Building a Production-Grade Cognigy.AI Handoff Webhook Handler in Python
A Python FastAPI service that receives Cognigy.AI handoff triggers, validates payload schemas against engine constraints, routes conversations to external channels, and returns compliant response payloads. The implementation uses Pydantic for strict schema enforcement, httpx for synchronous routing engine calls, and structured logging for governance tracking. The tutorial covers Python 3.9+ with FastAPI, Pydantic, and httpx.
- Cognigy.AI instance with webhook endpoints configured in the dialogue flow
- Cognigy REST API OAuth2 client credentials (client ID and client secret)
- OAuth scopes:
cognigy:api:read,cognigy:api:write - Python 3.9+ runtime
- External dependencies:
fastapi,uvicorn,pydantic,httpx,structlog - Install dependencies via
pip install fastapi uvicorn pydantic httpx structlog
Cognigy.AI REST API operations require a Bearer token obtained through the OAuth2 client credentials flow. The handler caches the token and refreshes it when expired to prevent authentication failures during high-volume handoff processing.
import os
import httpx
from typing import Optional
COGNIFY_BASE_URL = os.getenv("COGNIFY_BASE_URL", "https://your-domain.cognigy.ai")
CLIENT_ID = os.getenv("COGNIFY_CLIENT_ID")
CLIENT_SECRET = os.getenv("COGNIFY_CLIENT_SECRET")
TOKEN_ENDPOINT = f"{COGNIFY_BASE_URL}/api/v1/oauth/token"
class CognigyTokenManager:
def __init__(self) -> None:
self._expiry: float = 0.0
def get_token(self) -> str:
if self._token and time.time() < self._expiry:
return self._token
self._refresh_token()
return self._token
def _refresh_token(self) -> None:
payload = {
"client_id": CLIENT_ID,
"client_secret": CLIENT_SECRET
with httpx.Client(timeout=10.0) as client:
response = client.post(TOKEN_ENDPOINT, data=payload)
response.raise_for_status()
data = response.json()
self._token = data["access_token"]
self._expiry = time.time() + data["expires_in"] - 30
except httpx.HTTPStatusError as exc:
raise RuntimeError(f"Token refresh failed with status {exc.response.status_code}: {exc.response.text}") from exc
except httpx.RequestError as exc:
raise RuntimeError(f"Network error during token refresh: {exc}") from exc
Step 1: Schema Validation and Payload Construction
Cognigy.AI enforces strict payload limits and schema constraints for webhook handoffs. The handler defines Pydantic models that mirror the dialogue engine expectations, validates incoming JSON against maximum payload size, and rejects malformed requests before processing.
import json
from pydantic import BaseModel, Field, validator
from typing import Any, Dict, Optional
MAX_PAYLOAD_BYTES = 102400 # 100KB Cognigy webhook limit
class CognigyHandoffPayload(BaseModel):
session: Dict[str, Any]
context: Dict[str, Any]
user: Dict[str, Any]
handoff: Dict[str, Any]
payload: Optional[Dict[str, Any]] = None
@validator("context")
def validate_handoff_trigger(cls, v: Dict[str, Any]) -> Dict[str, Any]:
if "handoffTrigger" not in v:
raise ValueError("Missing required field: handoffTrigger")
return v
@validator("handoff")
def validate_channel_matrix(cls, v: Dict[str, Any]) -> Dict[str, Any]:
required_channels = ["targetChannel", "priority"]
missing = [k for k in required_channels if k not in v]
if missing:
raise ValueError(f"Missing channel matrix fields: {', '.join(missing)}")
return v
def validate_raw_payload(raw_body: bytes) -> CognigyHandoffPayload:
if len(raw_body) > MAX_PAYLOAD_BYTES:
raise ValueError(f"Payload exceeds maximum limit of {MAX_PAYLOAD_BYTES} bytes")
parsed = json.loads(raw_body)
except json.JSONDecodeError as exc:
raise ValueError("Invalid JSON format in webhook payload") from exc
return CognigyHandoffPayload(**parsed)
Step 2: Handoff Processing, Channel Verification, and Routing Sync
The handler checks channel availability, verifies user consent from the context, executes an atomic POST to the external routing engine, and triggers session migration. All outbound calls include retry logic for rate limits and explicit timeout handling.
import httpx
from typing import Dict, Any
ROUTING_ENGINE_URL = os.getenv("ROUTING_ENGINE_URL", "https://routing.internal/api/v1/handoffs")
CHANNEL_AVAILABILITY_URL = os.getenv("CHANNEL_AVAILABILITY_URL", "https://routing.internal/api/v1/channels/status")
def check_channel_availability(channel_id: str, token: str) -> bool:
with httpx.Client(timeout=5.0) as client:
resp = client.get(f"{CHANNEL_AVAILABILITY_URL}/{channel_id}", headers=headers)
resp.raise_for_status()
return resp.json().get("available", False)
except httpx.HTTPStatusError:
return False
except httpx.RequestError:
return False
def post_to_routing_engine(session_id: str, payload: Dict[str, Any], token: str) -> Dict[str, Any]:
max_retries = 3
base_delay = 1.0
resp = client.post(ROUTING_ENGINE_URL, json=payload, headers=headers)
if resp.status_code == 429:
retry_after = float(resp.headers.get("Retry-After", base_delay * (2 ** attempt)))
time.sleep(retry_after)
return resp.json()
if exc.response.status_code == 429:
time.sleep(base_delay * (2 ** attempt))
raise RuntimeError(f"Routing engine failed: {exc.response.text}") from exc
raise RuntimeError(f"Network error contacting routing engine: {exc}") from exc
raise RuntimeError("Routing engine rate limit exceeded after maximum retries")
def process_handoff(session_data: Dict[str, Any], context: Dict[str, Any], handoff_data: Dict[str, Any], token: str) -> Dict[str, Any]:
user_consent = context.get("userConsent", False)
if not user_consent:
raise ValueError("User consent verification failed. Handoff aborted.")
target_channel = handoff_data["targetChannel"]
if not check_channel_availability(target_channel, token):
raise RuntimeError(f"Target channel {target_channel} is unavailable")
routing_payload = {
"sessionId": session_data["id"],
"channel": target_channel,
"priority": handoff_data["priority"],
"contextTransfer": context,
"triggerSource": "cognigy_webhook"
routing_result = post_to_routing_engine(session_data["id"], routing_payload, token)
return routing_result
Step 3: Latency Tracking, Audit Logging, and Response Generation
The handler measures processing latency, generates structured audit logs for governance, and constructs the exact JSON response structure Cognigy.AI expects to continue or terminate the dialogue session.
import structlog
import logging
import uuid
def generate_audit_log(
session_id: str,
trigger: str,
channel: str,
latency_ms: float,
success: bool,
error: Optional[str] = None
) -> None:
logger.info(
"handoff_audit",
event_id=str(uuid.uuid4()),
timestamp=datetime.now(timezone.utc).isoformat(),
session_id=session_id,
trigger=trigger,
target_channel=channel,
latency_ms=round(latency_ms, 2),
success=success,
error=error
def build_cognigy_response(context_update: Dict[str, Any], end_conversation: bool = False) -> Dict[str, Any]:
"response": "Your request has been routed. An agent will join shortly.",
"context": context_update,
"endConversation": end_conversation
The following FastAPI application integrates all components into a single runnable module. Deploy with uvicorn main:app --host 0.0.0.0 --port 8000.
import os
import json
import uvicorn
from fastapi import FastAPI, Request, HTTPException
from fastapi.responses import JSONResponse
from typing import Any, Dict, Optional, Union
import httpx
import structlog
# Configure structured logging
structlog.configure(
processors=[
structlog.stdlib.filter_by_level,
structlog.stdlib.add_logger_name,
structlog.stdlib.add_log_level,
structlog.stdlib.PositionalArgumentsFormatter(),
structlog.processors.TimeStamper(fmt="iso"),
structlog.processors.JSONRenderer()
context_class=dict,
logger_factory=structlog.stdlib.LoggerFactory(),
wrapper_class=structlog.stdlib.BoundLogger,
cache_logger_on_first_use=True,
# Configuration
CLIENT_ID = os.getenv("COGNIFY_CLIENT_ID", "your_client_id")
CLIENT_SECRET = os.getenv("COGNIFY_CLIENT_SECRET", "your_client_secret")
app = FastAPI(title="Cognigy Handoff Handler", version="1.0.0")
return v
if missing:
return v
class TokenManager:
return self._token
return self._token
payload = {
response = client.post(f"{COGNIFY_BASE_URL}/api/v1/oauth/token", data=payload)
token_manager = TokenManager()
return False
return False
max_retries = 3
base_delay = 1.0
return resp.json()
@app.post("/webhook/cognigy/handoff")
async def handle_handoff(request: Request) -> JSONResponse:
raw_body = await request.body()
generate_audit_log("unknown", "unknown", "unknown", 0, False, "Payload exceeds 100KB limit")
return JSONResponse(status_code=413, content={"error": "Payload size exceeds maximum limit"})
payload = CognigyHandoffPayload(**parsed)
except json.JSONDecodeError:
return JSONResponse(status_code=400, content={"error": "Invalid JSON format"})
except ValueError as exc:
return JSONResponse(status_code=400, content={"error": str(exc)})
session_id = payload.session.get("id", "unknown")
trigger = payload.context.get("handoffTrigger", "unknown")
target_channel = payload.handoff.get("targetChannel", "unknown")
token = token_manager.get_token()
user_consent = payload.context.get("userConsent", False)
routing_payload = {
"sessionId": session_id,
"priority": payload.handoff["priority"],
"contextTransfer": payload.context,
routing_result = post_to_routing_engine(session_id, routing_payload, token)
context_update = {
"handoffCompleted": True,
"routingTicketId": routing_result.get("ticketId"),
"estimatedWait": routing_result.get("estimatedWaitSeconds", 0)
generate_audit_log(session_id, trigger, target_channel, latency_ms, True)
response_data = build_cognigy_response(context_update, end_conversation=False)
return JSONResponse(content=response_data, status_code=200)
except Exception as exc:
generate_audit_log(session_id, trigger, target_channel, latency_ms, False, str(exc))
logger.error("handoff_processing_failed", error=str(exc))
status_code=500,
content={"error": "Internal processing error", "details": str(exc)}
session_id: str,
trigger: str,
channel: str,
latency_ms: float,
success: bool,
) -> None:
logger.info(
"handoff_audit",
trigger=trigger,
success=success,
error=error
uvicorn.run(app, host="0.0.0.0", port=8000)
Error: 400 Bad Request (Schema Validation Failure)
Cognigy rejects payloads that lack required handoff fields or exceed size limits. The handler validates the JSON structure before routing. If you receive a 400, verify that the webhook configuration in Cognigy includes handoffTrigger, targetChannel, and priority in the context and handoff objects. Ensure the raw payload does not exceed 100KB.
Error: 401 Unauthorized (Token Expired or Invalid)
The OAuth2 client credentials flow may return an expired token if the TTL calculation drifts. The TokenManager class subtracts 30 seconds from the expires_in value to prevent boundary failures. If 401 errors persist, verify that the client credentials possess the cognigy:api:read and cognigy:api:write scopes. Regenerate credentials in the Cognigy admin console if rotation occurred.
Error: 429 Too Many Requests (Routing Engine Rate Limit)
External routing engines enforce request quotas. The post_to_routing_engine function implements exponential backoff with a maximum of three retries. If the routing engine returns a Retry-After header, the handler respects it. Monitor your routing engine dashboard and adjust the max_retries and base_delay parameters if your handoff volume exceeds current quotas.
Error: 504 Gateway Timeout (Channel Availability Check Failure)
Network partitions or DNS resolution failures can cause timeout exceptions during channel verification. The handler uses a 5-second timeout for availability checks and falls back to False on failure. Verify that the CHANNEL_AVAILABILITY_URL resolves correctly from the deployment environment. Add infrastructure health checks to prevent silent routing failures.
