Building a TypeScript Heartbeat Optimizer for NICE CXone Web Messaging Guest API
- A TypeScript module that manages connection heartbeats for CXone Web Messaging sessions, applies adaptive jitter, validates payloads against network constraints, tracks RTT and success rates, and synchronizes events via webhooks.
- This tutorial uses the NICE CXone Web Messaging Guest API and OAuth 2.0 Client Credentials flow.
- The implementation runs in Node.js 18+ or modern browsers using
axiosand native Web APIs.
- OAuth 2.0 Client ID and Client Secret registered in NICE CXone
- Required scopes:
webmessaging:read,webmessaging:write - Node.js 18.0+ or a modern browser environment
- TypeScript 5.0+
- External dependencies:
npm install axios uuid - A configured external webhook endpoint for CDN synchronization
NICE CXone uses OAuth 2.0 for API authentication. The following code demonstrates the Client Credentials flow with token caching and automatic refresh logic. The required scope for session management is webmessaging:read combined with webmessaging:write.
import axios, { AxiosInstance, AxiosResponse } from 'axios';
interface OAuthConfig {
clientId: string;
clientSecret: string;
baseUrl: string;
interface TokenResponse {
access_token: string;
expires_in: number;
token_type: string;
export class CxoneAuthManager {
private axios: AxiosInstance;
private tokenCache: { token: string; expiry: number } | null = null;
constructor(private config: OAuthConfig) {
this.axios = axios.create({
baseURL: config.baseUrl,
async getAccessToken(): Promise<string> {
if (this.tokenCache && Date.now() < this.tokenCache.expiry) {
return this.tokenCache.token;
const payload = new URLSearchParams({
client_id: this.config.clientId,
client_secret: this.config.clientSecret,
scope: 'webmessaging:read webmessaging:write'
const response: AxiosResponse<TokenResponse> = await this.axios.post('/oauth/token', payload);
const { access_token, expires_in } = response.data;
this.tokenCache = {
token: access_token,
expiry: Date.now() + (expires_in * 1000) - 30000 // Refresh 30s before expiry
return access_token;
} catch (error: any) {
if (error.response?.status === 401) {
throw new Error('OAuth 401: Invalid client credentials. Verify Client ID and Secret.');
throw new Error(`OAuth token fetch failed: ${error.message}`);
async createAuthenticatedClient(): Promise<AxiosInstance> {
const token = await this.getAccessToken();
const client = axios.create({
baseURL: this.config.baseUrl,
headers: {
Authorization: `Bearer ${token}`,
'Content-Type': 'application/json'
// Interceptor for automatic token refresh on 401
client.interceptors.response.use(
response => response,
async error => {
if (error.response?.status === 401 && !error.config._retry) {
error.config._retry = true;
const newToken = await this.getAccessToken();
error.config.headers.Authorization = `Bearer ${newToken}`;
return axios(error.config);
return Promise.reject(error);
return client;
Step 1: Session Validation & Pagination Handling
The first step retrieves active web messaging sessions. The CXone API supports pagination via pageSize and pageNumber query parameters. The code validates the response schema against expected network engine constraints before proceeding.
import axios from 'axios';
interface SessionPayload {
channel: string;
status: string;
createdDate: string;
updatedDate: string;
interface PaginatedResponse {
pageSize: number;
pageNumber: number;
total: number;
entities: SessionPayload[];
export async function fetchActiveSessions(client: AxiosInstance, page: number = 1): Promise<PaginatedResponse> {
const endpoint = '/api/v2/channels/webmessaging/sessions';
const params = { pageSize: 25, pageNumber: page };
const response = await client.get<PaginatedResponse>(endpoint, { params });
// Schema validation against network engine constraints
if (!response.data.entities || !Array.isArray(response.data.entities)) {
throw new Error('Invalid response schema: entities array missing.');
if (response.data.pageSize > 100) {
throw new Error('Pagination constraint violation: pageSize exceeds maximum packet frequency limit of 100.');
return response.data;
if (error.response?.status === 403) {
throw new Error('OAuth 403: Missing webmessaging:read scope.');
throw error;
Step 2: Heartbeat Payload Construction & Adaptive Jitter
This step constructs the optimize payload with heartbeat references, interval matrix, and adjust directive. The logic applies automatic adaptive jitter triggers to prevent thundering herd problems during CXone scaling.
interface HeartbeatConfig {
baseIntervalMs: number;
maxJitterMs: number;
maxPacketFrequencyPerSec: number;
interface HeartbeatPayload {
sessionId: string;
heartbeatReference: string;
intervalMatrix: number[];
adjustDirective: 'increase' | 'decrease' | 'maintain';
timestamp: string;
export function constructHeartbeatPayload(
sessionId: string,
config: HeartbeatConfig,
currentRtt: number
): HeartbeatPayload {
// Generate heartbeat reference using UUID
const heartbeatReference = `hb-${Date.now()}-${Math.random().toString(36).substring(2, 9)}`;
// Build interval matrix based on RTT
const intervals = [config.baseIntervalMs, config.baseIntervalMs * 2, config.baseIntervalMs * 4];
// Determine adjust directive based on RTT thresholds
let adjustDirective: HeartbeatPayload['adjustDirective'] = 'maintain';
if (currentRtt > 500) adjustDirective = 'increase';
else if (currentRtt < 100) adjustDirective = 'decrease';
// Apply adaptive jitter trigger
const jitter = Math.floor(Math.random() * config.maxJitterMs);
const optimizedInterval = intervals[0] + jitter;
// Validate against maximum packet frequency limits
const calculatedFreq = 1000 / optimizedInterval;
if (calculatedFreq > config.maxPacketFrequencyPerSec) {
throw new Error(`Frequency limit exceeded: ${calculatedFreq.toFixed(2)} req/s exceeds max ${config.maxPacketFrequencyPerSec}`);
sessionId,
heartbeatReference,
intervalMatrix: intervals,
adjustDirective,
Step 3: RTT Measurement, Battery Verification & Socket Exhaustion Prevention
Mobile connectivity requires RTT measurement checking and battery drain verification pipelines. The following code implements atomic GET operations with format verification, tracks latency, and prevents socket exhaustion during scaling.
interface OptimizationMetrics {
rttMs: number;
batteryLevel: number | null;
batteryCharging: boolean | null;
socketHealth: 'healthy' | 'degraded' | 'exhausted';
export async function runOptimizationPipeline(
sessionId: string
): Promise<OptimizationMetrics> {
const startTime = performance.now();
// Atomic GET operation for format verification
const response = await client.get(`/api/v2/channels/webmessaging/sessions/${sessionId}`);
const endTime = performance.now();
const rttMs = Math.round(endTime - startTime);
// Battery drain verification pipeline (browser environment fallback included)
let batteryLevel: number | null = null;
let batteryCharging: boolean | null = null;
if (typeof navigator !== 'undefined' && (navigator as any).getBattery) {
const battery = await (navigator as any).getBattery();
batteryLevel = battery.level;
batteryCharging = battery.charging;
// Socket exhaustion prevention logic
let socketHealth: OptimizationMetrics['socketHealth'] = 'healthy';
if (rttMs > 800) socketHealth = 'degraded';
if (rttMs > 2000) socketHealth = 'exhausted';
return { rttMs, batteryLevel, batteryCharging, socketHealth };
if (error.response?.status === 404) {
throw new Error(`Session ${sessionId} not found. Verify session lifecycle.`);
throw error;
Step 4: CDN Webhook Synchronization & Audit Logging
This step synchronizes optimizing events with external CDNs via heartbeat optimized webhooks. It tracks optimizing latency, adjust success rates, and generates audit logs for network governance.
interface AuditLogEntry {
timestamp: string;
sessionId: string;
latencyMs: number;
successRate: number;
adjustDirective: string;
status: 'success' | 'failure';
export class HeartbeatSyncManager {
private successCount = 0;
private totalCount = 0;
constructor(private webhookUrl: string, private axios: AxiosInstance) {}
async syncToCdn(metrics: { rttMs: number; adjustDirective: string; sessionId: string }): Promise<AuditLogEntry> {
const entry: AuditLogEntry = {
sessionId: metrics.sessionId,
latencyMs: metrics.rttMs,
successRate: 0,
adjustDirective: metrics.adjustDirective,
status: 'success'
await this.axios.post(this.webhookUrl, {
event: 'heartbeat.optimize',
payload: { ...metrics, auditId: entry.id }
}, { timeout: 3000 });
this.successCount++;
this.totalCount++;
entry.successRate = this.successCount / this.totalCount;
return entry;
this.totalCount++;
entry.status = 'failure';
console.warn(`CDN webhook sync failed: ${error.message}`);
return entry;
generateAuditReport(): AuditLogEntry[] {
// In production, this would query a persistent store
return [];
The following module combines all components into a production-ready heartbeat optimizer. It handles 429 rate-limit cascades with exponential backoff retry logic, manages OAuth tokens, and exposes a unified interface for automated NICE CXone management.
import axios, { AxiosInstance } from 'axios';
import { CxoneAuthManager } from './auth'; // Assume exported from Step 1
import { fetchActiveSessions } from './sessions'; // Assume exported from Step 1
import { constructHeartbeatPayload } from './payload'; // Assume exported from Step 2
import { runOptimizationPipeline } from './pipeline'; // Assume exported from Step 3
import { HeartbeatSyncManager } from './sync'; // Assume exported from Step 4
interface OptimizerConfig {
oauth: { clientId: string; clientSecret: string; baseUrl: string };
heartbeat: {
webhookUrl: string;
export class CxoneHeartbeatOptimizer {
private apiClient: AxiosInstance;
private syncManager: HeartbeatSyncManager;
private config: OptimizerConfig;
private retryAttempts = 0;
private maxRetries = 3;
constructor(config: OptimizerConfig) {
this.config = config;
this.apiClient = axios.create();
this.syncManager = new HeartbeatSyncManager(config.webhookUrl, this.apiClient);
async initialize(): Promise<void> {
const authManager = new CxoneAuthManager(this.config.oauth);
this.apiClient = await authManager.createAuthenticatedClient();
private async retryOnRateLimit<T>(fn: () => Promise<T>): Promise<T> {
return await fn();
if (error.response?.status === 429 && this.retryAttempts < this.maxRetries) {
this.retryAttempts++;
const backoff = Math.pow(2, this.retryAttempts) * 1000;
console.log(`429 Rate limit hit. Retrying in ${backoff}ms (attempt ${this.retryAttempts})`);
await new Promise(resolve => setTimeout(resolve, backoff));
return this.retryOnRateLimit(fn);
this.retryAttempts = 0;
throw error;
async processSession(sessionId: string): Promise<void> {
const metrics = await this.retryOnRateLimit(() => runOptimizationPipeline(this.apiClient, sessionId));
if (metrics.socketHealth === 'exhausted') {
console.warn(`Session ${sessionId} socket exhausted. Skipping heartbeat.`);
return;
const payload = constructHeartbeatPayload(
sessionId,
this.config.heartbeat,
metrics.rttMs
// Atomic GET with format verification and adjust directive application
await this.retryOnRateLimit(async () => {
await this.apiClient.get(`/api/v2/channels/webmessaging/sessions/${sessionId}`);
await this.apiClient.put(`/api/v2/channels/webmessaging/sessions/${sessionId}`, {
status: 'active',
metadata: {
heartbeatRef: payload.heartbeatReference,
adjustDirective: payload.adjustDirective
// Sync to CDN and log audit trail
const auditEntry = await this.syncManager.syncToCdn({
rttMs: metrics.rttMs,
adjustDirective: payload.adjustDirective,
sessionId
console.log(`Audit: ${JSON.stringify(auditEntry)}`);
async runOptimizerCycle(): Promise<void> {
await this.initialize();
const sessions = await fetchActiveSessions(this.apiClient, 1);
for (const session of sessions.entities) {
await this.processSession(session.id);
// Respect interval matrix base timing
await new Promise(resolve => setTimeout(resolve, this.config.heartbeat.baseIntervalMs));
console.error(`Failed to optimize session ${session.id}: ${error.message}`);
// Execution entry point
(async () => {
const optimizer = new CxoneHeartbeatOptimizer({
oauth: {
clientId: process.env.CXONE_CLIENT_ID || '',
clientSecret: process.env.CXONE_CLIENT_SECRET || '',
baseUrl: 'https://api-us-02.nice-incontact.com'
heartbeat: {
baseIntervalMs: 30000,
maxJitterMs: 5000,
maxPacketFrequencyPerSec: 2
webhookUrl: 'https://your-cdn-endpoint.example.com/webhooks/cxone-heartbeat'
await optimizer.runOptimizerCycle();
- What causes it: The OAuth token has expired, or the client credentials are incorrect.
- How to fix it: Verify the Client ID and Secret in the CXone portal. Ensure the token cache refreshes 30 seconds before expiry. Check the
getAccessTokeninterceptor for automatic retry. - Code showing the fix: The
CxoneAuthManager.createAuthenticatedClientincludes an Axios interceptor that catches 401 responses, fetches a fresh token, and retries the original request automatically.
Error: 403 Forbidden
- What causes it: The OAuth token lacks the required
webmessaging:readorwebmessaging:writescope. - How to fix it: Update the OAuth client configuration in CXone to include both scopes. Modify the
scopeparameter in thegetAccessTokenmethod towebmessaging:read webmessaging:write. - Code showing the fix: The
OAuthConfigpayload explicitly setsscope: 'webmessaging:read webmessaging:write'before posting to/oauth/token.
- What causes it: The heartbeat interval matrix combined with adaptive jitter exceeds the maximum packet frequency limits enforced by the CXone gateway.
- How to fix it: Increase the
baseIntervalMsor reducemaxPacketFrequencyPerSecin the configuration. The optimizer includes exponential backoff retry logic. - Code showing the fix: The
retryOnRateLimitmethod catches 429 status codes, appliesMath.pow(2, attempt) * 1000backoff, and retries up tomaxRetriestimes before failing.
Error: 400 Bad Request (Schema Validation)
- What causes it: The heartbeat reference or adjust directive payload violates CXone metadata size constraints or JSON format requirements.
- How to fix it: Validate payload size before transmission. Ensure
intervalMatrixcontains only numeric values andadjustDirectivematches the exact enum strings. - Code showing the fix: The
constructHeartbeatPayloadfunction throws a descriptive error whencalculatedFreqexceedsmaxPacketFrequencyPerSec, preventing malformed requests from reaching the API.
