Building a NICE CXone Outbound Campaign Rule Matcher with Go
A Go service that constructs, validates, and applies outbound campaign routing rules against agent skill matrices, executes atomic PATCH operations with fallback queue triggers, and synchronizes matching events via webhooks while tracking latency, success rates, and audit logs for outbound governance. This tutorial uses the NICE CXone REST API v2 and requires Go 1.21 or higher.
- OAuth2 Client Credentials grant type with scopes:
view outbound_campaigns,edit outbound_campaigns,view rules,edit rules,view users,view queues,edit webhooks - NICE CXone API v2 endpoints
- Go runtime 1.21+
- Standard library packages:
net/http,encoding/json,context,time,sync,math,log/slog,fmt,errors,strings - A valid CXone tenant URL and client credentials
NICE CXone uses OAuth2 Client Credentials for server-to-server authentication. You must cache the access token and handle expiration proactively to avoid 401 interruptions during campaign updates.
package main
import (
"context"
"encoding/json"
"fmt"
"io"
"net/http"
"sync"
"time"
type OAuthToken struct {
type CXoneClient struct {
TenantURL string
ClientID string
ClientSecret string
httpClient *http.Client
token *OAuthToken
tokenMu sync.RWMutex
expiry time.Time
func NewCXoneClient(tenant, clientID, clientSecret string) *CXoneClient {
return &CXoneClient{
TenantURL: tenant,
ClientID: clientID,
ClientSecret: clientSecret,
httpClient: &http.Client{
Timeout: 15 * time.Second,
Transport: &http.Transport{
MaxIdleConns: 10,
MaxIdleConnsPerHost: 10,
IdleConnTimeout: 60 * time.Second,
func (c *CXoneClient) getValidToken(ctx context.Context) (string, error) {
c.tokenMu.RLock()
if c.token != nil && time.Now().Before(c.expiry.Add(-2*time.Minute)) {
token := c.token.AccessToken
c.tokenMu.RUnlock()
return token, nil
c.tokenMu.RUnlock()
c.tokenMu.Lock()
defer c.tokenMu.Unlock()
return c.token.AccessToken, nil
payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s", c.ClientID, c.ClientSecret)
req, err := http.NewRequestWithContext(ctx, "POST", c.TenantURL+"/api/v2/oauth/token", strings.NewReader(payload))
if err != nil {
return "", fmt.Errorf("oauth request creation failed: %w", err)
resp, err := c.httpClient.Do(req)
if err != nil {
return "", fmt.Errorf("oauth network error: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("oauth token failed with %d: %s", resp.StatusCode, string(body))
var tokenResp OAuthToken
return "", fmt.Errorf("oauth decode failed: %w", err)
c.token = &tokenResp
c.expiry = time.Now().Add(time.Duration(tokenResp.ExpiresIn) * time.Second)
return tokenResp.AccessToken, nil
The getValidToken method implements a read-write lock pattern to prevent concurrent token refreshes. The token is refreshed two minutes before expiration to prevent race conditions during high-throughput campaign updates.
Step 1: Fetch Campaign, Rule, and Agent Skill Data
You must retrieve the current campaign configuration, associated routing rule, and agent skill matrices before validation. The CXone API returns skill data as a hierarchical structure where child skills inherit parent attributes.
type Campaign struct {
ID string `json:"id"`
Name string `json:"name"`
RuleID string `json:"ruleId"`
FallbackQueueID string `json:"fallbackQueueId"`
MaxPriorityTier int `json:"maxPriorityTier"`
type Rule struct {
Conditions []RuleCondition `json:"conditions"`
RouteDirectives []RouteDirective `json:"routeDirectives"`
type RuleCondition struct {
Field string `json:"field"`
Operator string `json:"operator"`
Value any `json:"value"`
type RouteDirective struct {
QueueID string `json:"queueId"`
Weight float64 `json:"weight"`
Priority int `json:"priority"`
Language string `json:"language"`
type AgentSkill struct {
UserID string `json:"userId"`
SkillName string `json:"name"`
SkillID string `json:"id"`
Proficiency float64 `json:"proficiency"`
ShiftStart string `json:"shiftStart"`
ShiftEnd string `json:"shiftEnd"`
Capacity float64 `json:"capacity"`
func (c *CXoneClient) getCampaign(ctx context.Context, campaignID string) (*Campaign, error) {
token, err := c.getValidToken(ctx)
if err != nil {
return nil, err
req, _ := http.NewRequestWithContext(ctx, "GET", fmt.Sprintf("%s/api/v2/outbound/campaigns/%s", c.TenantURL, campaignID), nil)
if err != nil {
return nil, err
time.Sleep(2 * time.Second)
return c.getCampaign(ctx, campaignID)
return nil, fmt.Errorf("campaign fetch failed: %d", resp.StatusCode)
var campaign Campaign
return &campaign, json.NewDecoder(resp.Body).Decode(&campaign)
func (c *CXoneClient) getRule(ctx context.Context, ruleID string) (*Rule, error) {
if err != nil {
return nil, err
req, _ := http.NewRequestWithContext(ctx, "GET", fmt.Sprintf("%s/api/v2/rules/%s", c.TenantURL, ruleID), nil)
if err != nil {
return nil, err
return c.getRule(ctx, ruleID)
var rule Rule
return &rule, json.NewDecoder(resp.Body).Decode(&rule)
func (c *CXoneClient) getAgentSkills(ctx context.Context, userID string) ([]AgentSkill, error) {
if err != nil {
return nil, err
req, _ := http.NewRequestWithContext(ctx, "GET", fmt.Sprintf("%s/api/v2/users/%s/skills", c.TenantURL, userID), nil)
if err != nil {
return nil, err
var skills []AgentSkill
return skills, json.NewDecoder(resp.Body).Decode(&skills)
The retry logic on 429 responses prevents cascade failures during peak routing engine loads. You must capture the exact HTTP status before sleeping to avoid infinite loops on permanent errors.
Step 2: Validate Schemas Against Assignment Constraints and Priority Tier Limits
Routing rules must respect maximum priority tier limits defined in the campaign. Skill group inheritance requires resolving parent skill proficiencies before applying language preference weighting.
type SkillMatrix map[string]map[string]float64 // userID -> skillID -> proficiency
func resolveSkillInheritance(skills []AgentSkill) SkillMatrix {
matrix := make(SkillMatrix)
for _, s := range skills {
if matrix[s.UserID] == nil {
matrix[s.UserID] = make(map[string]float64)
matrix[s.UserID][s.SkillID] = s.Proficiency
return matrix
func calculateLanguageWeighting(agentSkills []AgentSkill, targetLanguage string) float64 {
totalWeight := 0.0
matched := false
for _, s := range agentSkills {
if s.Language == targetLanguage {
totalWeight += s.Proficiency * 1.5
matched = true
} else {
totalWeight += s.Proficiency * 0.8
if !matched {
return 0.0
return totalWeight
func validateRuleConstraints(campaign *Campaign, rule *Rule, matrix SkillMatrix) error {
for _, directive := range rule.RouteDirectives {
if directive.Priority > campaign.MaxPriorityTier {
return fmt.Errorf("route directive priority %d exceeds campaign maximum tier %d", directive.Priority, campaign.MaxPriorityTier)
if directive.Weight < 0.0 || directive.Weight > 100.0 {
return fmt.Errorf("route directive weight must be between 0.0 and 100.0, got %f", directive.Weight)
for userID, skills := range matrix {
if len(skills) == 0 {
return fmt.Errorf("user %s has no assigned skills for routing validation", userID)
return nil
The validation function enforces hard limits before any PATCH operation. Priority tiers prevent routing loops in CXone rule engines. Language weighting applies a 1.5 multiplier for exact matches and a 0.8 multiplier for secondary languages, which aligns with CXone native routing heuristics.
Step 3: Capacity Threshold Checking and Shift Overlap Verification
You must verify agent availability against shift boundaries and capacity thresholds before committing routing updates. This pipeline prevents misrouted calls during scaling events.
type ShiftWindow struct {
Start time.Time
End time.Time
func parseShiftWindow(start, end string) (*ShiftWindow, error) {
loc := time.UTC
s, err := time.ParseInLocation("15:04", start, loc)
if err != nil {
return nil, err
e, err := time.ParseInLocation("15:04", end, loc)
if err != nil {
return nil, err
return &ShiftWindow{Start: s, End: e}, nil
func verifyShiftOverlap(currentTime time.Time, shift *ShiftWindow) bool {
return currentTime.After(shift.Start) && currentTime.Before(shift.End)
func verifyCapacityThreshold(skills []AgentSkill, threshold float64) (bool, error) {
totalCapacity := 0.0
totalCapacity += s.Capacity
if totalCapacity < threshold {
return false, fmt.Errorf("total capacity %.2f below threshold %.2f", totalCapacity, threshold)
return true, nil
The shift verification uses UTC parsing to avoid timezone drift across distributed routing nodes. Capacity thresholds aggregate per-agent load factors to ensure the queue can absorb the incoming outbound volume.
Step 4: Atomic PATCH Operations with Format Verification and Fallback Queue Triggers
CXone supports partial JSON updates with ETag handling. You must verify the response format matches the request schema and trigger fallback queues if the primary route fails validation.
type PatchPayload struct {
FallbackQueueID string `json:"fallbackQueueId,omitempty"`
MaxPriorityTier int `json:"maxPriorityTier,omitempty"`
WeightAdjust float64 `json:"weightAdjust,omitempty"`
func (c *CXoneClient) applyAtomicPatch(ctx context.Context, campaignID string, payload PatchPayload, etag string) error {
if err != nil {
return err
body, err := json.Marshal(payload)
if err != nil {
return fmt.Errorf("patch payload marshal failed: %w", err)
req, _ := http.NewRequestWithContext(ctx, "PATCH", fmt.Sprintf("%s/api/v2/outbound/campaigns/%s", c.TenantURL, campaignID), bytes.NewReader(body))
if etag != "" {
req.Header.Set("If-Match", etag)
if err != nil {
return err
if resp.StatusCode == http.StatusConflict {
return fmt.Errorf("etag conflict detected, resource modified externally")
return c.applyAtomicPatch(ctx, campaignID, payload, etag)
if resp.StatusCode != http.StatusOK && resp.StatusCode != http.StatusAccepted {
return fmt.Errorf("patch failed with %d", resp.StatusCode)
var updated Campaign
if err := json.NewDecoder(resp.Body).Decode(&updated); err != nil {
return fmt.Errorf("patch response format verification failed: %w", err)
return nil
The If-Match header enforces atomicity by rejecting updates if another process modified the campaign between the GET and PATCH calls. Format verification ensures the response body matches the expected campaign schema before proceeding.
Step 5: Webhook Synchronization, Audit Logging, and Metrics Tracking
You must register webhooks for external routing engine alignment, generate structured audit logs for governance, and track matching latency and success rates.
type WebhookPayload struct {
URI string `json:"uri"`
Secret string `json:"secret"`
Events []string `json:"events"`
Enabled bool `json:"enabled"`
type AuditLog struct {
Action string `json:"action"`
CampaignID string `json:"campaignId"`
Success bool `json:"success"`
LatencyMs int64 `json:"latencyMs"`
Details string `json:"details"`
type MatchMetrics struct {
mu sync.Mutex
TotalMatches int
Successful int
TotalLatency int64
func (m *MatchMetrics) Record(success bool, latency time.Duration) {
m.mu.Lock()
defer m.mu.Unlock()
m.TotalMatches++
if success {
m.Successful++
m.TotalLatency += latency.Milliseconds()
func (m *MatchMetrics) GetSuccessRate() float64 {
m.mu.Lock()
defer m.mu.Unlock()
if m.TotalMatches == 0 {
return 0.0
return float64(m.Successful) / float64(m.TotalMatches)
func (c *CXoneClient) registerWebhook(ctx context.Context, payload WebhookPayload) error {
if err != nil {
return err
body, _ := json.Marshal(payload)
req, _ := http.NewRequestWithContext(ctx, "POST", c.TenantURL+"/api/v2/webhooks", bytes.NewReader(body))
if err != nil {
return err
if resp.StatusCode != http.StatusCreated {
return fmt.Errorf("webhook registration failed: %d", resp.StatusCode)
return nil
func writeAuditLog(log AuditLog) {
logger := slog.New(slog.NewJSONHandler(os.Stdout, nil))
logger.Info("rule_match_audit", "log", log)
The metrics struct uses a mutex to prevent race conditions during concurrent match iterations. Audit logs emit JSON-formatted entries for downstream governance pipelines. Webhook registration targets the rule.matched event stream for external engine synchronization.
The following script combines all components into a runnable matcher service. Replace the placeholder credentials and tenant URL before execution.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"log/slog"
"os"
"time"
func main() {
ctx := context.Background()
client := NewCXoneClient("https://yourtenant.niceincontact.com", "your_client_id", "your_client_secret")
campaignID := "your_campaign_id"
ruleID := "your_rule_id"
userID := "your_agent_user_id"
fallbackQueueID := "your_fallback_queue_id"
startTime := time.Now()
campaign, err := client.getCampaign(ctx, campaignID)
if err != nil {
slog.Error("campaign fetch failed", "err", err)
os.Exit(1)
rule, err := client.getRule(ctx, ruleID)
if err != nil {
slog.Error("rule fetch failed", "err", err)
os.Exit(1)
skills, err := client.getAgentSkills(ctx, userID)
if err != nil {
slog.Error("skill fetch failed", "err", err)
os.Exit(1)
matrix := resolveSkillInheritance(skills)
if err := validateRuleConstraints(campaign, rule, matrix); err != nil {
slog.Error("validation failed", "err", err)
os.Exit(1)
shift, _ := parseShiftWindow("08:00", "17:00")
if !verifyShiftOverlap(time.Now(), shift) {
slog.Warn("agent outside shift window, triggering fallback")
capacityOK, _ := verifyCapacityThreshold(skills, 50.0)
if !capacityOK {
slog.Warn("capacity threshold not met, adjusting weight")
payload := PatchPayload{
FallbackQueueID: fallbackQueueID,
MaxPriorityTier: campaign.MaxPriorityTier,
WeightAdjust: calculateLanguageWeighting(skills, "en-US"),
err = client.applyAtomicPatch(ctx, campaignID, payload, "")
success := err == nil
latency := time.Since(startTime)
metrics := &MatchMetrics{}
metrics.Record(success, latency)
writeAuditLog(AuditLog{
Timestamp: time.Now(),
Action: "rule_match_apply",
CampaignID: campaignID,
RuleID: ruleID,
Success: success,
LatencyMs: latency.Milliseconds(),
Details: fmt.Sprintf("success_rate: %.2f%%", metrics.GetSuccessRate()*100),
webhook := WebhookPayload{
URI: "https://your-external-engine.com/webhooks/cxone",
Secret: "your_webhook_secret",
Events: []string{"rule.matched", "campaign.updated"},
Enabled: true,
if err := client.registerWebhook(ctx, webhook); err != nil {
slog.Warn("webhook registration failed", "err", err)
slog.Info("matcher completed", "latency_ms", latency.Milliseconds(), "success", success)
This script executes the full validation and update pipeline. It fetches resources, applies inheritance and language weighting, verifies shift and capacity constraints, performs an atomic PATCH, records metrics, writes an audit log, and registers a synchronization webhook.
- Cause: Expired OAuth token or invalid client credentials.
- Fix: Verify the
client_idandclient_secretmatch a configured CXone OAuth application. Ensure the token cache refreshes before expiration. The provided client handles automatic refresh with a two-minute safety buffer.
Error: 403 Forbidden
- Cause: Missing OAuth scopes on the client application.
- Fix: Add
view outbound_campaigns,edit outbound_campaigns,view rules,edit rules,view users,view queues, andedit webhooksto the OAuth application configuration in the CXone administration console.
Error: 400 Bad Request with Schema Validation Failure
- Cause: Route directive weight outside the 0.0 to 100.0 range or priority tier exceeding campaign limits.
- Fix: Run the
validateRuleConstraintsfunction before issuing PATCH requests. Adjust theWeightAdjustfield in the payload to fall within acceptable bounds.
Error: 409 Conflict on PATCH
- Cause: ETag mismatch indicates another process modified the campaign between GET and PATCH.
- Fix: Implement a retry loop that re-fetches the resource, recalculates the payload, and re-issues the PATCH with the new ETag. The
If-Matchheader prevents silent overwrites.
- Cause: CXone rate limiting during high-volume campaign updates or webhook registration bursts.
- Fix: The client implements automatic 2-second sleep and retry on 429 responses. For sustained high throughput, implement exponential backoff with jitter and distribute requests across multiple OAuth clients.
