueueID == "" {
return fmt.Errorf("queue ID reference missing in routing rule")
// Validate offset directive format
if payload.OffsetDirective == nil {
return fmt.Errorf("offset directive must be provided")
if _, exists := payload.OffsetDirective["adjustmentFactor"]; !exists {
return fmt.Errorf("offset directive missing adjustmentFactor parameter")
return nil
Step 3: Atomic Patch Execution with Idempotency and Redelivery
You execute the patch operation against the CXone REST API using HTTP PATCH. The service attaches the idempotency key as a header to guarantee safe retry behavior. You must implement exponential backoff for 429 Too Many Requests responses and trigger automatic redelivery when the patch modifies active routing strategies. The service tracks latency and success rates for operational visibility.
package main
import (
"bytes"
"encoding/json"
"fmt"
"io"
"log"
"math"
"net/http"
"time"
type PatchResult struct {
Success bool
Latency time.Duration
StatusCode int
Body []byte
func executeQueuePatch(token string, queueID string, payload *PatchPayload, idempotencyKey string) PatchResult {
startTime := time.Now()
endpoint := fmt.Sprintf("https://api-us.niceincontact.com/api/v2/routing/queues/%s", queueID)
jsonBody, _ := json.Marshal(payload)
var result PatchResult
var lastError error
// Retry loop for 429 rate limiting
for attempt := 0; attempt <= 3; attempt++ {
req, err := http.NewRequest(http.MethodPatch, endpoint, bytes.NewBuffer(jsonBody))
if err != nil {
result = PatchResult{Success: false, Latency: time.Since(startTime), StatusCode: 0}
return result
req.Header.Set("Authorization", fmt.Sprintf("Bearer %s", token))
req.Header.Set("X-Idempotency-Key", idempotencyKey)
client := &http.Client{Timeout: 30 * time.Second}
if err != nil {
lastError = err
result.Body = body
result.StatusCode = resp.StatusCode
backoff := time.Duration(math.Pow(2, float64(attempt))) * time.Second
log.Printf("Rate limited (429). Retrying in %v", backoff)
time.Sleep(backoff)
if resp.StatusCode == http.StatusOK || resp.StatusCode == http.StatusCreated {
result.Success = true
result.Latency = time.Since(startTime)
return result
lastError = fmt.Errorf("patch failed with status %d: %s", resp.StatusCode, string(body))
break
result.Success = false
if lastError != nil {
log.Printf("Patch execution failed after retries: %v", lastError)
return result
func triggerRedelivery(token string, queueID string) error {
endpoint := fmt.Sprintf("https://api-us.niceincontact.com/api/v2/routing/queues/%s/redelivery", queueID)
req, err := http.NewRequest(http.MethodPost, endpoint, nil)
if err != nil {
return fmt.Errorf("failed to create redelivery request: %w", err)
if err != nil {
return fmt.Errorf("redelivery trigger failed: %w", err)
if resp.StatusCode != http.StatusOK && resp.StatusCode != http.StatusAccepted {
return fmt.Errorf("redelivery trigger returned status %d", resp.StatusCode)
return nil
Step 4: Webhook Synchronization and Audit Logging
After a successful patch, the service synchronizes the event with an external dead letter queue via a webhook dispatch. You must record patching latency, success rates, and full payload hashes for queue governance. The audit log structure supports compliance tracking and rollback verification.
package main
import (
"crypto/sha256"
"encoding/json"
"fmt"
"log"
"net/http"
"time"
type AuditLogEntry struct {
IdempotencyKey string `json:"idempotencyKey"`
PayloadHash string `json:"payloadHash"`
LatencyMs int64 `json:"latencyMs"`
Success bool `json:"success"`
StatusCode int `json:"statusCode"`
func generateAuditLog(queueID, idempotencyKey string, payload []byte, result PatchResult) AuditLogEntry {
hash := sha256.Sum256(payload)
return AuditLogEntry{
Timestamp: time.Now(),
QueueID: queueID,
IdempotencyKey: idempotencyKey,
PayloadHash: fmt.Sprintf("%x", hash),
LatencyMs: result.Latency.Milliseconds(),
Success: result.Success,
StatusCode: result.StatusCode,
func syncToDeadLetterQueue(webhookURL string, auditLog AuditLogEntry) error {
jsonBody, err := json.Marshal(auditLog)
if err != nil {
return fmt.Errorf("failed to marshal audit log: %w", err)
req, err := http.NewRequest(http.MethodPost, webhookURL, bytes.NewBuffer(jsonBody))
if err != nil {
return fmt.Errorf("failed to create webhook request: %w", err)
req.Header.Set("X-Webhook-Source", "cxone-queue-patcher")
if err != nil {
return fmt.Errorf("webhook delivery failed: %w", err)
if resp.StatusCode < 200 || resp.StatusCode >= 300 {
return fmt.Errorf("webhook returned non-success status: %d", resp.StatusCode)
return nil
The following module combines authentication, WebSocket subscription, payload validation, atomic patching, and audit synchronization into a single executable service. Replace the placeholder credentials and webhook URL before deployment.
package main
import (
"encoding/json"
"fmt"
"log"
"os"
"time"
"github.com/google/uuid"
func main() {
clientID := os.Getenv("CXONE_CLIENT_ID")
clientSecret := os.Getenv("CXONE_CLIENT_SECRET")
webhookURL := os.Getenv("DLQ_WEBHOOK_URL")
if clientID == "" || clientSecret == "" || webhookURL == "" {
log.Fatal("Missing required environment variables: CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, DLQ_WEBHOOK_URL")
// Step 1: Authenticate
token, err := fetchCXoneToken(clientID, clientSecret, "routing:queue:write routing:queue:read webchat:websocket")
if err != nil {
log.Fatalf("Authentication failed: %v", err)
log.Println("OAuth token acquired successfully")
// Step 2: Connect to WebSocket routing channel
wssURL := "wss://api-us.niceincontact.com/api/v2/websocket/routing"
conn, err := establishWebSocketConnection(wssURL, token)
if err != nil {
log.Fatalf("WebSocket connection failed: %v", err)
defer conn.Close()
log.Println("WebSocket subscription active")
idempotencyStore := &IdempotencyStore{
Keys: make(map[string]time.Time),
// Step 3: Event processing loop
for {
_, message, err := conn.ReadMessage()
if err != nil {
log.Printf("WebSocket read error: %v. Reconnecting in 5s...", err)
time.Sleep(5 * time.Second)
conn, err = establishWebSocketConnection(wssURL, token)
if err != nil {
log.Printf("Reconnection failed: %v", err)
var event RoutingEvent
if err := json.Unmarshal(message, &event); err != nil {
log.Printf("Failed to parse event: %v", err)
// Construct patch payload from event payload
queueID, ok := event.Payload["queueId"].(string)
if !ok {
idempotencyKey := uuid.New().String()
if err := idempotencyStore.VerifyAndStore(idempotencyKey, event.Sequence); err != nil {
log.Printf("Idempotency/sequence validation failed: %v", err)
payload := PatchPayload{
MaxRetentionDays: 30,
LastUpdated: time.Now().UTC().Format(time.RFC3339),
MessageMatrix: []RoutingRule{
{QueueID: queueID, Priority: 5, SkillGroup: "support_tier1"},
OffsetDirective: map[string]interface{}{
"adjustmentFactor": 0.85,
"appliedAt": time.Now().UnixMilli(),
if err := validatePatchPayload(&payload); err != nil {
log.Printf("Payload validation failed: %v", err)
payloadBytes, _ := json.Marshal(payload)
log.Printf("Executing patch for queue %s with idempotency key %s", queueID, idempotencyKey)
result := executeQueuePatch(token, queueID, &payload, idempotencyKey)
auditLog := generateAuditLog(queueID, idempotencyKey, payloadBytes, result)
if result.Success {
log.Printf("Patch applied successfully. Latency: %dms", auditLog.LatencyMs)
if err := triggerRedelivery(token, queueID); err != nil {
log.Printf("Redelivery trigger failed: %v", err)
} else {
log.Printf("Patch failed. Status: %d", result.StatusCode)
// Synchronize with external dead letter queue
if err := syncToDeadLetterQueue(webhookURL, auditLog); err != nil {
log.Printf("Audit sync failed: %v", err)
- What causes it: The OAuth access token expired or was revoked. CXone tokens expire after 3600 seconds.
- How to fix it: Implement token expiration tracking. Refresh the token before the WebSocket connection times out or before the next PATCH request.
- Code showing the fix: Add a token cache with a timestamp. Check
time.Since(tokenAcquired).Seconds() > 3300and callfetchCXoneTokenautomatically.
Error: 400 Bad Request
- What causes it: The patch payload violates CXone schema constraints. Common triggers include
maxRetentionDaysexceeding 365, missingroutingRules, or invalid skill group identifiers. - How to fix it: Run
validatePatchPayloadbefore transmission. Ensure all queue ID references exist in your CXone tenant. Verify theoffsetDirectivecontains the requiredadjustmentFactorkey. - Code showing the fix: The validation function in Step 2 explicitly checks these boundaries. Log the full response body to identify the exact failing field.
- What causes it: The CXone API enforces rate limits per tenant. Burst patching from WebSocket event spikes triggers throttling.
- How to fix it: Implement exponential backoff with jitter. The
executeQueuePatchfunction includes a retry loop that sleeps for2^attemptseconds before retrying. - Code showing the fix: See the retry loop in
executeQueuePatch. Adjust the maximum attempts or backoff multiplier based on your tenant quota.
Error: WebSocket Connection Drops
- What causes it: Network instability, proxy timeouts, or CXone server maintenance.
- How to fix it: The main loop catches
conn.ReadMessageerrors, logs the failure, waits five seconds, and re-establishes the connection using the cached token. Ensure your firewall allows persistent TCP connections to port 443.
