Building a real-time Genesys Cloud conversation monitor by subscribing to WebSocket events and transforming payloads into a Node.js EventEmitter stream
- You will build a Node.js service that connects to the Genesys Cloud Real-Time Analytics API, consumes live conversation lifecycle events, and emits them through a strongly typed
EventEmitterfor downstream processing. - This implementation uses the
@genesyscloud/purecloud-platform-client-v2SDK and the/api/v2/analytics/eventsendpoint. - The tutorial covers JavaScript (Node.js 18+) with native
fetch,EventEmitter, and production-grade stream handling.
- OAuth 2.0 client credentials flow with the scope
analytics:events:read - Genesys Cloud Platform SDK v2 (
@genesyscloud/purecloud-platform-client-v2@^2.30.0) - Node.js 18.0 or higher (native
fetchandEventEmittersupport) - No additional npm dependencies required for this tutorial
Genesys Cloud uses OAuth 2.0 for API access. The SDK handles token acquisition, caching, and automatic refresh when you initialize it with client credentials. You must provide a loginUri that matches your environment (e.g., https://api.mypurecloud.com for US, https://api.au.mypurecloud.com for Australia).
import { PlatformClient } from '@genesyscloud/purecloud-platform-client-v2';
const PLATFORM_CONFIG = {
clientId: process.env.GENESYS_CLIENT_ID,
clientSecret: process.env.GENESYS_CLIENT_SECRET,
loginUri: process.env.GENESYS_LOGIN_URI || 'https://api.mypurecloud.com'
* Initializes and returns a configured PlatformClient instance.
* The SDK manages token lifecycle automatically.
export async function initializePlatformClient() {
const client = PlatformClient.init(PLATFORM_CONFIG);
await client.login();
return client;
The SDK stores the access token in memory and automatically requests a new token when the current one expires. You do not need to implement manual refresh logic. If you require custom token storage, you can inject a tokenProvider into the PlatformClient configuration.
Step 1: Initialize the Platform Client and Configure the Real-Time Query
Genesys Cloud delivers real-time event data via Server-Sent Events (SSE) over HTTP/2, not raw WebSockets. The platform chose SSE because it simplifies firewall traversal, reduces connection overhead, and aligns with standard HTTP caching and retry behaviors. The /api/v2/analytics/events endpoint accepts a JSON query body that defines which event types to stream and the polling interval.
import { AnalyticsApi } from '@genesyscloud/purecloud-platform-client-v2';
* Constructs the real-time event query payload.
* Required scope: analytics:events:read
export function buildRealTimeQuery() {
eventTypes: [
'conversation:start',
'conversation:update',
'conversation:end',
'conversation:wrapup'
interval: 'PT1S',
filter: {
type: 'AND',
clauses: [
type: 'EQ',
field: 'mediaType',
value: 'voice'
* Returns an AnalyticsApi instance bound to the authenticated client.
export function getAnalyticsApi(platformClient) {
return new AnalyticsApi(platformClient);
The interval: 'PT1S' parameter instructs the server to flush events every second. The filter object restricts the stream to voice conversations. You can remove the filter to receive all media types. The query body must remain consistent throughout the stream lifecycle. Changing the query requires closing the existing connection and opening a new one.
Step 2: Subscribe to the Event Stream and Handle Connection Lifecycle
The SDK method postAnalyticsEventsQuery returns a Node.js Readable stream. You must handle stream errors, connection drops, and rate limits. The following function wraps the subscription with exponential backoff retry logic for 429 responses and network interruptions.
* Subscribes to the real-time event stream with automatic retry logic.
* @param {AnalyticsApi} analyticsApi
* @param {object} queryBody
* @param {function} onStreamReady - Callback receiving the Readable stream
* @param {object} options - Retry configuration
export async function subscribeToEventStream(
analyticsApi,
queryBody,
onStreamReady,
options = { maxRetries: 5, baseDelayMs: 1000 }
let attempt = 0;
async function attemptConnection() {
const stream = await analyticsApi.postAnalyticsEventsQuery(queryBody);
attempt = 0;
onStreamReady(stream);
} catch (error) {
attempt++;
const isRateLimit = error.response?.status === 429;
const isAuthError = error.response?.status === 401 || error.response?.status === 403;
const isFatal = isAuthError || attempt >= options.maxRetries;
if (isFatal) {
throw new Error(
isAuthError
? `Authentication failed with status ${error.response?.status}. Verify client credentials and scopes.`
: `Max retries (${options.maxRetries}) exceeded for event stream subscription.`
const delayMs = options.baseDelayMs * Math.pow(2, attempt - 1);
console.warn(`Stream connection failed (attempt ${attempt}). Retrying in ${delayMs}ms. Error: ${error.message}`);
await new Promise(resolve => setTimeout(resolve, delayMs));
await attemptConnection();
The SDK throws a PlatformApiException on HTTP errors. You must inspect error.response.status to distinguish between transient failures (429, 502, 503) and fatal failures (401, 403). The retry logic resets the attempt counter on successful connection and respects the exponential backoff curve.
Step 3: Transform Raw SSE Payloads into a Typed Node.js EventEmitter
Raw SSE payloads arrive as newline-delimited JSON strings prefixed with data: . You must parse each chunk, extract the event type, normalize the payload structure, and emit it through an EventEmitter. The following class handles chunk buffering, JSON parsing, and event routing.
import { EventEmitter } from 'events';
* Transforms a Genesys Cloud real-time stream into a typed EventEmitter.
* Emits: 'conversationStart', 'conversationUpdate', 'conversationEnd', 'conversationWrapup', 'streamError'
export class GenesysEventStream extends EventEmitter {
constructor() {
super();
this.maxListeners = 50;
this.buffer = '';
* Processes a raw data chunk from the Readable stream.
* @param {string} chunk
processChunk(chunk) {
this.buffer += chunk;
const lines = this.buffer.split('\n');
this.buffer = lines.pop(); // Retain incomplete line in buffer
for (const line of lines) {
if (!line.startsWith('data: ')) continue;
const jsonStr = line.slice(6).trim();
if (!jsonStr || jsonStr === '{}') continue;
const payload = JSON.parse(jsonStr);
this.routeEvent(payload);
} catch (parseError) {
this.emit('streamError', { error: parseError, rawLine: line });
* Maps Genesys event types to normalized EventEmitter methods.
* @param {object} payload
routeEvent(payload) {
const eventType = payload.eventType;
const normalized = {
eventType,
conversationId: payload.conversationId,
timestamp: payload.timestamp,
payload
switch (eventType) {
case 'conversation:start':
this.emit('conversationStart', normalized);
break;
case 'conversation:update':
this.emit('conversationUpdate', normalized);
break;
case 'conversation:end':
this.emit('conversationEnd', normalized);
break;
case 'conversation:wrapup':
this.emit('conversationWrapup', normalized);
break;
default:
this.emit('unknownEvent', normalized);
The processChunk method handles partial JSON payloads that arrive across multiple TCP packets. SSE streams do not guarantee message boundaries align with data: lines. The buffer retention pattern prevents JSON.parse failures on split messages. The routeEvent method emits strongly typed events that downstream consumers can attach listeners to without inspecting eventType strings.
Step 4: Attach Listeners and Process Conversation Lifecycle States
You connect the Readable stream to the GenesysEventStream instance and register event listeners. The following example demonstrates production-ready listener attachment with graceful shutdown handling.
* Wires the SDK stream to the EventEmitter and registers lifecycle listeners.
* @param {Readable} sdkStream
* @param {GenesysEventStream} eventStream
export function wireStreamListeners(sdkStream, eventStream) {
sdkStream.on('data', (chunk) => {
eventStream.processChunk(chunk.toString('utf8'));
sdkStream.on('error', (err) => {
eventStream.emit('streamError', { error: err, source: 'sdkStream' });
sdkStream.on('close', () => {
console.log('SSE connection closed by server. Reconnection required.');
// Conversation lifecycle listeners
eventStream.on('conversationStart', (data) => {
console.log(`[START] Conversation ${data.conversationId} at ${data.timestamp}`);
// Initialize tracking state, allocate resources, or push to message queue
eventStream.on('conversationUpdate', (data) => {
console.log(`[UPDATE] Conversation ${data.conversationId} state changed`);
// Update real-time dashboards or trigger business rules
eventStream.on('conversationEnd', (data) => {
console.log(`[END] Conversation ${data.conversationId} terminated at ${data.timestamp}`);
// Flush metrics, close tracking state, or trigger post-call workflows
eventStream.on('conversationWrapup', (data) => {
console.log(`[WRAPUP] Conversation ${data.conversationId} entered wrapup`);
// Queue for QA scoring or CRM sync
eventStream.on('streamError', (data) => {
console.error(`[STREAM ERROR] ${data.error.message}`, data.rawLine || data.source);
The data event on the Readable stream emits Buffer objects. You must convert them to UTF-8 strings before passing them to processChunk. The close event indicates server-initiated termination. You must trigger reconnection logic in your orchestration layer when this fires.
The following script combines all components into a runnable Node.js module. Replace the environment variables with your Genesys Cloud credentials.
import { initializePlatformClient } from './auth';
import { buildRealTimeQuery, getAnalyticsApi, subscribeToEventStream } from './stream-subscriber';
import { GenesysEventStream } from './event-transformer';
import { wireStreamListeners } from './listeners';
async function main() {
console.log('Initializing Genesys Cloud Platform Client...');
const client = await initializePlatformClient();
const analyticsApi = getAnalyticsApi(client);
const queryBody = buildRealTimeQuery();
const eventStream = new GenesysEventStream();
console.log('Subscribing to real-time conversation events...');
await subscribeToEventStream(analyticsApi, queryBody, (sdkStream) => {
console.log('SSE connection established. Streaming active.');
wireStreamListeners(sdkStream, eventStream);
// Graceful shutdown handler
const shutdown = () => {
console.log('Shutting down event monitor...');
eventStream.removeAllListeners();
process.exit(0);
process.on('SIGINT', shutdown);
process.on('SIGTERM', shutdown);
main().catch((error) => {
console.error('Fatal initialization error:', error.message);
process.exit(1);
Run the script with node monitor.js. The process will maintain an active SSE connection, parse incoming events, and emit them through the EventEmitter. You can extend the listeners to push events to Kafka, update a Redis cache, or write to a time-series database.
- Cause: Invalid client credentials, missing
analytics:events:readscope, or expired token. - Fix: Verify the OAuth application in the Genesys Cloud admin console has the correct scopes assigned. Ensure the
loginUrimatches your environment region. The SDK logs token acquisition failures toconsole.warn. - Code showing the fix:
// Verify scope assignment before initialization
const REQUIRED_SCOPE = 'analytics:events:read';
console.log('Required scope:', REQUIRED_SCOPE);
// Check your OAuth app in Genesys Cloud > Administration > Security > OAuth 2.0 Client Applications
- Cause: Exceeding the real-time event subscription limit per tenant or triggering rate limits during rapid reconnections.
- Fix: Implement exponential backoff. Genesys Cloud returns a
Retry-Afterheader on429responses. Parse this header to adjust your retry delay. - Code showing the fix:
// Enhanced retry logic respecting Retry-After header
const retryAfterMs = error.response?.headers?.['retry-after']
? parseInt(error.response.headers['retry-after'], 10) * 1000
: options.baseDelayMs * Math.pow(2, attempt - 1);
await new Promise(resolve => setTimeout(resolve, retryAfterMs));
Error: JSON Parse Failures on data: {} or Empty Lines
- Cause: The SSE protocol sends keep-alive pings as empty data lines or
{}payloads. - Fix: Filter out empty or null payloads before parsing. The
processChunkmethod already implements this check withif (!jsonStr || jsonStr === '{}') continue;. - Code showing the fix:
// Already implemented in GenesysEventStream.processChunk
Error: Stream Drops Without Reconnection
- Cause: Network instability or server-side idle timeout. SSE connections typically close after 60-120 seconds of inactivity if no events are emitted.
- Fix: Implement a heartbeat listener or monitor the
closeevent to triggersubscribeToEventStreamagain. Production systems should run the subscription inside awhile(true)loop with atry/catchblock to guarantee continuous operation.
