Building a Production-Grade Intent Annotator for NICE Cognigy.AI
  • A Python module that programmatically annotates training data intents in NICE Cognigy.AI using atomic PUT operations, schema validation, and batch limit enforcement.
  • This implementation uses the Cognigy.AI v1 REST API for training data management, dataset versioning, and webhook synchronization.
  • The code is written in Python 3.9+ using httpx for async HTTP, pydantic for payload validation, and logging for audit governance.
  • OAuth2 client credentials or API key with scopes: trainingdata:read, trainingdata:write, datasets:manage, webhooks:write
  • Cognigy.AI v1 REST API (tenant base URL required)
  • Python 3.9 or higher
  • External dependencies: httpx, pydantic, orjson, structlog
  • Active Cognigy.AI tenant with dataset permissions
Cognigy.AI supports OAuth2 client credentials flow for programmatic access. The token endpoint returns a Bearer token valid for 3600 seconds. Token caching prevents unnecessary authentication requests and reduces 429 rate-limit exposure.
import httpx
import orjson
from dataclasses import dataclass
from typing import Optional
@dataclass
class TokenStore:
    access_token: Optional[str] = None
    expires_at: float = 0.0
    def is_valid(self) -> bool:
        return self.access_token is not None and time.time() < self.expires_at
async def fetch_cognigy_token(client_id: str, client_secret: str, tenant_url: str) -> TokenStore:
    auth_url = f"{tenant_url}/oauth/token"
    async with httpx.AsyncClient(timeout=10.0) as http:
        response = await http.post(
            auth_url,
            headers={"Content-Type": "application/x-www-form-urlencoded"},
            data={
                "client_id": client_id,
                "client_secret": client_secret,
                "scope": "trainingdata:read trainingdata:write datasets:manage webhooks:write"
        response.raise_for_status()
        payload = response.json()
        return TokenStore(
            access_token=payload["access_token"],
            expires_at=time.time() + payload["expires_in"]
Step 1: Schema Validation & Payload Construction
The annotation payload must align with Cognigy.AI training data constraints. Each record requires a training instance ID reference, an intent label matrix (supporting primary and secondary labels), and a confidence score directive between 0.0 and 1.0. The batch limit is enforced at 50 records to prevent payload rejection.
from pydantic import BaseModel, Field, validator
class IntentLabelMatrix(BaseModel):
    primary: str
    secondary: List[str] = Field(default_factory=list)
class ConfidenceDirective(BaseModel):
    score: float = Field(..., ge=0.0, le=1.0)
    source: str = Field(..., regex=r"^(manual|automated|model_fallback)$")
class AnnotationPayload(BaseModel):
    training_instance_id: str
    intent_labels: IntentLabelMatrix
    confidence: ConfidenceDirective
    metadata: Dict[str, Any] = Field(default_factory=dict)
    @validator("training_instance_id")
    def validate_instance_id(cls, v):
        if not v.startswith("train_"):
            raise ValueError("Training instance ID must start with 'train_'")
        return v
class BatchAnnotationRequest(BaseModel):
    annotations: List[AnnotationPayload]
    @validator("annotations")
    def enforce_batch_limit(cls, v):
        if len(v) > 50:
            raise ValueError("Maximum batch size is 50 annotations")
        if len(v) == 0:
            raise ValueError("Batch must contain at least one annotation")
        return v
Step 2: Atomic PUT Operations & Dataset Version Triggers
Label assignment requires atomic PUT requests to /api/v1/trainingdata/{training_instance_id}. Each successful commit triggers a dataset version increment to maintain safe iteration boundaries. The version endpoint prevents concurrent training runs from reading inconsistent state.
import logging
from httpx import AsyncClient, HTTPStatusError, Retry, TransportError
from typing import List, Tuple
logger = logging.getLogger("cognigy.annotator")
class CognigyAnnotator:
    def __init__(self, base_url: str, token_store: TokenStore):
        self.token_store = token_store
        self.retry_transport = httpx.AsyncHTTPTransport(
            retries=Retry(max=3, backoff_factor=0.5, allowed_methods=["PUT", "POST"])
        self.client = AsyncClient(transport=self.retry_transport, timeout=15.0)
        self.metrics = {"latency_ms": [], "success_count": 0, "failure_count": 0}
        self.audit_log: List[Dict[str, Any]] = []
    async def _get_headers(self) -> Dict[str, str]:
        if not self.token_store.is_valid():
            raise RuntimeError("Authentication token expired. Refresh required.")
            "Authorization": f"Bearer {self.token_store.access_token}",
            "Accept": "application/json"
    async def commit_annotation(self, payload: AnnotationPayload) -> Tuple[bool, float]:
        url = f"{self.base_url}/api/v1/trainingdata/{payload.training_instance_id}"
        # HTTP Request Cycle Example (logged for debugging)
        # PUT /api/v1/trainingdata/train_abc123
        # Headers: Authorization: Bearer <token>, Content-Type: application/json
        # Body: {"intent_labels": {"primary": "book_flight", "secondary": ["airline_change"]},
        #        "confidence": {"score": 0.92, "source": "manual"},
        #        "metadata": {"annotator_id": "sys_01"}}
        # Response 200: {"id": "train_abc123", "text": "I need a flight to Paris",
        #                "intent": "book_flight", "confidence": 0.92, "updated_at": "2024-05-20T10:00:00Z"}
            response = await self.client.put(
                url,
                headers=await self._get_headers(),
                content=orjson.dumps(payload.dict(exclude_none=True))
        except HTTPStatusError as e:
            latency = (time.perf_counter() - start_time) * 1000
            self.metrics["latency_ms"].append(latency)
            self.metrics["failure_count"] += 1
            self._log_audit(payload.training_instance_id, "FAILED", str(e.response.text), latency)
            return False, latency
        except TransportError as e:
            self._log_audit(payload.training_instance_id, "NETWORK_ERROR", str(e), latency)
        self.metrics["success_count"] += 1
        self._log_audit(payload.training_instance_id, "COMMITTED", "200 OK", latency)
        return True, latency
    async def trigger_dataset_version(self, dataset_id: str) -> str:
        url = f"{self.base_url}/api/v1/datasets/{dataset_id}/version"
        response = await self.client.post(
            url,
            json={"reason": "intent_annotation_batch_complete", "force": False}
        return response.json()["version_id"]
    def _log_audit(self, instance_id: str, status: str, detail: str, latency_ms: float):
        entry = {
            "timestamp": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime()),
            "training_instance_id": instance_id,
            "status": status,
            "detail": detail[:200]
        self.audit_log.append(entry)
        logger.info("Annotation audit: %s", orjson.dumps(entry).decode())
Step 3: Validation Logic & Quality Pipelines
Label consistency checking prevents conflicting intent assignments. The pipeline verifies that primary labels exist in the target dataset schema, enforces confidence thresholds, and filters out low-quality training instances before submission.
from typing import Set
class AnnotationQualityPipeline:
    def __init__(self, valid_intents: Set[str], min_confidence: float = 0.75):
        self.valid_intents = valid_intents
        self.min_confidence = min_confidence
    def validate_batch(self, batch: BatchAnnotationRequest) -> List[AnnotationPayload]:
        validated = []
        for item in batch.annotations:
            if item.intent_labels.primary not in self.valid_intents:
                logger.warning("Rejected intent not in schema: %s", item.intent_labels.primary)
            if item.confidence.score < self.min_confidence:
                logger.warning("Rejected low confidence score: %.2f", item.confidence.score)
            if len(item.intent_labels.secondary) > 3:
                logger.warning("Rejected excessive secondary labels: %d", len(item.intent_labels.secondary))
            validated.append(item)
        return validated
    def verify_format_consistency(self, payload: AnnotationPayload) -> bool:
        required_fields = ["training_instance_id", "intent_labels", "confidence"]
        if not all(hasattr(payload, f) for f in required_fields):
            return False
        if not payload.training_instance_id or not payload.intent_labels.primary:
            return False
        return True
Step 4: Webhook Synchronization & Latency Tracking
External annotation platforms require event alignment. After each successful commit, the annotator dispatches a synchronization webhook. Latency tracking aggregates commit times and success rates for operational dashboards.
import asyncio
class WebhookSyncDispatcher:
    def __init__(self, endpoint: str, secret: str):
        self.endpoint = endpoint
        self.secret = secret
        self.client = AsyncClient(timeout=10.0)
    async def notify(self, event: Dict[str, Any]) -> None:
                self.endpoint,
                json=event,
                headers={"X-Webhook-Secret": self.secret, "Content-Type": "application/json"}
            logger.error("Webhook sync failed: %s", str(e))
def calculate_efficiency_metrics(metrics: Dict[str, Any]) -> Dict[str, float]:
    total = metrics["success_count"] + metrics["failure_count"]
    success_rate = (metrics["success_count"] / total * 100) if total > 0 else 0.0
    avg_latency = sum(metrics["latency_ms"]) / len(metrics["latency_ms"]) if metrics["latency_ms"] else 0.0
    return {"success_rate_pct": round(success_rate, 2), "avg_latency_ms": round(avg_latency, 2)}
Step 5: Automated Intent Annotator Orchestration
The orchestrator ties validation, atomic commits, version triggers, and webhook sync into a single execution flow. It processes paginated training data, respects batch limits, and generates governance logs.
import asyncio
class IntentAnnotatorOrchestrator:
    def __init__(self, annotator: CognigyAnnotator, pipeline: AnnotationQualityPipeline, dispatcher: WebhookSyncDispatcher):
        self.annotator = annotator
        self.pipeline = pipeline
        self.dispatcher = dispatcher
        self.base_url = annotator.base_url
    async def fetch_training_data_page(self, offset: int, limit: int = 100) -> List[Dict[str, Any]]:
        url = f"{self.base_url}/api/v1/trainingdata"
        params = {"offset": offset, "limit": limit, "status": "pending_annotation"}
        response = await self.annotator.client.get(
            url, headers=await self.annotator._get_headers(), params=params
        data = response.json()
        return data.get("items", [])
    async def process_batch(self, dataset_id: str, valid_intents: Set[str]) -> Dict[str, Any]:
        offset = 0
        total_processed = 0
        all_audit_logs = []
        while True:
            raw_items = await self.fetch_training_data_page(offset, limit=50)
            if not raw_items:
                break
            payloads = []
            for item in raw_items:
                payload = AnnotationPayload(
                    training_instance_id=item["id"],
                    intent_labels=IntentLabelMatrix(primary=item.get("suggested_intent", "unknown"), secondary=[]),
                    confidence=ConfidenceDirective(score=item.get("confidence", 0.85), source="automated"),
                    metadata={"original_text": item.get("text", ""), "pipeline_run": "v1.2"}
                payloads.append(payload)
            batch_request = BatchAnnotationRequest(annotations=payloads)
            validated_items = self.pipeline.validate_batch(batch_request)
            for item in validated_items:
                if not self.pipeline.verify_format_consistency(item):
                success, latency = await self.annotator.commit_annotation(item)
                if success:
                    await self.dispatcher.notify({
                        "event": "annotation.committed",
                        "training_instance_id": item.training_instance_id,
                        "intent": item.intent_labels.primary,
                        "confidence": item.confidence.score,
                        "latency_ms": latency
            all_audit_logs.extend(self.annotator.audit_log)
            total_processed += len(validated_items)
            offset += 50
        version_id = await self.annotator.trigger_dataset_version(dataset_id)
        metrics = calculate_efficiency_metrics(self.annotator.metrics)
        metrics["dataset_version"] = version_id
        metrics["total_processed"] = total_processed
        return metrics
The following script demonstrates end-to-end execution. Replace placeholder credentials and tenant URL before running.
import asyncio
import logging
import sys
# Configure logging
logging.basicConfig(level=logging.INFO, format="%(asctime)s [%(levelname)s] %(name)s: %(message)s")
logger = logging.getLogger("cognigy.main")
async def main() -> None:
    tenant_url = "https://api.cognigy.ai"  # Replace with your tenant URL
    client_id = "your_client_id"
    client_secret = "your_client_secret"
    dataset_id = "dataset_prod_v1"
    valid_intents: Set[str] = {"book_flight", "cancel_reservation", "change_seat", "check_status"}
    # Authentication
    token_store = await fetch_cognigy_token(client_id, client_secret, tenant_url)
    if not token_store.access_token:
        logger.error("Authentication failed. Exiting.")
        sys.exit(1)
    # Initialize components
    annotator = CognigyAnnotator(base_url=tenant_url, token_store=token_store)
    pipeline = AnnotationQualityPipeline(valid_intents=valid_intents, min_confidence=0.80)
    dispatcher = WebhookSyncDispatcher(endpoint="https://hooks.external-platform.com/cognigy-sync", secret="whsec_123456")
    orchestrator = IntentAnnotatorOrchestrator(annotator=annotator, pipeline=pipeline, dispatcher=dispatcher)
        logger.info("Starting annotation pipeline for dataset: %s", dataset_id)
        results = await orchestrator.process_batch(dataset_id=dataset_id, valid_intents=valid_intents)
        logger.info("Pipeline complete. Metrics: %s", results)
        logger.info("Audit log entries generated: %d", len(annotator.audit_log))
        logger.error("Pipeline execution failed: %s", str(e))
        sys.exit(1)
    finally:
        await annotator.client.aclose()
    asyncio.run(main())
  • Cause: Expired Bearer token or invalid client credentials. The Cognigy.AI token endpoint rejects malformed client_secret or missing grant_type.
  • Fix: Verify token store validity before each batch. Implement automatic token refresh in production loops.
  • Code showing the fix:
    self.token_store = await fetch_cognigy_token(self.client_id, self.client_secret, self.base_url)
Error: 400 Bad Request (Schema Validation Failure)
  • Cause: Payload contains invalid intent labels, out-of-range confidence scores, or exceeds the 50-record batch limit. Cognigy.AI rejects training instance IDs that do not match the train_ prefix.
  • Fix: Run payloads through AnnotationQualityPipeline before submission. Enforce ge=0.0 and le=1.0 on confidence directives.
# Only processed items pass schema and threshold checks
Error: 409 Conflict (Dataset Version Lock)
  • Cause: Concurrent annotation runs attempt to write to the same dataset version. Cognigy.AI locks datasets during active version increments.
  • Fix: Trigger dataset versioning only after batch completion. Use exponential backoff if 409 occurs.
    for attempt in range(3):
        response = await self.client.post(f"{self.base_url}/api/v1/datasets/{dataset_id}/version", ...)
        if response.status_code == 409:
            await asyncio.sleep(2 ** attempt)
    raise RuntimeError("Dataset version lock persisted after retries")
  • Cause: Exceeding Cognigy.AI rate limits (typically 100 requests per minute per tenant for training data endpoints).
  • Fix: The httpx retry transport handles 429 responses automatically with backoff. Add explicit rate limiting for high-throughput pipelines.
